Gooseneck trailer jacks
/ Gooseneck trailer jacks #1
brokenhornmw
rio rancho NM
20 tym t494
/ Gooseneck trailer jacks #2
They make 12v Gooseneck trailer jacks to replace the hand crank ones. I think they even make hybrid ones that you can use either. I saw some a while ago, but can't seem to find them now.
I'm not sure the motor you posted would have enough strength to crank the jack. It only produces 6 ft-lbs of torque. Alot more effort than that is put into cranking that jack.
Do a search for 12v gooseneck trailer jacks (or "landing gear" as it is sometimes called).
Yeah I have seen them I dont want to replace the existing landing Jack's. Need to find an add on to replace crank handle to help load/unload trailer
/ Gooseneck trailer jacks #4
What I would do, is to find a socket that will fit over the the shaft that the handle on the jack fits into, then drill holes in the socket to match the holes in the shaft and put a bolt through it. Then put an adapter and hook it up to an 18 volt battery-operated drill. That will be the simplest and cheapest way to run your jacks up and down.
Aaron Z
sounds good but I am not sure that will work. These are the landing Jack's of the gooseneck. I know I have done that with RV stabilizing Jack's though
/ Gooseneck trailer jacks #8
First thing I would do is find out how much torque is required to move it at the most burdened spot in it's travel and go from there. That's easy enough to do, and I'm sure you'll find it requires far more than the 6 ft.lb. item linked.
/ Gooseneck trailer jacks #10
I've used a cordless drill to power the landing gear on my 5th. wheel for years. I just welded a large nut on the shaft where the crank goes. It's also at least twice as fast as factory powered landing gear. Make sure to have a suitable wrench available in case the drill quits.
/ Gooseneck trailer jacks #12
Is that on a 2 speed jack, single or dual? Trailer loaded or unloaded? You just pulled the handle off and welded a nut there? Isnt it just a round shaft with a ~ 1/4 hole? Hmmm, my horse trailer has hydraulic jacks but the dump and equipment don’t....This maybe a simple enough mod to keep a drill motor in the truck with an adapter.
/ Gooseneck trailer jacks #13
It's a 25ft fifth wheel and it doesn't seem to matter about loaded or not. It's the standard hand operated landing gear, the same as most trailers, only one speed. The hand crank has an off-set of about a foot from the main shaft. I would expect it to work on any hand crank.
/ Gooseneck trailer jacks #14
You took the hand crank off and welded a nut to the straight shaft, right?
/ Gooseneck trailer jacks #16
Yes, the hand crank comes off (it's not permanently attached like the one in the picture) and I welded a nut on the end of the shaft. I can post a picture if anyone wants it, but I'm out all day tomorrow and quite busy until Sunday. The landing gear is slightly different than the picture as it's a 5th wheel RV. I haven't bothered doing the same thing on my equipment trailer as I don't use it very often and don't find the hand crank a hassle.
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2022 EZ-GO ELITE...
2017 Ford Escape 4WD SUV (A61574)
2017 Ford Escape...
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
2007 Cadillac DTS Sedan (A61574)
2007 Cadillac DTS...
