Gotta new barn, getting ready to learn some welding, which welder should I pop for?!?
   / Gotta new barn, getting ready to learn some welding, which welder should I pop for?!? #21
It seemed the 100%argon makes for better penetration and runs a hotter weld.
I'm surprised to hear that. I don't weld MIG, but I thought I had heard that CO2, being a more reactive gas, was way hotter than Ar.
   / Gotta new barn, getting ready to learn some welding, which welder should I pop for?!? #22
I have never ran 100%CO2 so I cant compare.
   / Gotta new barn, getting ready to learn some welding, which welder should I pop for?!? #23
With 100% CO2 you will get a touch more splatter, but a hotter puddle, plus it is cheaper than a mix.
Using 100% argon for Mig welding steel is really not recommended, for aluminum yes. It will keep you more in a globular transfer. Add a little CO2 to get into short arc, C-25,(75% argon with 25% CO2) is a good all around mix for short arc. Add more volts, and a little oxygen to the argon mix to get into spray transfer.
I played with some C-10 to see what spray arc transfer was all about. Some people use C-5, or 98% argon with 2% oxygen for spray transfer.
   / Gotta new barn, getting ready to learn some welding, which welder should I pop for?!? #24
i use 100% co2
2008 Ford Escape XLS SUV (A59231)
2008 Ford Escape...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
2017 Ram 1500 Pickup Truck, V6, 4X4, Automatic Transmission, 212,570 Miles (A56438)
2017 Ram 1500...
2006 Trail King RGN 45ft. 60 Ton Quad Axle Heavy Haul Lowboy Equipment Trailer (A60460)
2006 Trail King...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
