Good morning!!!!
/ Good morning!!!! #154,921
Day has suddenly shifted focus. As per my routine, walked out to the Tractorshed to read my solar electric numbers. I keep a daily log of production/use of previous 24 hours.
As I walked out back I see this fountain of fine water spray at the doorway. A quick mental check and the only hose hooked up didn’t even have a nozzle, hence would not be under pressure. As I got closer I could be the spray coming from the pump itself. Apparently there is a small diameter poly tube that sprung a leak. Pulled the power to pump and cut the flow from the tank, ending the fountain.
Contemplating how to repair as I enjoy my coffee. Luckily the pot well was full
/ Good morning!!!! #154,922
when I moved to NC I knew absolutely no one in the area. My wife had died, I was fairly messed up emotionally, and
I had orchards to plant. Which I did and the world got back on its axis. But what I didn't have that whole time was my "old friends"
which I see I refer to. My three guy friends from high school and one from simply long ago here, met at Meeting.
Reaffirms to me how much I missed my old friends by moving way far away from them.
I'm lucky that I get to go back to a small town that is still fairly small. Other than completely unaffordable housing, it has everything I want.
So I rent this little cottage and dream of tractors.
that's ok to do, isn't it?...
I think of David and Sophie and others who have moved pretty far away.
Very different than retiring to Florida where some of your old friends likely wound up.
So David has built, and continues to build, his own paradise. Thank goodness for Zoom. Really.
Being able to see my sister smile at me from California is a delight.
Great perspective, Drew.
And some I have thought about from time to time.
I guess in many ways we are what we grew up. As a kid we moved fairly often, especially when my Dad worked construction. Mom put her foot down after my freshman year in HS and they relocated to 110 acres just 10 miles up the road. But again, a new place, new school, new church, etc but also a complete break with all the old. By the time I finished HS I was still considered an out of towner. I’ve pretty much continued the pattern over the year, just longer intervals. Sophie’s childhood wasn’t so different growing up a military brat. Sometimes it is amazing that the 17 years we’ve been here is the longest either of us has lived anywhere in our lives. No plans to move either. But I guess if there is a downside, neither of us have those longterm friends like grace your live. I don’t think it’s something we try to do on purpose, just kinda happens. Precovid we were pretty active, knew and interacted with a fair number of people we think of friends. Guess a sign of these modern times, but many on here, that I’ve never met in person I consider a friend.
/ Good morning!!!! #154,923
first pass done, had to come in, 92 and sunny, just sweating too much.
At least this afternoon I can work in the shade.
Battery died in Gravely and friend put in a used Red Top. Promptly died on me after click click click.
I put it on a charger on agm setting and it got to green, but the battery dies quickly. I'm going to leave it on my
5amp smart charger overnight, see if that rescues the battery. It sits there for months on end not getting used.
Am pretty much figuring on a trip to TSC for a new battery tomorrow.
once I cool off will head back out to take plate off top of gearshift area, which exposes all the levers you can't normally get to.
I'll be hosing that down with oil later. Got a lot of black gunk off; wondering where it comes from, basically a new engine.
Now the old Kohler was an oily beast, but new Vanguard shouldn't pump out oil nearby. Now it's clean so we can keep an eye on it.
when I powerwashed the cloth seat,made of some sunbrella like material, very durable, I had to laugh because years ago I had washed the seat and I guess
I got too much detergent in it. When I hosed it down today, it foamed up all over. Looked almost like new when it dried.
front hitch worked like a dream
/ Good morning!!!! #154,924
Buckeye, is it a 3600 rpm or 1800 rpm generator?
3600 rpm
Generac model 7210 air cooled
200A transfer switch
They said at least 300 gal propane tank for 2-3 days depending on load. I really don’t want a huge tank in my back yard. Really don’t like generator there either.
generators direct can ship it Friday for $5757
/ Good morning!!!! #154,925
Took the weed burner for an hour walk.... I have to admit, a lot easier and more effective than the string trimmer. Granted, I can only use it in the gravel and walkway areas, won't risk starting a brush fire.
I have been monitoring the propane use (just by weight of the 20 lb tank) and hasn't gotten too much lighter. I believe that it is another good tool in the arsenal.
Supposedly, the burner will also eliminate any seeds, so I will pay attention to how long it takes them to grow back. The perennial weeds might take a few 'treatments' before being eliminated, but that's ok.
When you hit them, even briefly, you can watch them literally wilt over!
I'm sure you guys know all about these.....
Never used one, but probably should in my driveway.
/ Good morning!!!! #154,926
Yes. I’ve met a couple TBN people and it was like meeting an old friend.
I only had 2-3 close HS friends from growing up (living on a farm we didn’t get out much), and they moved away also. Most of my friendships have developed from church, and we know people all over the US because of it.
I went to church In Maui once and knew the first person we met in the parking lot. He had visited his friend at our church in MD once.
I went to church in Germany once, and a member (former US Air Force who married a German) invited me to stay a weekend at his house near the Danube river.
When we went to Alaska to visit my best friend from HS, people from church there let us stay at their house.
Friends of ours used to be snowbirds in Phoenix AZ, they invited us for a week and drove us to Grand Canyon and around.
Last week we visited old friends in TN. They said we could have stayed with them if we would have said something. I didn’t want to impose, but did invite them to stay with us if they visit MD again. We have friends in AR we have stayed with.
/ Good morning!!!! #154,927
gen direct been around a long time, seems reputable.
Buckeye, the whole thing is ugly and noisy. The built ins a bit less... Having solar power and batteries/inverters sounds very nice, and quiet too.
wonder what the animals think when all the gens fire up throughout the neighborhood.
Those noisy humans.
you can put small shrubs in front of the tank, small evergreens you can run a power cord to
and have xmas lights there. (spent a lot of time hiding my 1000 gal tank in back yard, as plants in front of it slowly grew.)
now I'm an insurance guy, so the bigger the tank, the bigger your insurance policy. More days of running.
But if you get a big tank, I'd put a lock on it. People steal just about anything in the dead of night.
Or....since you already have diesel there, get a diesel unit. I'd guess ten grand more.
Or...get a Winco 25kw for the back of your larger Kubota and drive it up to house and plug it in. Plug like I have now, only 50 amps but I guess you could have two.
50 amps does an awful lot in an emergency. That 24kw generac I think puts out a full 100 amps, maybe a little more.
If you can live without central a/c this is pretty simple. If you have an all electric house like I had in NC with three hvac systems then it's not simple and downright
expensive for all the add on modules. That 400 amp panel with load shedding modules is held very dear by generac.
too bad they don't make them run on firewood. Hmmm. Steam boiler, little turbine, generator, batteries, inverter. ??
/ Good morning!!!! #154,928
RNG, I got a chuckle seeing the heads in the dishwasher, you obviously don’t share your kitchen like I do.
Drew, Gravely looks awesome, I would go to warehouse battery in Quakertown rather than TSC though. Better, fresher batteries and generally cheaper.
I was born in Manhattan, lived on Long Island until I was 6, then moved to Berks County, PA until I was 10, then to Bucks County, PA until finally moving to property that I’m on now in the 70’s. My kids all grew up here, the oldest one lives in the original farmhouse in front of me. I am fortunate to have a lot of old friends going back to grade school, as well as many others along the way.
To me, they are the greatest wealth that I have acquired. When I was seriously injured in an accident in 2019 it was humbling to see people coming out of the woodwork to help, especially since I’ve always considered myself to be a bit of a curmudgeon that doesn’t suffer fools well. But nonetheless they came to visit, help, feed us, and just generally do whatever they could to help. My self assessment can’t be too far off, this shirt showed up anonymously-
When I got home from today’s trip, my wife was walking up the lane, which was great to see.
Buckeye, I’ve got a Generac 22kw that I installed myself, none of it was particularly difficult, if you get an electrician to wire it for you, and the gas company to set the tank and run the line and set the regulator, all you will have to do is level a spot and either pour a pad or set a prefab plastic or concrete one to place it on.
/ Good morning!!!! #154,930
The tube from pump body to pressure switch aged out - brittle and cracked just under the switch. 4mm tubing. I have 1/4” available, then remembered an old pump taken out of service. A length of that tube as a temp fix. Had to make a temp clamp from a twist of copper wire. Sl
Till have a slight drip but serviceable until I get to town. This is a HD/ Everbilt pump so hopefully they have appropriate parts.
Back to regular program.
/ Good morning!!!! #154,931
3600 rpm
I could never justify a whole house generator here in Texas. Even during the worst hurricanes in Houston power was never out for more than a few days. I just pretend I'm camping. If it looks like there may be an outage event that will last a week I don't see a problem. I do have a small Yamaha gasoline generator to charge the phones for several hours a day. Batch cooking before, water, Ice - good to go.
/ Good morning!!!! #154,933
Alien, great video. Like those fake wrestling shows where they throw the other guy out of the ring.
two more hours in the gunk but got it mostly cleaned off, and oiled where needed. JD has some nice spray oil with
teflon in it. So all those dirty controls are now cleaned and well oiled. Ready for another five years or so then the cover has to come off and this
job repeated. I'll resume again tomorrow afternoon. Battery is shot, went tick tick and barely started. I'll tighten the connections again, but they felt good.
new drill bits for metal came in. US made, so sharp almost nicked my finger.
No more using the wrong bits.
/ Good morning!!!! #154,934
those drill bits are in Ken's honor. That poor guy spent an hour in the hot sun trying to drill with those impossibly dull drill bits I gave him for the trailer job.
He was a real trooper and didn't give up. After I had.
Popgadget had a marvelous eyebrow raise when I handed him my broken drill bits and it was clear they should never have gone into hardened steel.
And it was also clear he could not put humpty dumpty back together again.
there are lots of wood bits that look only like wood bits like spade or forstner. Then there are wood bits that look like metal bits. I am now very familiar with them.
when the going gets tough, better bring the right drill bits.
/ Good morning!!!! #154,935
LS, sorry your knee is such a pain. Hope it gets better before too long.
Buppies, hope you and the wife are feeling better.
Don, 2 words...Tires, Costco.
Wag, looking forward to your tale.
RNG, I like your new "dishes"...also hope you got those hummingbird feeders cleaned up and refilled...ours are almost in a frenzy this time of year.
Hope that Sophie has a safe return home.
Yesterday drove to Virginia Beach to pick up my mom and take her to two out of town cemeteries, the farm, her favorite country store, etc. We had 6+ hours together and we really had fun. Did a BEF driving day...445 miles...just wish they'd get that new Hampton Roads bridge-tunnel finished.
Today, took it easy...washed the truck before sunrise, and then worked on the leaking plumbing on my 3 pt spray tank/boom. Watched a movie with my wife. It felt like August outside again.
/ Good morning!!!! #154,936
75F partly cloudy.
Thought for sure it be short day at work...no so,after an hour rest decided to mow the front field notice the grass starting to slow up growing. :)
Time to head for the deck with popsicle wait for little critters...Boo already here. :)
Enjoy your evening.
/ Good morning!!!! #154,937
/ Good morning!!!! #154,938
/ Good morning!!!! #154,939
Good Morning Everyone,
another busy day in town, sold eggs, bought chicken feed, then coffee with a friend. when i got home i fed the chickens and rabbits, and then i heard some peeping in the incubator ... so far 1 more little yellow chick, probably noticed within 1 hr of hatching
daugen - i love the Ventrac, and that Gravely is classic. good thing you were present to Babysit that company and crew, sounds hectic
BEF - i almost want to build a slope in order to really justify the purchase of a Ventrac
popgadget - praying that your wife's the back surgery went well today
RNG - a streetlamp maybe ?
/ Good morning!!!! #154,940
One of my closest uncles passed away 2 nights ago. I was sending condolences to my cousins, and my one cousin responded that they (cousin, her husband, and another cousin) were driving from Alberta to Vancouver area BC ... i asked if they were coming through the Salmon Arm area enroute. She said yes they were.
Long and short, I met them for coffee for about an hour this afternoon. I gave them 6 condolence cards, a wooden toy "garage" that my uncle made for each of four of us cousins (50 years ago), and a few diecasts. They thought that was awesome. We had a good visit, and they carried on for the final 6 hours of the drive. It was nice to catch up. I told them that it was unlikely that I'd be able to get to the service though. They have a lot on their plates at the moment.
now back to my regular day
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
TANK MANIFOLD (A58214)
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
14ft Flatbed Truck Body (A59228)
14ft Flatbed Truck...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
Honda UTV (A56859)
Honda UTV (A56859)
