Got to try a toolcat... pretty cool!
/ Got to try a toolcat... pretty cool! #1
MessickFarmEqu
Super Member
Lancaster County, PA
I gotta say, I was impreseed. It drove really nicely. I like the F/R shuttle. It was an AWS and really turned tight. Build quality seemed good, I liked the controls. I was really disappointed in the strength of the loader, it did not seem to have the capacity that it should. Defentialy not somthing for daily dirt work, but I can see that it has a place.
/ Got to try a toolcat... pretty cool! #2
Was it the lift capacity you didn't like? It is rated for 1500# but will lift 2000# to full height. The lift has a different arc compared to a CUT or SS and more circular in pattern. FEL and SS is more vertical or larger radius arc. The shorter circular arc is less than optimal for dirt work. As it lifts, there is a lot of forward swing which makes dirt work more difficult because the lift arm wants to dig and lift against too much resistance. As with most machines, it is a compromise in some aspects. Even my bobcat S300 has some issues in hard digging and it has over 8500# in weight and much more lift. I am interested in buying one, but may try installing a slightly larger lift cylinder-if I can find the right length, stroke and pin diameters. I would like to have a 2250-2500 lb lift capacity. Based on prior measurements I took, there should be room for a 1/2" larger cylinder for the boom. I would like to be able to use it on my 36" tree spade but need a little more lift capacity for bigger trees. The 7' lift height is a little marginal for some tasks.
/ Got to try a toolcat... pretty cool! #3
I am not sure what the market is for these machines but I would think a 3000 pound lift capacity would be ideal. Then you can use it on jobsites (either construction or landscape). I know with construction it would be a great machine in that it can handle small task like a telehandler and fill the role of a UTV at the same time. With landscaping it could lift pallets of sod (not sure how heavy they can get), landscaping stone/block and other palleted items.
I would love to own a Toolcat but I can't justify the cost as it is basically a supersized UTV with a price 3-6 times that of other UTV's:(
/ Got to try a toolcat... pretty cool! #4
The toolcat is much more than a UTV. They really are a compromise machine. Not as fast or smooth riding as most UTV's, can't lift as high or turn as sharp as a SS, doesn't have a 3 pt like a CUT, and can't haul/tow as much or go as fast as a pickup or technically street legal. However, they can turn in a 17' diameter circle, tow 4000#, lift 2000#, can travel 18mph, are gentle on grass/turf, can haul 2000# in hydraulic dump bed, can utilize 40 attachments, has independant suspension for smoother ride and soon will have rear 3pt and pto.
They can do a lot of tasks but overall not great at any one job with maybe the exception of snow removal. However, they are much cheaper than a SS, UTV, CUT or PU together. It's multitask ability is what intrigues me. List price on base toolcat is around 32K and can have street price of 27-28K. A loaded Bobcat S300 SS will sell for about the same as a loaded Toolcat. Kubota RTV 900 for 11K. Kubota RTV 1100 for 16K. Polaris ranger XP 10-11K. Pickup for 30-50K.
/ Got to try a toolcat... pretty cool! #5
radman1,
You really did a nice job of capsulating toolcat's contribution. I like the fact that it is a brave departure from the accepted format, and has a seat for a friend.
jmf
/ Got to try a toolcat... pretty cool! #6
Plus it is excellent on lawns using 6' finish mower with great visibility and control in tight spots~minimal tire scufffing. Easier to get in and out of than tractor and has extra seat to carry your dog or helper. I hope the next revision will have 4 wheel lock and idle option similar to Kubota excavators to save fuel.
/ Got to try a toolcat... pretty cool! #7
I still think they are a supersized UTV.
Yes they can accept some of the Bobcat attachments but like any do all machine the Toolcat isn't great at any. It is a Utility vehicle with more features then a standard UTV. Bobcat even list it in the same category as their smaller UTV (the 2000 series).
Referring to it as a UTV is not an insult.
/ Got to try a toolcat... pretty cool! #8
Bear in mind a Toolcat only weighs around 5000 lbs. My 2003 model only weighs around 4500. It will pick up and move round bales of hay with the rear tires bouncing off the ground. The lift is sized appropriately if not slightly too strong when you consider the size of the unit. Pallets of sod are usually 2000 lbs. The Toolcat is rated for 2000 lbs to 4 feet (lift the pallet off a flatbed and lower it for transport).
The value of the Toolcat for me is the versatility and comfort. If you want to clear trees out of a fence line throw your saws and other tools in the back and put a grapple on the front. If you want to build fence load supplies and attachments on a trailer, put hand tools in the dump bed and two people can head out to build fence.
If they were priced more reasonable I think you would see a lot more of them around.
dsb
/ Got to try a toolcat... pretty cool! #9
I didn't interpret it as an insult and I agree with you on many points. Heck, I don't even have one - yet. I kind of view its UTV use as its more minor function for how I would be using one. It is kind of like comparing it to a Leatherman tool. It has a knife, wire cutter, pliers, screwdriver, corkscrew or whatever. The leatherman is very handy but usually not a good as a dedicated tool for a specific function.
I think it gets stuck in the utility category because of the dump box feature.
/ Got to try a toolcat... pretty cool! #10
I think it gets stuck in the utility category because it is a true Utility vehicle, more so then the average UTV. Just like a letherman is a utilty tool so is the Toolcat. It can do a lot of things and as dsb said, if it was more reasonably priced there would be a lot more of them.
If you can get the Toolcat for $22-$25k then I feel a lot of people would pay the extra for it given the added utility features.
/ Got to try a toolcat... pretty cool! #11
You are right. They are just too expensive to become widespread. My local bobcat dealer has only sold a few. He only orders them when needed. He said if they were 25-30K with cab and a/c, he could sell lots of them. A large frame SS will sell for a little less than the toolcat. My other dealer 50 miles away sells quite a few toolcats. Some of the difference has to be due to marketing and sales dept.
/ Got to try a toolcat... pretty cool! #12
I thought long and hard before I decided on the ASV SR80 rather than the Toolcat. I had some serious land clearing to do besides maintenance. It wasn't so much the short comings of the TC as it was any option with tires. My property contains many steep slopes and plenty of thorns. I knew either machine could not handle the large trees (I plan on renting an excavator), but the SR80 was better equipped to handle the drainage work and debris removal. I also had a Polaris Ranger and a Ford 4000 and wanted to keep them for snow plowing, mowing and finish grading. When finances allow, I see the SR80 and TC a good compliment.
jmf
Is it rated for that much? I never really looked it up, but I'm rather shocked. I went into a dirt pile with a 60" low profile skid loader bucket and had to backout to lift it out of the pile. I would have guess'ed it at more like 800lbs or so.
I guess what impressed me most was how nice it drove.
/ Got to try a toolcat... pretty cool! #14
i lift 2500lbs with my fork out of the back of my 3500 dump truck without any major issues - 63 bags of 40lb salt on a wood pallet. i have about 400lbs of counterweight in the back.
ts
/ Got to try a toolcat... pretty cool! #15
Like I stated earlier, the forward swing of the lift arc is different then SS or FEL. The forward swing makes it want to dig more. Just isn't possible. Need to back up slight when lift. Same as with FEL but more noticeable with toolcat.
/ Got to try a toolcat... pretty cool! #16
I guess I never tried that. I always enter the pile flat then lift and curl to fill the bucket, same way I do with a rubber tired end loader. If I'm not careful on mine I over fill it and gravel/dirt spills over the bucket onto the pivot points. Not a good thing on the 'A' series as the material gets pinched when the attachment is fully curled.
A while back I had four loads of gravel delivered for a barnyard project. I cored out the area off the cement then built it back up with gravel. Also built up the inside and around the outside of the cattle shed. Having done that project with a SS and a FEL I would say the Toolcat is faster than the FEL but slower than the SS.
dsb
/ Got to try a toolcat... pretty cool! #17
I had a 800 series bobcat and a case 580 loader w/backhoe before I bought my toolcat The toolcat is more useful around the house and faster to get my jobs done and its a lot easier on the grass. They are not for every job but nothing is, they are a good multi-task piece of equipment. A little expensive for what I do but makes my life easier and that worth it.
/ Got to try a toolcat... pretty cool! #18
Having now had some experience with a tractor, you can't overstate the control you have on the FEL with the increased visibility of the Toolcat. You just cant' do any kind of delicate work with an FEL on a tractor.
The FEL is rated at 1,500 lbs at full height, but like others have said, it's designed to lift a pallet of sod off of a truck bed. I've lifted a one ton pallet of fertilizer without any problem. I like that I can do some heavy lifting without worrying about attaching counter weight on back. I can lift very little with the tractor unless I have a heavy implement mounted on the 3-PT hitch.
2021 TORO TRAILER (A65643)
2021 TORO TRAILER...
1999 Dorsey 45' Aluminum Citrus Trailer (A64127)
1999 Dorsey 45'...
72in. Fine High Side Skeleton Skid Steer Bucket (A65640)
72in. Fine High...
2022 John Deere 6R 155 (A64126)
2022 John Deere 6R...
Case 90XT Skidsteer Loader (A66285)
Case 90XT...
Skid Steer Blank U-Plate (A65640)
Skid Steer Blank...
