Got asked to bid a very unusual project
   / Got asked to bid a very unusual project #131
Maybe it’s just me but I don’t think the log jam in the river will be that tough once you start on it.
Are you sure one of those long reach excavators won’t reach it? I just looked up the specs and some are 70 feet or a little more. They aren’t common but I see them around here, I think mainly for clearing out ponds.
Not sure I’d want to be perched on a river bank with a dipperstick extended 60-70 feet (if such a machine exists) over a body of water.
One false move and you and the machine are going for a crazy dangerous and expensive swim.
   / Got asked to bid a very unusual project #133
They exist, they look like a regular tracked machine although on the larger size. I do notice they have a smaller bucket on them and the boom seems like a thinner profile. Just Google “long reach excavator “ and you’ll see what I’m talking about. I’m sure it takes a lot more care just because the boom is so long.
   / Got asked to bid a very unusual project #134
So, it's Not your problem, or your scope of work; but I think the log jam is only 30% of any flooding issue. I think the sand bar might be the route cause. Now, did a log jam catch sediment and lead to the sand bar? Maybe. Will removing the logs allow natural scour to remove the sand bar? Maybe. Would I be caught excavating a sandbar next to a bridge structure? He'll no, I wouldn't dig that sand bar out, using Your license/insurance/equipment :)
None of that is related to your scope, and I'm not intending it too be. All I'm saying, is, it's hard to tell a symptom from a cause...
A good stable boat, some safety ropes, and a pole saw will do a lot of work. I Do think it's a min 2 man job though; and not being able to see the bottom 75% of the perverbial iceberg, I would be hesitant to throw a lump sum bid at this job, unless it was Well padded, or had a provision for unforseen circumstances.
   / Got asked to bid a very unusual project #135
The long boom excavator does not have much capacity due to extreme reach. Mostly used for grading and demolition.
   / Got asked to bid a very unusual project #136
Typically the debris will catch on the pier and
then sand will be trapped in the debris field
I’ll leave it up to the water engineers.
They went to college for this stuff, so they must know everything.
I could just see rolling a “long reach” excavator into a beautiful, historic river in front of a bunch of museum visitors. Minimum of water contamination from diesel fuel & oil, and destroying a rented machine, or worst case, drowning in the cab submerged underwater.
Reach is very far and the logs are heavy & waterlogged.
No thanks.
   / Got asked to bid a very unusual project #139
I get the general idea of why they want this done. My opinion is they think the log jamb is causing flooding but I’m betting it’s not. I think no matter what you do some is going downstream.
It was going down straem when it got hung up there.
Weber CR5 Reversible Plate Compactor (A56857)
Weber CR5...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2012 Ford F-250...
2013 TYTAL CRUDE TRAILER (A58214)
2013 TYTAL CRUDE...
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
2015 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2015 DRAGON 130...
