got my pto-generator today.
/ got my pto-generator today. #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
My 13kw/12kw surge/rated pto gen came in freight today. I've read the manual, and unpacked it. Friday I plan on mounting it on a skid on my carryall, and hooking it up and powering it up to test it.
here's a pic from their website.
Soundguy
/ got my pto-generator today. #2
Nice looking generator. What did that set you back? Can I assume you run it at the normal 540 PTO speed.
Curt
/ got my pto-generator today. #3
I'll be very interested to see how it's mounted. That is not obvious from the picture.
Cliff
/ got my pto-generator today. #4
Please let us know how it works. I have been thinking of buying one for sometime now. Thanks,
Logan
/ got my pto-generator today. #5
Chris, I guess you couldn't get it before Frances came through. How did the hurricane effect you there? I have two tons of limbs and cones all over the place.
One large limb hit the roof, but only the bushy part and the heavier end drug it on down to the ground, no damage.
I got pretty lucky in my opinion as I was sure the wind was going to push over a wateroak right at the end of my house. The pines around me are all 80-100 ft tall, and many of them are within stiking distance of my house. I'm relieved for the time being, but Ivan may be causing us more pain soon.
The power just came back on a couple of hours ago. Did without for better part of 5 days.
I hope you faired well also. John
It lists for 1100$.. but I got mine for 999$ ( sale? )
If I would have ordered it right after charlie i would have had it for frances.. but I waited too long. Come sin truck freight.. 1 week or 2 weeks depending on shipping options.
It comes stapled to a shipping pallet, to which you can then bolt it down to ,with a handfull of small hardware from the hardware store.
There is also an optional mounting kit you can buy that gives it large flanges with multiple hole sin it to give you a variety of mounting options.. like to mount it to a concrete slab.. etc.
I'm pretty sure mines going to be mounted on that pallet, and then bolted ontop my 3pt carrier.
We got minor hurricane damage... no power for a few days.. lost a chicken, and a 10x16 section of my pole barn collapsed ( on top of my ford 8n )..
I'm buying the correct power plug today so i can hook up my well if power goes out again. Well, and fridge are my main concerns. I can do without hot water an a/c.
Soundguy
/ got my pto-generator today. #7
This generator was on ebay. I thought that it seemed like a good deal for $1250. It included the trailer and the shaft for that price.
/ got my pto-generator today. #8
Soundguy,
Going to check frequency/Voltage and such with an O scope for us ? I have been wondering how well they worked and am not familiar with the brushless ones. Are they supposed to be more stable or just less maintenance ?
Sorry to hear about the Tractor, will it recover ?
</font><font color="blue" class="small">( Going to check frequency/Voltage and such with an O scope for us )</font>
You bet! I've already got my vom / scope out and ready. I'll power that baby up on friday and hit it with a variety of loads and watch the sine wave.
</font><font color="blue" class="small">( not familiar with the brushless ones. Are they supposed to be more stable or just less maintenance )</font>
Primarily the brushless ones are less maintenance ( no maintenance ).. but without brushes.. there should be a side benefit of less emi/rfi noise. as you might find comming off the armature of a genny with brushes. Should be a true-er sine wave as well.
Soundguy
/ got my pto-generator today. #11
What are you going to use for the electrical gear to hook the power from the genny into your house?
/ got my pto-generator today. #12
"I'm buying the correct power plug today so i can hook up my well if power goes out again. Well, and fridge are my main concerns. I can do without hot water an a/c."
I've been looking at PTO generator too.. couldn't you almost run your whole house on that size of generator?
When I had my electric meter moved.. I wanted a setup to connect a generator.. the electrician put in a 200amp fuse box between the meter and the house's breaker box.. and said it could be switched out w/ a transfer switch.
The younger electrician said (for a temp solution) you could turn off the house's main 200amp switch.. and then run the generator's power through the dryer's plug into the house.
Sorry to hear about the damage.. Ivan is on it's way.. let us know how it works.. take care & be safe!!
Edited: The news this morning: Grenada flattened, 15 die.. Florida Keys already ordered to be evacuated. Good luck SoundGuy!
/ got my pto-generator today. #13
I have a 2 cyl diesel Onan generator that is rated at 12Kw. I have used a heavy (000 gauge) wire and backfed my house through my welder outlet after throwing the main breaker off. It ran everything fine until one of my A/C units tried to kick on. Oops! The 'ole generator belched a bit of black smoke and shut off.
Two things about my experience. First; be VERY careful if you use an existing heavy outlet to feed the house. Your jumper cable between the generator and house will have to be male on both ends to plug in. A live male connection is not safe. It would be very easy to get yourself fried that way. Second; make sure you turn your A/C units off. In general, you need a minimum of 25Kw to consider using them.
That having been said, I've been looking at 25Kw PTO generators. Unfortunately they seem rather spendy for me. /forums/images/graemlins/crazy.gif Good luck Soundman. Hopefully Ivan will not pay you a visit.
/ got my pto-generator today. #14
If you are going to backfeed your house for an emergency then you need to remember that if you do not disconnect your house from the utility company you can backfeed electricity back into the overhead lines. The danger of this is that a lineman will be working with a line that he thinks is not 'live' and he gets injured or worse.
For a whole bunch of reasons (easier load balancing, forgetting that the automatic sprinklers are wired into the house, the furnace comes on and loads the circuit too much, etc) it is just better to plug your load directly into your generator.
A generator disconnect switch removes the concern of backfeeding the utility. (This was pointed out already in this thread but I am saying it again here.) /forums/images/graemlins/grin.gif
ps... ground your generator (it shows how in the manual) and be darn careful when you mess with the generator (filling it up, plugging stuff in etc) because you are usually standing in wet mud that conducts electricity and is slick to stand on! /forums/images/graemlins/shocked.gif
/ got my pto-generator today. #15
</font><font color="blue" class="small">( Two things about my experience. First; be VERY careful if you use an existing heavy outlet to feed the house. Your jumper cable between the generator and house will have to be male on both ends to plug in. A live male connection is not safe. It would be very easy to get yourself fried that way. Second; make sure you turn your A/C units off. In general, you need a minimum of 25Kw to consider using them. )</font>
I'm wondering what this does for protection of circuits? If it's powered on the back side the breakers wouldn't still operate the same in a short would they? I don't get electrical very well, help me out. John
/ got my pto-generator today. #16
Dum and dangerous. We had a guy do exactly this, he was back feeding and knocked a Mass electric co. worker off the pole!! For one, you have to pull your own meter when you back feed through a dryer plus so you don't hurt other people,, For two, how much of the house do you think you really repower? We have a on/off genset throw switch right next to the meter,, At least when I hook up my genset, I know, no one will get hurt and I'm not backfeeding through sockets such as a dryer plug..
/ got my pto-generator today. #17
Wait please tell me why I have to pull the meter. If the main is off then both sides of my panel is dead so assuming I am not stupid and turn the main back on if I run from my 220 plug on my gen and put one hot to one side and the other hot to the other side then the house works fine. With the main off how would I feed power but up the lines and hurt a power guy. I have never had a problem doing this but I do put tape over the main and label it something like " unhook gen before removing tape incause someone comes along and tries to "help me out"
/ got my pto-generator today. #18
Not only is it dangerous if you do not have a way to disconnect from your power source, but illegal. If you electrocute a utility worker, you are liable. I would assume that in most all states a home owner is not "legally" able to send electricity through municipal power lines, for just that reason. Not only do you take a chance of going to jail, there would be a real possibility of having your generator explode when power is restored.
In the instance I mentioned earlier, I clearly mentioned it was dangerous due to the method needed to attach to the house. However, with the main breaker sitting on the shelf next to the breaker box, it would not be possible to back feed the utility lines.
Your safe choices are to snake a dozen or so heavy duty extension cords into your house to power what you need to power, or spend $1500 - $3000 or so to have your house professionally wired with a genset switch. The switch will allow you to plug your generator into the house and select what circuts you wish to power.
/ got my pto-generator today. #19
Wiring a transfer switch is fairly simple to do & doesn't have to cost much if you do it yourself. I did mine & I'm glad to have it. I looked at Home Depot's made in china units & decided to get mine at CED (made in USA). Cost for the switch, exterior outlet & wire were about the same. Directions for installation were pretty clear & made sense. Calculating the loads on each circuit was easy as well. I'd recommend getting it done.
/ got my pto-generator today. #20
It's not illegal to run power back into the grid - that's what net-metering is all about, and a good number of people do it with their solar systems. You have to have the right equipment, though, and the utility company has to know all about it.
For a generator, definitely use a transfer switch. They're incredibly easy to install, and they give you the ability to balance the load across the circuits you want to power. Good ones will have a power meter on them so that you know how much power you're using so that you don't overload your generator. You should be able to install a nice setup yourself for under $500.
2001 Ford Explorer Sport SUV (A61569)
2001 Ford Explorer...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
(INOP) 1988 MANITOU R522-4TC TELESCOPIC FORKLIFT (A62130)
(INOP) 1988...
UNUSED WOLVERINE TD-13-36R STUMP DIGGER (A62131)
UNUSED WOLVERINE...
UNUSED KJ 12'X20' SINGLE GARAGE METAL SHED (A62131)
UNUSED KJ 12'X20'...
2020 Deere 544L (A60462)
2020 Deere 544L...
