Goodyear xtra trac tire ?
/ Goodyear xtra trac tire ? #1
Vtktm
Vermont
Has anyone used the xtra trac tire. I have a new b2320 with r4's and may put these on. Have clay in area's on my lawn. Will be used in the winter with my fel for snow .
/ Goodyear xtra trac tire ? #2
I have Goodyear xtra trac tires on the rear of my B2100. I love them, they don't tear the yard up like bar tires. They are good in moderate mud. I also plow three steep driveways in the winter. I would recommend them over regular turf tires.
UnclePaul, thanks for the input on the tires, I assume you are using chains on the rear?.
/ Goodyear xtra trac tire ? #4
No, I don't use chains. I do, however, have a lot of rear ballast. I have a 5' rear blade with a 100 pound lead weight mounted on it. Plus a Buyer's salt spreader mounted off the back of the blade.(Which I fill before leaving to go plow.) Normally that is more than enough traction. The only time I have had problems is a few times we got rain before it turned to snow. Then it would have been nice to have chains.
2024 14ft Pairboat Flat Bottom Mud Boat (A64557)
2024 14ft Pairboat...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
2009 Ford E-350 Cargo Van (A64556)
2009 Ford E-350...
2015 Ford Transit 250 Cargo Van (A64556)
2015 Ford Transit...
2008 Case CX240B Hydraulic Excavator (A64194)
2008 Case CX240B...
