GPS Discussion Group
/ GPS Discussion Group
Derek,
I did download the Expert Version and do like it. It does give me everything I pretty much want. AS far as the state map it never asked me that so until I do some more digging into it I am not sure if I got any map at all or how to open any of them. I probably will run my thrity days out before I get back to it.
I am also looking at some of the maps that Garmin makes and they also will give me what I want. I spend $60.00 for Expert or $110.00 for the Garmin Map that I think would give me more than 'Expert????
Got any suggestions I would appreciate it.
murph
/ GPS Discussion Group #22
I'm at work now, I don't have ExpertGPS in front of me. I have never used the garmin software. When I looked at the software about 4 years ago I felt it was to expensive and did as much as the Delorme 3D topoquads that I purchased at that time. If you are just uploading and dowloading waypoints, routes and tracks the ExpertGPS is the better way to go. They are the USGS maps. Plus with ExpertGPS you can look at aerial photos with your waypoints, routes or trackes loaded on to them, just like the topomaps. I think it is a neat feature but not a needed feature. Also with ExpertGPS you can down load maps for all 50 states. You can also (might be for a small fee) down load something like 1.6 million waypoints (points of interest for all 50 states) along with a description of the points. Again a neat feature but not a need feature. Just my thoughts.
One thing you may consider if you do a lot of work with tracks rather than routes is get a GPS with memory. I know my Magellan Meridian Platinum can use removable media card up to 128MB. So you can track a section of road or trail and save the track to the card. That way you can build a log of you tracks you need and not have to deal with the extra track information or the dead reconing, turn off a GPS unit in one place and turning it on in another.
Hope this helps and does /forums/images/graemlins/confused.gif
Derek,
I have a Garmin Etrex Vista. I mostly use it for 4 wheelin up north which is mostly woods. You can lost pretty easy. One feature I liked with one of the programs that I was trying was the fact that I could draw lines on where I was over an aerial view. As far as extra memory I am not so sure I would need that as I think I have 24 meg built in already. I looked into an extra memory chip and could not find one for my GPS. However, I can run for three days in the woods with my wheeler and still only use of about 40% of my track log. With the mud and all we don't get too far in a days time. If lucky we get 20 miles a day.
I still am wondering about how to open the state that you were talking about?
murph
Rowski,
I did some more research on the ExpertGPS and made some maps. To save the map as a .jpg file you can not do. You have to do a "Print Screen" and then paste it in a photo editor of some kind. Attached is three maps I made of a 4 wheelin trip. All three maps are of the same area and trip. One map is from ExpertGPS and two are from USAPhotomaps.
First one is ExpertGPS, I had to scrunch them all down to get under the 150 limit here but you can see what I did.
murph
pic 2 is from worldmaphotos
tis picture is the same as the last one but only zoomed in. You can see where I actually drove over the same trail a couple of times.
These are aerial views from world maps. The blue line is actually the trail I drove on. You can take the lines off and see the roads leading back into the trails that I went on. It is pretty accurate as the line gets put right on the roads.
murph
I had to downsize the maps to get under the 100k limit. The first map using ExpertGPS allows me to name the waypoints. That is what is in the white boxes.
World maps only will display the waypoints when you scroll over with your mouse. Otherwise it only shows a green dot that is very tough to see. Shrinking the file made the green dots not noticeable.
I think I will purchase the ExpertGPS. I still wonder about opening the states though. I can't find how to do that or if you can download them to your GPS.
Murph
/ GPS Discussion Group #28
Opening the state is done when you download. I just mentioned incase you used your Gps out of your home state. In other words the Minnesota maps are the only map you can veiw till you pay then you can veiw all 50 states.
I haven't tried printing yet, but the way you explained it make sense.
</font><font color="blue" class="small">( One feature I liked with one of the programs that I was trying was the fact that I could draw lines on where I was over an aerial view. )</font>
I'm not sure what you mean. You can draw "lines" in ExpertGps. As far as I have found you can't draw free hand but if you make the "legs" when you draw it looks almost like free hand. Once you have drawn a "route" say over your track you can save the route. Then when the time comes you can upload the route as a track or a route to your GPS. Hope that made sense /forums/images/graemlins/confused.gif. Not sure if you found the online manual for ExpertGPS. But it explains the tools fairly well.
I'm still on my trial period too. I will purchase it too. Seem like a nice bang for the buck. I hope to play with ExpertGPS a lot in the next week or so before spring chores start. I won't have to much time then.
Derek,
I guess what I mean with the lines is I can overlay my tracks on the aerial view. I didn't mean to confuse you. As far as the state, when I did my download it never ask me a state or anything it just downloaded the exe file and that was it. Did I downlaod or install wrong??
murph
/ GPS Discussion Group #30
murph
Maybe I downloaded or installed something wrong /forums/images/graemlins/frown.gif. Hope the program works out for you. If you run into something give me a shout and I'll do the same.
Looks like there is a lot of water around where you go 4 wheel'n.
Best of luck
Derek,
Actually there is a lot of water where I go wheelin, but the dark spots you see on the maps is groves of Pines in amongst birch and other trees. There really is no lakes other than beaver ponds.
Try this link. http://www.upnorthadventure.com/
You can mess around that web page to get an idea of the area. It is private land but tree harvestors do go in there.
When there click on Wheelin, then in the middle of the page you will see "some favorites" Thats me in the middle of the hole.
murph
/ GPS Discussion Group #32
Hayden,
Sorry to respond so late, just saw this thread today. Blame it on High traffic.
Check out Map Tech They have products for PC's Pocket PC's & Palm pilots. Looks like the PC version of Terrain Navigator may do what you want. Not sure about the Palm version. You can download a free demo.
The proffesional version of terrain navigator Pro Navigator will definitely do it, but it is $299
Good luck
Derek,
Spent a lot of time messing with ExpertGPS this week-end and I think it is the program for me. I like all aspects except for you can't save the map to a file (.jpg). You can print screen and then paste it in a picture editor but you loose a lot of quality.
The other thing I don't like is I have a whole mess of waypoints in a 2 mile squared area and the waypoints on the map overlap each other so you can't see the one under the top one.
Other than that it is pretty flexible and easy to use. Well worth the money I believe. Will probably get it next week or so.
Now I just have to clean up all the other programs on my computer that I have tried in the last month.
murph
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A68183)
2023 Caterpillar...
2018 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A66736)
2018 Chevrolet...
SHORTWOOD 5 BOLTSTER LOG TRAILER (A64276)
SHORTWOOD 5...
CAT 963 4-in-1 Bucket (A68134)
CAT 963 4-in-1...
2011 FORD CROWN VICTORIA POLICE CAR (A66091)
2011 FORD CROWN...
