gooseneck conversion
/ gooseneck conversion #1
hernando
tennessee
dk 4510 kioti and a 450 case track loader
anyone ever convert a bumper pull equipment trailer to a gooseneck..i have a 20 ft.. that i want to convert...i have alot of 6 " chanel .. i was told that it would not be strong enough for the gooseneck ...any thoughts ??? thanks
/ gooseneck conversion #2
Another consideration is that the axles on a bumper pull and gooseneck are placed at different points under the trailer. A gooseneck's axles tend to be farther towards the back of the trailer to give more tongue weight. A typical bumper pull has 10% tongue weight and a gooseneck has 15-20%.
Chris
/ gooseneck conversion #3
I think I would take a look at factory goosenecks on a dealer lot somewhere to see what size steel they use. I think they use bigger material.
Also sounds like a lot of heavy work.
/ gooseneck conversion #4
Why on earth would you want a 20ft deck gooseneck.. anyhow.. the 30 footer i have sure has a lot of heavy iron in the gooseneck area..
its all 10 inch by 5 inch I beam.. my 2305 cant budge the front of the trailer..
/ gooseneck conversion #5
Another thing to keep in mind.. there is a big difference in how strong a true c channel is or a c channel that was bent into a c. anything bent to make a c i would NOT use in the hitch building part of your project.
/ gooseneck conversion #6
I do not know if this will help but i have a 20 ft goose neck 7 ton it has 8" c channel and i have seen longer trailers in the same weight class with 10" c channel if you are going to covert one you need to be sure you add all the bracing. I think you can buy some plans for a goose neck trailer you should be able to adapt them to your needs.
/ gooseneck conversion #7
I believe wroughtn_harv just did a conversion. You may want to PM him and he might post some pics.
3147 (A63117)
3147 (A63117)
Bucket (A64194)
Bucket (A64194)
(1) Small Livestock Feeder Gate (A66408)
(1) Small...
Cherry Picker (A65640)
Wolverine Quick Attach Hydro Slide Pallet Forks (A66408)
Wolverine Quick...
1992 Fontaine Trailer 44ft (A62679)
1992 Fontaine...
