Good morning!!!!
   / Good morning!!!! #120,761
No worries Kyle.:laughing: I've learned my lesson about trusting people, and should have done the van work myself. Even if I had to do some of it over again in the learning process, it would have been done correctly and in less time.
The last power outage ended at 12:27 PM yesterday, as logged by the solar power control computer. Didn't run the generator except for the normal Friday exercise period, all done automatically. I do find myself scheduling activities that need a lot of electrical power for the peak sun hours of the day; it's a use it or lose it situation with solar once the battery bank is fully charged. Doesn't always work out, especially when it's hot and I need to run the A/C overnight. When I was off the grid during the fires earlier this year, I did use the generator to keep the battery bank charged, but only put four hours on the generator during that time. During a two day outage last year about this time, the little Honda generator ran 25 hours keeping the 'fridge cold and running the TV and lights at night. Now the battery bank takes care of those loads easily, and no messing around with gasoline and patch cords. So far the solar power system is the best purchase I've made in 2020!:thumbsup:
Good to hear your system is doing well, hope the techs can tweak it to the rest of your expectations.
Good morning. It's 53° with a 12 mph north wind here and our high will be only about 69°.
When the front came thru, late yesterday afternoon, the temperature dropped from 83° to 61° in about 20 minutes. Winds were gusting to about 30 mph.
We finalized our deal, to replace our sold Polaris XP700, yesterday and brought home our new PR XP 1000 Crew "Texas Edition".
The difference between it and our 13 year old PR is amazing. It's way more powerful, much quieter, with great seats. I took it out, after dark, last evening and the LED headlights are really bright.
I went online and ordered a set of rear view mirrors for it.
I was going to put our 15 gallon 12 volt sprayer in the bed and finish spraying perimeter fence lines but .. that will wait until the wind goes down.
Bought a cargo bed mat for it, to keep things from sliding around so .. will need to take it down to the shop, remove the cargo tie downs in the corners of the bed, put in bed mat, then install cargo tie downs thru the mat. I rarely used the cargo tie downs in our previous Ranger .. so I might not even re-install them for now. That would make cleaning out BP the bed much easier if the mat could be quickly removed?
Hope everyone has a great start to your weekend.
Prayers to all.
That thing looks great, I hope it serves you well. I'd be interested to hear how well the suspension works. No dump bed?
It did cool down quick. I took a my daughter and a friend to the football game last night....sitting on aluminum bleachers with a stiff cold breeze...had us all chilled to the bone. Out of the wind, it felt great.
It'll only make right turns...…..can't go left.
Now that, was funny....thanks for the guffaw laugh.
Yes, I see that! Some of the prices are scary...
   / Good morning!!!! #120,762
Roy, that cab looks well laid out.
Congrats on your license Drew, safe trip today.
More mindblowing pics, 🤙🤙🤙🤙🤙
Glad to hear bleeding is under control, Randy
Rip, I’m in same class, not much of a welder. Keep saying I’m going to practice but never get to it.
Nice looking Polaris, Rick.
   / Good morning!!!! #120,763
Ted, I suspect they could, but I’ve taken steps along the way.
The whole container sits under a carport type roof.
The only direct sun exposure is the side getting the main door and window. That is morning only and mostly protected by the lanai cover I put up previously. I think the T111 will help as well. It will be painted Balcony Rose same as house. I am using a cellulose foam board insulation inside under the sheetrock.
I’m hoping the 2 6 ft doors and the windows each end give sufficient air movement.
Our temp extremes are 58-82, but mostly high 60’s to 70’s.
I’m hoping it will be fine.
   / Good morning!!!! #120,764
RNG, no current plans for the 36x80 piece removed yesterday. Tucked away for future.
The larger 72x80 piece coming out today I have delusions of possibly rebuilding deck of my rotary cutter. Of course that would entail improving my non existent plasma and welding skills.
Always glad to read how well your system is performing, especially low generator use.
   / Good morning!!!! #120,765
Nice mirrors Ted.
I wish my tractor seat lifted, I miss that especially when cleaning out debris. Someday I will figure out how to mod it.
   / Good morning!!!! #120,766
Rick, besides the logo on the seats what makes it a Texas edition?
Nice paint, 14" ground clearance, 29" Maxxis tires, 11" suspension travel, roof included, standard LED head lights ....
   / Good morning!!!! #120,767
46F and cloudy out @ 15:00, supposedly headed up to a high of 48F.
Late start ... went to bed early, had hard time falling asleep and finally was just about to drift off and the front came through ... which started the window shades rattling around in the wind ... which woke the cat up ... At that point I was awake ... so I stayed up until around 07:00 until I went back to bed.
Fedex dropped off the wet sandblaster kit a little bit ago, followed by Amazon delivering the hose-fed parts cleaning brush for the parts washer. They are supposed to deliver the replacement pump by 21:00. Also have some Rust-Oleum Wipe New on order to redo the plastic on the Kubota but that's not due in until Tuesday.
Did not get final cut done on grass ... but it has grown enough that I'll definitely hit it one more time before putting the mower away ... probably on one of the coming nice days when the high is supposed get close to 60F. Did get the MMM cleaned off though ... :thumbsup:
Today will be an inside day here at the house - will take inventory to see what I have in the way of leftovers and then cut the wood for a couple of roost boxes, a large sunflower seed feeder, and a nut feeder for the tree rats. Hopefully get some gluing/assembly done on those as well.
Need to get the furnace filter reinstalled, now that it's dried out.
Depressurize house water system and check charge on pressure tank.
Hope everyone has an enjoyable, productive, and safe day ... :thumbsup:
   / Good morning!!!! #120,768
It does have dump bed Kyle.
   / Good morning!!!! #120,769
David, at least you guys can weld. Every time I tried to learn how to weld, I got a massive headache from it. I leave the welding to the guys that don't get headaches from it.
   / Good morning!!!! #120,771
The quick hitch is on the 3PH, but the adjustable lift link (for leveling) won't rotate to adjust. I sprayed PB Blaster on it and hope it frees up.
PB Blaster did the trick!! Leveled the quick hitch...but since I've been drinking (mild buzz) and still watching an old Czech SF movie (Ikarie XB-1...better known as "Voyage to the End of the Universe" in 1963... Love these 60's SF movies!), I'll get back into it tomorrow morning.
Saturday is normally my day of kickin' back after a week of working...but sometimes I actually do something after the usual morning dump run...
Did spend some hours getting familiar with the tractor's controls and such...most is pretty intuitive. Did find out how nice the sound system is with a Chieftains CD (Chieftains is an Irish band...around for a long time...). I was surprised how good the sound is.
Tonight is supposed to drop to 32 degrees...think I'll plug the tractor in...with the extension cord I bought this morning.
Have a great rest of Saturday, Troops!!
   / Good morning!!!! #120,772
At this point it’s just a hole.
And I’m taking a lunch break.
Outdoor Circle was a bust. After waiting 2 hours in line only 3 varieties left, none we wanted.
   / Good morning!!!! #120,774
Nice to see what everyone does staying busy.
Top pop, hope arm heals fast. I’m on Eliquis also, so even a little scratch bleeds like crazy.
Good luck on the Steiner. Hope you get it picked up ok.
This morning I realized I was late paying 2 credit card bills. I could have scheduled them a couple weeks ago and didn’t, then forgot. Only a day late, but will surely get hit for interest, maybe a late fee. I went and paid the remaining balance.
Then went out to mow leaves again. More oaks leaves in back now. Mowed around house only.
Used backhoe to dig a snowball shrub out, got way too big. Planted small section back where it was, planted other 2 larger sections at edge of woods. Since I had tractor out, dug some small trees out where I took down the fence a couple months ago. The shrub puller chain didn’t work on them.
Grilled burgers for supper.
   / Good morning!!!! #120,775
I should not say that I can weld fit burn paint might get into trouble
   / Good morning!!!! #120,776
Beautiful place BEF
Nice UTV Rick
   / Good morning!!!! #120,777
Ran across this old photo of me at twelve, almost 13, standing on the edge of a spring on my aunt and uncle’s farm in Northern Alabama. Summer 1965.
   / Good morning!!!! #120,778
after 14 hour day, finally home. What a horrible drive down to VA, huge traffic jams and construction near DC, Route 66 heading West out of DC was a parking lot due to 20 miles of
road rewidening. I've never seen so many excavators working on one project. Can't even imagine what that whole thing will cost, but drive took 5 1/2 hours. Came back on Route 15 up to PA turnpike, what a marvelous difference and a pleasant drive. Almost ten hours of bouncing around in that Jeep was just too much for me.
I have a lot of unpacking to do tomorrow for sure.
Toppop, hope your arm gets better soon. Great pic, you haven't changed a bit! ;)
Rick, super nice UTV, hope it runs well for you.
Kyle, good luck with the Steiner, looks like a real find to me. Great project to work on.
Roy, glad your hitch works well now. Sounds like you have an impressive piece of machinery there.
The sirens of sleep are calling me...
   / Good morning!!!! #120,779
LS, ingenious air seat! Love it.
Drew, glad your home. Time to rest.
Oh how I would love to have a spring like that...handsome kid you were. :)
Sodamo, you deserve a break. Sorry about the waste of time.
I'm no welder. I weld "gorilla welds". Big, ugly and hopefully strong as heck. Cool videos on youtube by 6061.com showing how to make projects with aluminum. Some of the best videos on there, no lollygagging or hype. Just getting after it. But if you notice, his coordination of feeding the filler rod, is maybe the most important aspect of it all...IMO.
TIG Welding Aluminum Fabrication - Making a small fuel cell (gas tank) - 661.com - YouTube
Thinking about it, the Steiner 230 could possibly be a gasoline engine....It looks like all the dash panels on the parts website seem to have a hole for the glow plug idiot light, and they all have similar intake filters....time will tell. I need a come-along winch to get it up the ramp onto my trailer. I guess I might look at HF.
Don was right! I trimmed back my tomato plants in my garden, and started watering the poor decrepit wilty things, and now I have about 15-20 silver dollar sized green tomatoes. Hope it doesn't freeze. They have a lot more blooms too. I believe I read somewhere where our first annual freeze is usually early December down here.
   / Good morning!!!! #120,780
Good evening all. 41F for the start, strip of clouds in the east, light north wind. Moderate wind today, Sky clouded up to mostly overcast the started to clear again, and high temp was 59F. Bike ride this morning, slower than normal because of cold. Did get nap in. No new gopher activity by me or gopher.
Covid update: Cooke 539 confirmed cases, 22 active cases, Montague 270 confirmed cases, 33 active cases, Grayson 2508 confirmed cases, 195 active cases.
David sounds like a lot of cutting
Bill lot less flooding with only .75 in of rain.
Roy good to hear re-audit went well, have fun learning new tractor.
Thomas drive by shootings?
Drew hope trip goes well.
Ron glad cellar door done, hope shopping goes well, nice view.
Buppies hope you can get your outside work done before rain.
Billy good luck with skunk(s). glad to hear Coco no find skunks either.
Chris sounds like plenty of work to do.
Randy glad Ellen's surgery went well, good to hear bleeding more under control, and good to hear you are not on ladder!
Don already close to stepdaughter, medical access is adequate at best. thanks for defog tip
Mike hope you get your mowing, sushi and ceiling work done. Glad you get to visit with family
Rich breakfast looks good. sorry about the leaking hoses
Rick nice ride!
Ted good to help neighbor, hope stove works for him. hope trailer work goes well
Kyle Good luck with tractor.
RNG hope your punch list gets shorter, sounds like you are enjoying the bike project, does sound like you will get a camping trip anytime soon.
Roy thanks for update.
RNG thanks for details on solar. Disgusting what some people will do.
Ted nice pics on the mirrors, great idea on the b-ball as a spring.
Kyle interesting looking beast.
David good luck with next cut
Rick nice list of extras
RS sorry about sleep issues does mess greatly with the next day.
Roy glad the PB blaster worked, looking forward to the blower hookup
Dennis other than the late payments sounds like a nice day with seat time.
Randy, nice hat
Kyle gas engine will have spark plugs. Good news on your tomatoes.
prayers for all especially Drew/move, Jay/Peg, Kyle's daughter, RNG/fire, and Country/election
stay safe and healthy you all.
2007 Ingersoll Rand G240 240kVA 3-Phase Towable Diesel Generator (A59228)
2007 Ingersoll...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
iDrive TDS-2010H...
2015 Ram 1500 Crew Cab Pickup Truck (A59230)
2015 Ram 1500 Crew...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
2015 CATERPILLAR 308E2 CR EXCAVATOR (A60429)
2015 CATERPILLAR...
