Good morning!!!!
   / Good morning!!!! #61,441
... Kubota owners. Does anyone have trouble with their Kubota picking up a 3pt. post auger? Mines a MX5200 R4 tires. Lift maxes out and the tip is still dragging the ground. Lift arms are in the high setting. Auger is in lowest top link point and auger lift pins are in 1st hole.
I have a CountyLine unit from TSC that I use with our B2910 which I think is pretty much set up as you have described.
It does clear the ground - at least when I'm level ground - but it's close.
Also will third function valves run an auger or are they only for grapples? Only ever been around third function on skid steers.
No experience there ... but I can't see why one wouldn't.
   / Good morning!!!! #61,442
Then I might do some welding inside the barn. At least it's in the shade and I have a fan.
If the breeze from that fan is too strong it will blow away the envelope of gas shielding the hot weld metal from oxidation due to oxygen in the atmosphere. Unfortunately, that can make the weldor almost as hot as the weld!:laughing:
   / Good morning!!!! #61,443
Just finished the three drawings, turned them into PDF's, and sent them along via the email. Done well before the "requested by" date even ... :rolleyes:
Sounds like you were wrestling with ClarisCAD. Apple got sued for infringing copyright and dropped support for it, what, ten years ago? Tried several substitutes, none of which worked as well or as easily, and ended up with ViaCAD. It's OK, and also offers solid modeling, but it's quirky and not nearly as intuitive. It also cost a lot more, but not nearly as much as one of the pro level packages...:rolleyes:
   / Good morning!!!! #61,444
You'll have to check pressure / flow requirements of auger and compare that to what pressure / flow your function has available.
   / Good morning!!!! #61,445
69°F and .56 inches rain. Sun shining
Be safe.
Have a great day
   / Good morning!!!! #61,446
Good Morning!!!! 79F and climbing fast @ 9:30AM. Plentiful sunshine. High 98F. Winds SSW at 5 to 10 mph.
A buddy came down from Redding early yesterday morning to get a pair of tires swapped out on his motorcycle, which gave me the incentive to get up early and do some cleanup in the garage so we'd have a place to work. No surprises with the tire swap, but with all the laughing and scratching we didn't finish up until noon and he was riding into the heat in the way home. I finished up the afternoon bead blasting the bad paint off the old bike's aircleaner cover. That paint may not have looked nice, but it sure took a lot more abrasive to get it off than what was on there originally.:rolleyes: Now if I can just get a cool enough day to get the new coat to flow out nice.
The big sheet of solar filter material I ordered showed up a few days ago, so instead of waiting until the last minute I'll see what needs to be done to mount some on the most recent digital camera's 40x zoom lens. Probably end up just cutting a circle out and using a piece of double faced tape to secure it in place. Then see if I can photograph a sunspot or two to prove it out.
Turns out the mechanic had ordered in and received the new driveshaft for the van, but the paint on it doesn't look that good. I'll get it wet sanded today and be ready to top coat it with a nice satin black when the weather cools off again next week.
The capacitors for the dash clock on the van showed up yesterday so I'll have a try at making that repair. Not much else planned, so maybe time to have another go at the shop floor plans. Or another afternoon siesta:laughing:
Hope everyone enjoys their weekend.
   / Good morning!!!! #61,447
Actually, it was/is formZ (Renderzone version) by autodesys ...
formZ is kind of quirky and not at all inuitive (IMO) ... but you get used to what you learn, in terms of workflow.
I suppose it was (or could be) considered a "pro level" package ... it sure had a (somewhat) "pro level" price tag at the time ($1500 IIRC) ... :laughing:
At one time I was on their yearly "Family Plan" ... which got you all the updates/patches in a given year and discounts on major upgrades ... but after I got out of doing graphics and wasn't using it as much, I had better things to do with the $300/year or so cost for the pleasure of being considered "part of the family".
Does both surface and solid modeling ... and has a pretty decent (full) toolset ...
The most current version I have is 2.9.3 (circa 1998/1999 ?) I believe ... I think 8.5 is currently in beta ...
Would be interesting to see what that looks like ... but I probably don't have any machines that it would install on ... due to either the hardware or OS being too old.
BTW, it's non-OS X ... I'm running it in the Classic environment.
   / Good morning!!!! #61,448
82F partly cloudy sky mid 80's for high w/light breeze now and than.
Took the trimmer for 3 1/2 walker this morning humidity was heavy,got all clean up having lunch Mrs. said she like to fishing later today...yup the boat and goodies are now loaded.
Warmer temps on the way least until Wednesday. :(
Enjoy the day all.
   / Good morning!!!! #61,449
spent my first two hours today spraying both orchards due to tent caterpillars.
Then hustled back to barn to weld. Started that at 9am and stopped at 2pm.
Pleased with what got done, pleased that fill in primer covers so much.
Most of my welds looked like marble cake, swirled with slag. But the job got done, and
hopefully it will all not pop apart like Legos if I hit something...
Did a huge amount of grinding due to poor welding. Dirty business. Wearing a heavily insulated filthy Hobart
flame proof shirt did not add to my comfort. Plus hot gloves and a helmet.
One of the welding varieties i'm told you can sit in an air conditioned room and weld. That is beginning to sound
really really good.
   / Good morning!!!! #61,450
... One of the welding varieties i'm told you can sit in an air conditioned room and weld. That is beginning to sound
really really good.
Once you go MIG ... :D
The water is on the stove for another pot of java, and I just moved the soil screen frame into the shop to finish it up before I start on the SSQA repair and turned both AC's on to cool things down.
It was 78F in there and felt a little close ... :laughing:
   / Good morning!!!! #61,451
Drew,
Looks like you are making some good progress ... just keep at it.
Personally, I am often quite disgusted with the quality (or rather, the look) of my welds.
Sometimes it goes really well ... and they look relatively decent. Other times, it's "Good Grief ... how did I do that ?"
One thing I do know is that a grinding disc + a flap disc will erase a lot of what I don't like looking at ...
One thing I try to remember before I squeeze the trigger is to get in a comfortable position ... and make sure I can easily reach wherever I'm going to run a bead.
If it means laying on the floor, so be it.
If it means using a jackstand as an arm rest, so be it.
Whatever it takes ...
   / Good morning!!!! #61,452
I tried.
Pretty sore back and neck at the moment from a lot of bending over though.
Some times i could sit, that was good, until my leg got burned by sparks.
Now I should just think like I'm a computer guided laser, always even, always consistent.
And next time I should wear jeans.
   / Good morning!!!! #61,454
I need to buy a welder, i am an expert at sweating.
   / Good morning!!!! #61,455
Well, except for cleanup etc, induction cooking project is basically done:
King Suite
Twin Suite
Wife talked me into changing out the refrigerators, these have the larger freezer compartment.
All the wall shelving was on hand material, the cabinet plywood, Ohia for trim, polyurethane stain, screws and nails. All in, $1000 project not counting my free labor, even with the 2 new fridges. Not on par with the excellent remodel projects posted here, but I'm happy with the results.
   / Good morning!!!! #61,456
Good evening all. 76F this morning, clear, calm. Wind was moderate most of the day, skies remained mostly clear till about 4PM. High was 99F, HI raised that to about 110F. Bike ride on the agenda today, followed by lunch and nap.
   / Good morning!!!! #61,457
Good morning all. Very pleasant out this morning, little wind and no rain forecast until after dark. A good day for a walk around with a knapsack and catch up on a few more weeds.
Wngsprd, I'm not allowed to test the pattern for a couple of months yet as I promised I would leave the little 28 gauge in the cabinet until my birthday. At my age birthdays are no big deal, however I must admit that for the first time in many years I am quite looking forward to this next one.
... having lunch Mrs. said she like to fishing later today...yup the boat and goodies are now loaded.
Hope you and your wife managed to catch a few Thomas, you really are such a lucky man to have found a bride who enjoys fishing so much.
Sodamo, that looks neat work. Now time to take a rest, sit back and just watch the ammeter jump around as your guests play with the induction hobs.
   / Good morning!!!! #61,458
68 outside feels pretty nice. Should hit 89 and no rain until maybe Wednesday.
Finished mowing yesterday so I can take it mostly easy today. Son and wife bringing their Chesapeake Bay retriever here today on their way to beach.
David, very nice looking rooms.
Thomas, have any luck?
   / Good morning!!!! #61,459
David, very nice and impressive, stylish, just a great job.
going to cook some sausage (hard to find it without MSG) and ponder what I want to do today. After working hard
for several days in the heat, might just cool it today. The orchards are sprayed, the lawn is done, the welding is making good progress,
maybe a day off. Now if I knew how to fish like Thomas.
cooler day, nice to see the temp at 68 instead of 78 while it's still dark out.
   / Good morning!!!! #61,460
Eric Salop Hope you and your wife managed to catch a few Thomas said:
That's for the kind words.
Mrs. like to go fishing when ever she can and she does catch some good ones,I on the other hand have little to no intrest,but we always meet in the middle somehow.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
Kubota HB84 Hopper Broom (A53317)
Kubota HB84 Hopper...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56438)
2022 John Deere...
2021 JOHN DEERE 50G EXCAVATOR (A60429)
2021 JOHN DEERE...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
