Grab hooks for LL1102 loader bucket
   / Grab hooks for LL1102 loader bucket #1
dadkev
LSMT125
Hello,
I'm looking at adding grab hooks to my loader bucket. The top of the bucket has a shorter flat area before it starts bending downward. Underneath it is also where the quick release slides up into. Most hooks are longer than this available flat area. I would also need to weld it on so nothing interferes with the quick release. Anyone found something that works? Would you just weld on a typical hook even though the entire perimeter of the hook could not be welded. Or is there a mounting plate with hooks available that follows the curvature of the top of the bucket?
Thanks for any help.
   / Grab hooks for LL1102 loader bucket #2
This is what I did.
   / Grab hooks for LL1102 loader bucket #4
I wasn't sure of the metal thickness on top of the bucket so I added a piece of 3/16"
angle all the way across and welded my hooks to that.
Thanks for all the pictures. Mine looks different though. The area I could weld a hook is slightly less than 2 inches as seen in the picture. I looked at BoltOnHooks, they have a 5/16 hook which I would think would do fine and a large plate that could be used with it. Both are about 2.25 inches which is larger than the flat area where it could be mounted. So it would overhang some. I also can't say how the weld might work. The plate could overhang both the front and the back and a bead put down from the underside on each.
KBH Tender Trailer (A56438)
KBH Tender Trailer...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2011 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A59904)
2011 INTERNATIONAL...
Aerway Tillage Tool (A59814)
Aerway Tillage...
BOMAG BW213 SMOOTH DRUM ROLLER (A58214)
BOMAG BW213 SMOOTH...
2004 GMC Sierra 3500 Pickup Truck (A55973)
2004 GMC Sierra...
