Good morning!!!!
/ Good morning!!!! #83,402
Good Morning!!!! 60F @ 5:30AM. Sunny. High 77F. Winds light and variable.
Best wishes for all those suffering under the weather, and about to suffer bad weather. And Eric, I hope that little lamb wises up before it's lamb chops.
Those little metal fingers on the Drill Doctor that set the rotational position of the drill are easily bent, and don't seem to work well at all on smaller drills, either. But the small drills are inexpensive, so I keep spares for the most used sizes, usually tap drills. I can still manage to sharpen the larger drills by eye.
The Oronids meteor shower was mostly a no show this morning, at least for the fifteen or so minutes of semi-comfort that the doubled over moving blanket gave from the hard concrete patio. Spotted two flashes, but only out of the corner of my eye. There also seemed to be much more light pollution coming from Oroville and Chico than I've seen in past years, as the Milky Way was barely visible.:(
She's a runner! Got the old BMW motorcycle to fire up on the second button push yesterday, but not without some surprises along the way. Before I put fuel in the tank, I cranked the engine to make sure it had oil pressure, and lets just say you need oil to get pressure. And that led to other checks and adding oil to other areas that need it, too. Didn't notice the degree wheel on the timing light had shifted, so that was another mystery to be solved. But the new ignition had the correct amount of ****** for once, and once the carbs were somewhat balanced, the engine idled and revved freely. The double handful of insulation scraps that blew out the exhaust have me wondering if there might be more trapped in there, though. :eek: This morning I'll re-torque the cylinder heads and adjust the valves, then see if I can figure out why one of the valve covers is leaking. It'll be time for a short ride after that:cool2:
Another Amazon Prime Sunday delivery brought the OBDII reader for the iPhone, and it worked as advertised. It told me that the Check Engine Light was set by the lack of a Neutral Position Switch, and let me clear the error. I was then able to set up displays for both engine speed and RPM, and find that the tach on the dash is a little optimistic with respect to what the electronics are showing. Like a man with two watches, I suppose.:confused2: If there's time today, I'll connect the little switch on the clutch pedal to the Neutral Position Switch terminal on the Engine Control Unit, take the van for a drive, and see if that fixes the rev limiter problem. But that's a lot to ask for a Monday...
Hope everyone's week gets off to a great start!
/ Good morning!!!! #83,403
31 going to a high of 45F. Wind S 8 mph. 60% chance of showers.
Hard to believe it is only 3 degrees difference between Ontario Canada and my back porch in Arkansas. 34F this morning with the first frost of the season. It is supposed to warm up to low 60's later today. Hopefully we will have a long fall season and maybe I will get some motorcycle riding in this year. Last year spring was like one day and then summer hit with 90+ temps and the same thing with fall, one week and then the rains and cold set in. I didn't even take the bike out of the shop the whole year. At least this year I have had a few good rides in the spring and several with my Harley owning neighbor this fall. Bike is in the shop getting new brake pads on the rear and hopefully it will be out by mid-week and I can take advantage of the forecasted 5 days of mid 60's and sunny weather.
/ Good morning!!!! #83,405
It was 32° this morning, yesterday was another nice day in the mid 60's with a few clouds. Today is supposed to be the same with a slight chance of a rain shower.
I got some of the stuff loaded in the trailer yesterday. But I'm still finding things that needs fixed on it. The refrigerator works on gas but not on AC. No big deal I wasn't going to run it that way on the trip anyway. I'll see about getting that fixed next spring.
My wife is going down to SLC for a few days to visit the grandsons. I need to help her get her stuff together this morning. Then I'll see what else needs fixed on the trailer.
buckeyefarmer.. Happy Birthday.
Hope everyone has a nice day.
CWB.
/ Good morning!!!! #83,406
Buppies
After this things supposed to settle down some weather wise leading to milder conditions thru mid December if my crystal ball is correct. After that that big door might close and lots of snow and ice may be in store.
Like the sounds of the weather mid Dec,but after that please windex the crystal ball. ;)
/ Good morning!!!! #83,407
38°F and clear skies this morning, going up to 72° today.
Got the rest of the deck boards secured on the steps Saturday. When we installed them, we were racing incoming weather, and just threw in a couple of screws to keep them in place. The wind started getting almost unbearable while I was out there, even blowing screws off the deck. Once the dirt and debris from the field across the road started assaulting my eyes, I decided I'd had enough and called it a day. Piddled around inside for the rest of the day while The Wife was away running errands and taxiing the boy around. He had to go to Edwardsville in the morning to take another driving class, a mandated part of getting his license back in January.
We dropped unexpectedly below freezing Sunday morning. It was 28° when I got up. The hose we have running out to the chicken coop for water had frozen. As the sunshine warmed it later in the morning, it freed up with no bursts or cracks leaking anywhere. Dodged the bullet on that one.
Wife took the boy to meet one of his buddies to look at renting a two-bedroom house in Trenton. It's in an older part of town, but there's really no "bad" part of town. They liked it, and conversation disclosed that The Wife used to work with the landlord's cousin. He seemed to like the idea of renting to a couple of young guys who can mow the lawn for him. He's supposed to let them know today if they get it.
Happy Birthday, BEF.
Congrats on the Beemer running, RNG. That's got to be music to your ears.
We didn't ride at all this year, Gary, and only a couple of times last year. Just been too busy this year, and last year was definitely too hot.
/ Good morning!!!! #83,408
Good morning Gary.
Bought two more winning lottery tickets this morning.
got a bad batch on the last bunch...;)
TSC has RV antifreeze on sale for 2.50 a gallon, good price for -50 stuff. Time to winterize the orchard sprayer and few other pieces.
Then I'm going to spend some time rototilling the garden. 50 and sunny out.
/ Good morning!!!! #83,409
Busy weekend..
Decided to put snowblower back together Saturday morning (disassembled to fix leaking auger gearbox). I sanded the surfaces mostly smooth on the aluminum gearcase halves, put the permatex gasket maker on, etc. after a 1-2 hr break, I tightened the bolts and then proceeded to put it all together.. I was happy until I did a test run to see how it ran. Two things stood out, first, way too much movement (wonder if shaft is bent), but the biggest problem is the augers halves are on the wrong side.. LOL I need to take it apart again and swap them.
Daughter called and wanted me to bring car trailer to auction, she had bought a bunch of stuff, including a 30'x65'x15' shelter in a box (steel framed box about 10' long).. long line at auction pickup, tied down after dark, took it to their property and dropped trailer, tired and ready for bed. Got home and relaxed a few minutes before bed.
Sunday, we drove ~200 miles to celebrate one of the grandkids turning 3. Had a nice party, then turned around and drove home. Tahoe got 19.4mpg for trip.
Up early this morning for 6am meeting. 24F this morning, lots of catching up on TBN. Coffee tastes good.
/ Good morning!!!! #83,410
Gary Fowler, it IS hard to believe. 1300 miles between you and me by road almost due south west and only 3 degrees difference in temp.
/ Good morning!!!! #83,411
68°F and .12 inches rain. Currently drizzling.
Still hoping to mow.
Prayers for all
Be safe
Have a great day
/ Good morning!!!! #83,412
Good morning, thanks for the well wishes. Ellen is better, slight headache, was a migraine for sure, sensitivities to light, smells, etc... First one in over thirty years she says. I am not messing around, the next one lands her in the specialists office.
Going to hit Black Dig Salvage after breakfast and head to Gatlinburg if plans hold up.
Have a good day
Had to look up black dog... They are just across the tracks from where i took my geothermal installer course years ago.
Hope you make gatlinburg.
/ Good morning!!!! #83,413
Should have taken wngsprd's advice and stayed home today, but didnt.
Just had lunch at 2pm, planning on taking off a little early, going out to eat tonight.
Thanks for birthday wishes...
/ Good morning!!!! #83,414
For those thinking of a zero turn, consider what I call "Clint Eastwood, stay off my lawn!" version I saw on Facebook.
/ Good morning!!!! #83,415
Good morning ALL!!
My mom and sister flew to the Cherokee eastern reservation for a stay near the Tenn/N. Carolina border.
I’m in Gatlinburg now and will be going to Cherokee, NC about Wednesday for a day trip, haven’t been through the gap in about 16 years, tallest and steepest mountains in the east. Very steep rock walls and 800 foot plus drop offs. I love going down 441 and 19.
/ Good morning!!!! #83,416
Buppies and I were unable to get together due to both ladies being ill, but Randy and I had a great phone conversation this morning.
/ Good morning!!!! #83,417
lot of firepower, bet it would twirl like a teacup ride if that mini gun lit off. And whoever is sitting in that seat is awfully exposed.
Must be for those urban lawns when your neighbor's Humvee is always parking over the line...
lovely day outside, mowed and rototilled, got plenty dirty and a hot shower felt good.
My seed order for next Spring came in, will be fun to go through that. Helps to have seed packets with pictures on front to plan what goes where.
/ Good morning!!!! #83,418
28 this morning in Roanoke, 65 this afternoon in Gatlinburg, but evening brings a rapid cool down.
There are way too many people here for me! LOL
/ Good morning!!!! #83,419
Good evening to all! Temps went up to 65 today, clouds moved in around noon, couple of sprinkles on the way home this afternoon. Calling for showers tonight and tomorrow.
Well, made it through the class today with only one episode of nearly dosing off. :zzz::zzz:I was able to bring my attention level back up and made it through.
HAPPY BIRTHDAY BEF!
Drew, glad you got those last peppers! Too good to let them get mushy out in the cold. The island looks like it belongs there.
Hope everyone gets over their illnesses quickly and without any problems.
Toppop, sounds like the trip is going well. Make sure you get some pics going through the pass.
Kyle, sounds like your daughters are taking care of you pretty good... If they need more vehicles to vacuum.....
RNG, congrats on waking up the Beamer! So many projects....so little time...
Prayers out for all!
/ Good morning!!!! #83,420
2001 Subaru Outback AWD SUV (A59231)
2001 Subaru...
1998 MACK RD690S DUMP TRUCK (A60430)
1998 MACK RD690S...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
John Deere 5103 (A53317)
John Deere 5103...
Toro (A56857)
Toro (A56857)
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
