Got an oddball new attachment
/ Got an oddball new attachment #21
I wouldn't fret about it. I've double posted b-4. No one said anything about it. If the mods don't like it , I'm sure they would delete 1 of them
I read the forum guidelines, when I signed up and after this thread. I didn't read anything prohibiting making a thread where there is a link to another thread. I also know there are "unwritten rules" many times, too.
I don't see how this was a double posting at it's origin, how I had a mental breakdown, or where I had a strong attitude. That also doesn't mean I wasn't that way, either. No matter what, I wasn't trying to cause drama or strife in public, and I apologize to those who had to read my unsuccessful attempts at understanding how I erred. I appreciate all the supportive comments. Thanks.:thumbsup:
/ Got an oddball new attachment #23
International, no need to apologize, Willl is not a mod to my knowledge and if this post was not liked by the mods it would be removed as we all well know.
/ Got an oddball new attachment #25
284 post it 10 more times if you want to you just may find the right person that knows all about that piece of machinery and will help you.
It doesn't take much skill or intelligence to be a wise guy on the internet dime a dozen but to communicate well that takes the skill and intelligence. my .02
I have used this implement a little bit now, and am starting to get a feel for what it will do and be useful for doing. I've never seen another one, but in case somebody else finds one they can at least have another frame of reference for things.
I thought this implement was relatively light, at first. It is not. I put on the back of the 186D, and this is at the limit of what the machine will do. Accurately, it is too heavy, but if careful, it is doable. The 3 point relief valve squeals if opened rapidly. I was surprised the 186 wouldn't lift it easily, to be honest. It will lift my tube-frame 5 1/2 foot disk harrow that weighs, I guesstimate, about 600 lbs, without squealing. Fortunately, the implement usually rolls, so the tractor doesn't need to carry or lift the weight much.
The power requirements are minimal. My 186 has always felt a bit underpowered, but is sufficiently strong to power the cultivator under all conditions I have found. The cutting heads take minimal power, even when chewing through weeds in very hard packed soil. (Hard enough that a full size pickup doesn't leave tire tracks of any kind)
The cutting depth seems optimal at about 1 inch below grade. Much deeper and the cutting heads hurl clumps all over the place, and carve a trench two feet widen isn't really useful. Shallower, and uneven contours in the soil mean not all the weeds are scraped out.
The implement works very well on clumped weeds, and on weeds which have branched, shallow roots. It is ineffective on Bermuda grass, discouragingly, since that is a primary invasive species I want to control. Other grasses are poorly handled, too.
I have discovered where it excels: restoring untended baseball or softball diamonds. It is a marvel in the clay/brick dust mixture. It makes other field renovators look like pitiful toys. Pigweed and even Bermuda grasses in clumps ARE uprooted in the hard pack, and it leaves exactly the right consistency of material behind to finish drag for a sharp, professional appearance.
Otherwise, everything works as intended. The auto retract system is surprisingly gentle, though I wouldn't use it on trees less than several years old, mostly for the bark toughness to build up. The back and forth shuttling tosses the tractor around a little bit, but is not rough, so long as the implement is lowered fully. It is really a drawbar type implement with the ability to lift with the three point. Trying to run the implement when not fully lowered really batters the mechanism and tractor.
I'm still not sure if I can get what I want from it, but it is really cool to watch in action. I'm probably going to try replacing the cutting teeth with small cultivator sweeps to see if it will slice grass sufficiently to be useful.
/ Got an oddball new attachment #27
Cool gadget there, btw who is Willl? Haven't seen much of this guy on yanmar section.
A guy that speaks before he thinks......... ------Its the Internet.
2001 VIBROMAX W1106PD ROLLER (A66091)
2001 VIBROMAX...
2001 JOHN DEERE 310SG BACKHOE (A63276)
2001 JOHN DEERE...
2008 JOHN DEERE 544J SUPER TRACTION WHEEL LOADER (A65053)
2008 JOHN DEERE...
2007 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2007 INTERNATIONAL...
PALLET OF STAINLESS STEEL FEEDERS & WATERERS (A64278)
PALLET OF...
2003 PETERBILT 379 SLEEPER (A59914)
2003 PETERBILT 379...
