Good morning!!!!
   / Good morning!!!! #216,501
Good morning. We had a blizzard warning all day yesterday, moderate snow and the winds whipped up to 50+ mph. The snow mostly blew past me (I have not checked the drive yet) and the snow fence blew down (note - don't use zip ties). 7 degrees today, but had been in the 40's over Christmas.
   / Good morning!!!! #216,502
Arly, not to worry, you have plenty of snow for all of us ;)
but I'd sure rather have snow than this ice.
perhaps there is some positive karma at work
I ordered one 25 pound bag of icemelt from Amazon because they had two day delivery
and were competitive to hardware store, who of course was sold out.
Two heavy packages at the door.
drag them inside, they are identical, open one up.
yup, 25 pound bag of ice melt.
So they sent me two by mistake.
checked my order.
nope, only one ordered
went through return process, explained I had an extra
bag. Contact company was the reply.
I don't think so. They sure aren't going to pay freight on that to send it back.
usually they come back with some message basically saying keep it.
so since I'm rich in ice melt, going to throw a little down on the driveway
   / Good morning!!!! #216,503
up to 50 deg, been warming all morning. Wind starting to crank up now.
last wind broke the top clasp on my flag, and the end of flag was caught in the dogwood limbs that have grown around the flagpole. Couldn't pull the flag down with the lanyard, so i got 2 sections of pvc pipe to make a 20 ft pole and was finally able to push the flag off the limbs and got it down.
started all tractors in the barn. Had massey on the charger, it started right up. swapped the ZT and put it in front of the Ranger for the winter. Had to put air in BX front tire as it always goes flat. Recorded all the year end hours on them, doubt if i'll use them in the next 2 days.
fixed broken cord on my other Battery Tender. Dad had busted the cord several years ago, when he used FEL to move my old Husqvarna riding mower at the farm when I had the charger hooked up on it. It appears to still work.
BB was keeping me company, now he is in the house playing.
   / Good morning!!!! #216,504
Picked up groceries and forgot the appointment for Cody is actually tomorrow.
Helped wife with kitchen clean up and decalcified the coffeemaker after running 100 cycles through it
Need to move some firewood around to get ready for colder weather
Just in case learning how to operate a Scania heavy haul truck running in the arctic with the 770 hp engine. Looks easy enough
   / Good morning!!!! #216,505
22F with snow starting to come down and the winds just howling @ 12:30, with gusts over 50 mph possible.
High temp hit 62.5F last night ... quite the plunge in less than 12 hours time.
Wind started howling late last night, was hearing trees crack and snap and then hit the ground after I got in bed last night around 04:30.
Productive day yesterday.
Fired off the wood burner first thing and disposed of all the crap that was in it - good suckage and no apparent leaks ... (y)
Got the second set of shelving that was emptied the previous day moved out of the way.
Then started unloading the next set of shelves.
Got that all done and then moved those shelves out of the way, creating around 8' of clear space on the the north end of west wall.
Then started working on vacuuming the west wall.
Got the insulation in between 4 joists on top of the sill plate all pulled down and the cavities all vacuumed.
Woman came down to assist around that time and started moving stuff off the next set of shelves onto the now empty set that I had done earlier. She got that all done as well as moving some items out of the utility room into the family/rec room. Then did a bunch of vacuuming before She called it quits.
I unscrewed the straps from the clothes washer drain pipe and found there was enough flex in the pipe that I should be able to get a 1" thick piece of polyiso foam board behind it o the west wall. Replaced the screw on the middle strap with a longer one and blocked the pipe out with a scrap piece of 2 x 4.
Further down that line, near where it connects to the clean out, there is a break in the pipe with Fernco coupling on it. I should be able to trim off about an inch of the pipe ... which will allow me to move the pipe enough to piece in the last 16" wide section of polyiso that goes on the north wall.
Got the 8' section of the bottom of the west wall wire brushed and then scrubbed down with water and a scrub brush to remove the efflorescence.
Removed 3/4 plywood panel I had put up previously for the 200A fused disconnect switch for the electric service out to the barn:
Switch was never hooked up or mounted, it can be mounted on the stud wall once it's up.
Final task before knocking off was relocating/reorienting the gas valve.
Turned off the furnace and water heater around midnight just as the temps were starting to drop and then shut off the main valve.
Removed the valve (and plug) for the feed out to garage and reworked that so the valve was on a vertical leg. Even using "close" nipples it overshot the bottom of the floor joists (too high) Was short a couple of 90's and a close nipple to bring it back down flush with the bottom of the joists but I was able to get the valve reinstalled and all the new joints checked for leaks. Now I can just turn the valve off and install the 90's once I have them and extend the line.
Turned gas and furnace back on after that and re-lit the pilot on the water heater and made sure everything was operating normally. Then called it a day.
On the agenda for today:
Put out food and fresh (warm) water for the feral kitty.
Add insulation to cavities between floor joists that were cleaned out yesterday.
Add some more wire staples to the wires that are tacked to the sill plate on the west wall so they aren't hanging down.
Get at least one polyiso panel glued up, placed, and braced, maybe two ... if I can get the washer drain line trimmed.
Empty debris bin on whole house vacuum and get that cleaned out.
Bring another bag of trash up to go in the cans tonight.
Get the remaining four 2 x 4's by the front door hauled downstairs.
Probably start hanging the 3/4 copper hot water supply line (full temp) for the clothes washer and dishwasher.
See if I can't clear an area to build the next section of stud wall.
Beyond that just see what else comes up.
Temp now down to 21F and ground starting to turn white, winds still just howling.
Hope everyone is having a decent day ... (y)
   / Good morning!!!! #216,506
nasty weather RS , guess you'll be sending it East
dumped 25 pounds of ice melt on driveway, hope that will do the trick this afternoon.
Sun is trying to peek out. That's what we really need to melt the ice.
and then I went to open the second box of ice melt to put the inner bag away and
I won't repeat what I called myself, repeatedly, when I sliced right through the inner ice melt
bag. That just means it will go bad faster and/or I'll spill it; am already transferring to a smaller
hand shaker. Sticky stuff. Truly a lame maneuver.
   / Good morning!!!! #216,507
That looks like the way it’s headed …
Glad I really don’t have to go out in it … although I might sneak out there later and fill the hopper and suet feeders … maybe throw some salt down on the entryway while I’m at it.
   / Good morning!!!! #216,508
Good Afternoon!
Wow after all the talk of snow and ice I almost hate to say it's only in the mid-high 40's here and no snow or ice, or even rain. Light winds make it feel colder. Humidity has dissipated some.
It's been an interesting morning. Several projects going on and always some changes mid-stream.
We may have a tenant moving early next year. Going to see him later today to see what his plans are. A neighbor has asked about renting a vacant lot we have for parking cars occasionally. Not really sure I want to do it. Might be more trouble than it's worth.
Hope everyone stays warm, dry, well fed and healthy! Prayers for our Nation!
   / Good morning!!!! #216,509
34F cloudy 15F daybreak tomorrow morning refreeze no doubt.
Well the day didn't go as I plan,postive Mrs. safe house warm didn't lose power...yet.
Should have put pickup end if driveway :cautious: couple thrills getting pickup down the driveway this morning :oops: driveway sheet of ice tree limbs hanging low,heard several pine trees snapping in the woods,going to be lot spring clean up.:(
Crush stone company was close today :unsure: try again tomorrow get couple loads grit for the driveway,if no luck again hire contractor sand....OUCH.
Plans for the evening next to nothing.
Enjoy your evening all.
   / Good morning!!!! #216,512
Good (Tuesday) morning. Overnight Low of 13C and it's presently 25.1C, partly cloudy & fairly calm.
Yesterday's town trip was successful. First a local contractor came to look at a job at the Church's roof (circa 1884, extreme pitch/angle); a 'cherry picker'/bucket lift is needed = yup, he can do it mid January. (y) Next was a stop at the PO to see if there was any mail = no, but a woman with a bub-in-arm, needed help to her car with her packages and I was just the man for the job. (y)
Lastly it was over to the hardware store for the spare hose connections... O.K., I did also buy a 10metre garden hose 'extension', but that was IT. (y)
I don't know what I'll get up to today. Some jobs are beginning to accumulate, like limb trimming, but I did notice that I've got a nice crop growing in my eaves throughs which will require a fair bit of ladder work to do. <sigh> Oh, well.
   / Good morning!!!! #216,513
TxDon - hope the BIL keeps healing well, good to hear some improvements.
His wife.just sent a video of his first steps with a walker since the accident. About 3 steps then he had to sit down and rest. He does have a long hard recovery/physical therapy journey ahead.
   / Good morning!!!! #216,514
I'm glad that you were able to be a Johnny on the spot when needed. 👍👍
FWIW: I use an extension for my leaf blower, like this one;
It keeps me off a ladder, and I find it is actually pretty quick once you get the hang of it.
All the best,
Peter
   / Good morning!!!! #216,515
I didn't do a thing today. Watched the snow come down. A couple of inches on top of the 1/8" of ice yesterday evening. A couple more inches tonight. May be plowing tomorrow.
The slab cab Scania looks interesting, but not a truck I would want to drive. He certainly IS set up for heavy haul.
   / Good morning!!!! #216,516
His future sounds more promising every day! PTL!
   / Good morning!!!! #216,517
Good evening all. 17ºF in St Ann, MO, overcast, windy. Wind slowed down through the day, Sky cleared off and clouded up again as I drove south and high temp for day in TX was 42ºF. Made coffee to start day, drove back to Texas, unpacked, did load of laundry, Worked on posting.
resuming
Buppies sorry to hear about power issues. Glad to hear A1C good.praying for you and Holly.
Friend(trac) a belated Happy Birthday.
Frits sorry wife scalded her hand, prayers for quick recovery.
prayer for all, especially Jay/Peg, Kyle /Daughter, /mom's breathing, /son's migraines, Mike /BIL in FL, Ron /heart, David(moss) /remodel, /divorce, Buppies /cancer, parathyroid, blood sugar /wife, Thomas /gout, Phil /reflux, Frits /veteran son with mental issues, /granddaughter with Evans Syndrome, Ken /chronic fatigue, Diet not working, Randy(wag) /sister stoke, Scott(vt) /wife's back pain, Don, / BIL motorcycle accident, Steppenwolfe /son-auto immune disorder, Grev /wife's eye, Ted /knee recovery, /retirement & disability red tape, /family issues, /wife back issues and cancer, Lou /eye issues, /heart issues, /wife hip replacement, Doug and wife/health issues, / hand nerve and surgery, /fall and recovery, / wife headaches and heart eval, / David(sadamo)/Sophie's hip or leg pain, Eye recovery, /back issue, Scaredy/shoulder dislocation, /marriage dissolving, / friend stop drinking, Dennis /neighbor issues, /brother's lymphoma, /dad surgery recovery, Drew /back operation issues, /friend's wife cancer diagnosis and recovery, Scotty /back pain, Helogabals /wife's friend situation, Fatjay /father broken hip, Ukraine war, and Country.
   / Good morning!!!! #216,518
Drinking first cup of hot coffee. 19° with snow showers this morning. Heading to 23° with cloudy skies. Wind sure did blow yesterday. Lots of limbs have fallen. Wind blew the snow into drifts. Enough so I need to get snow shovel and tractor out to clear areas that are up to 1' deep. Then back into house where it is warm.
Everyone who visit my feeders like peanuts.
Everyone stay well and safe.
Good Morning All.
   / Good morning!!!! #216,519
good morning all
and the wind is still roaring when I got up; 16-19mph steady with big gusts
28 out now, not going up much today; basically cold for entire next week
decided to bring out the undershirts and stay warmer
need to do a little food shopping this morning and I bet some stick pickup
dinner tonight at a friend's in Doylestown; need to pick up a soft red blend to take with me.
hope you all have a great day.
   / Good morning!!!! #216,520
if you know anyone in Denmark, you can no longer mail them a letter.
Denmark just retired its postal system, saying snail mail was outdated and no longer needed.
Whole country is highly digital and connected.
Shipping boxes of course still works.
I wonder if it's handwriting on the wall
Zero Turn Mower (A59231)
Zero Turn Mower...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A60432)
UNUSED RAYTREE...
2022 Dodge Ram 4500 Miller 8,000lbs Wrecker Tow Truck (A59230)
2022 Dodge Ram...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
