rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 13,229
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
I have a CountyLine unit from TSC that I use with our B2910 which I think is pretty much set up as you have described.... Kubota owners. Does anyone have trouble with their Kubota picking up a 3pt. post auger? Mines a MX5200 R4 tires. Lift maxes out and the tip is still dragging the ground. Lift arms are in the high setting. Auger is in lowest top link point and auger lift pins are in 1st hole.
It does clear the ground - at least when I'm level ground - but it's close.
No experience there ... but I can't see why one wouldn't.Also will third function valves run an auger or are they only for grapples? Only ever been around third function on skid steers.
