Good morning!!!!
   / Good morning!!!! #186,383
these phones aren't cheap, hope I have some credit built up with them. Been a Verizon customer a long long time.
I have found that the best deals are when you go to a new carrier. I’ve been with Verizon, T-Mobile and AT&T. Presently with AT&T. For some reason, none of them seem to value existing customers, all the best deals are reserved for new ones.
   / Good morning!!!! #186,384
I'm going from a 12 to a 15 and they will give it to me free online, but charge me if I go in for service.
that's about right...
I think it will be a couple hundred bucks outright. Let's see what today's program is.
I certainly would not pay 1000 bucks for a phone unless I was using it to earn. I'm sure not.
I think I already have an unlimited plan so they can't upsell me on that. But I'm sure they will try something.
in cold weather I really can't put some of these small plants down on the bottom shelf, doesn't get warm enough.
Tuesday morning will be 20 here, then the warmup begins. A very pleasant 48 in heavy overcast today.
those geese would never make it in the Blue Angels :rolleyes:
   / Good morning!!!! #186,385
yep, same with everything else you subscribe to. You only get a deal to switch.
   / Good morning!!!! #186,386
Drew.
Our goto curry
My simple recipe:
Stick of butter
Tablespoon olive oil
Bulb garlic
Brown about 2 lb cubed meat
Add
4 cans coconut milk
Box of curry
Handful of craisins
Cup or so frozen mixed veggies
Teaspoon corn starch depends on thickness.
   / Good morning!!!! #186,388
If that’s the case, you can use the Sirius/XM app to stream to your RV or anything else that you want. I don’t pay any extra for streaming, the subscription for my car covers it.
   / Good morning!!!! #186,389
Hope Cody is recovering, Frits. Heart?
Thanks yes he is back to normal. Part of the blood testing was to check for enzymes that can indicate damaged heart condition. Waiting for results and will see where it goes from there. Brain issues may also be possible
   / Good morning!!!! #186,390
🤞 raising boxers, a known issue sadly. Wishes for best for Cody
   / Good morning!!!! #186,391
No joy in Scagsville.
Scag SCZ-36A 19KAI w/ Kawasaki FH580V
Cranks but not fire/start, even with starter fluid
New plugs, gapped .30
New ignition coils gapped
Good spark both cylinders.
Cleaned contacts, voltage regulator
Fuel system
Both tanks removed, flushed
New connectors
New 1/4 in fuel lines
New inline filters
New water separator
New, filtered E0 gas
Good fuel flow to carb
New carb
Compression
Right 100
Left 115
Battery charged
All safeties working
Timing Issue?
   / Good morning!!!! #186,392
Timing Issue?
Isn’t the timing fixed by the placement of the coils around the flywheel? Set over the magnet? You said the gap is correct, did you use a brass or other nonmagnetic feeler gauge to set it? That compression is a bit low, I am assuming a compression release somewhere in the valve train.
It’s curious…..
   / Good morning!!!! #186,393
Are the plugs wet with fuel? Is there suction at inlet to carb? Did you use a spark tester? Did you try to spray starter fluid into the spark plug holes? Is the flywheel axle key broken so the ignition timing is off?
   / Good morning!!!! #186,394
It’s curious…..
hopefully not the compress release I've seen on videos of other engines, have to tear it down to replace.
   / Good morning!!!! #186,395
Well folks, we sold the big (23 acre) cottage property. “Bemaba Lodge”, as it was called, was going to be our retirement home, but someone came along and made me an offer I couldn’t refuse, and in any case there’s so much work still there that I figure I guess I’m getting too old for it (!)
Some of you may remember some of the lovely buildings on the place, including a great big 50 foot long boathouse. I will miss that place a lot.
He’s a couple of pics that I had posted over the years.
There’s a lot more on vrbo.com. Our ad no. Is 1362879
Goodbye Bemaba!🥲
   / Good morning!!!! #186,396
I'd check the flywheel Key. It's making spark, but as you said, timing could be off. Should just have to remove shroud and flywheel nut & washer. I agree compression sounds low. Also, check the low oil pressure switch first, shouldnt be it since you have fire, but.....
   / Good morning!!!! #186,397
good morning, 37 going to 55 today cloudy
Use Milton V style high flow air couplers. Quincy air compressor tank has 1 inch ball valve shut off at the tank that I close after use and turn off breaker. When turning back on check that the pressure is still holding at 150PSI. Have made a habit of opening the ball valve drain occasionally to drain condensate.
Cody went into a seizure yesterday. Pretty scary to watch him flop dawn. Our vet just 2 miles up the road did not have a doc in the clinic so had to go to another one further away. He recovered and stumbled around for a while. Vet took blood samples and will get results in a couple of days. 400 dollar bill. Hope insurance will cover. This morning he seems fine
Special thoughts for Cody.
   / Good morning!!!! #186,398
Thanks Kyle. I appreciate that.
Its bittersweet to search for a puppy after losing your best friend. We found a top quality breeder who introduces puppies to bird retrieval and waterfowl hunting. I'm not (yet) a hunter but maybe it is another dimension to interact with a future "best friend." We have a phone interview with them tomorrow.
32F, going to a sunny warm 62F here in Formerly-Great California.
Got the surgical staples out yesterday. Surgeon said the magic words: "Goodbye!" Glad that is behind me.
I hope everyone recovers from the many bugs and illnesses circulating out there. Everyone have a great day!
A golden can be a great hunter, or a great inside companion, or both.
Glad you got the staples out, and hope for comfort and well being.
   / Good morning!!!! #186,399
Good (Saturday) morning. Overnight Low of10.3C and it's presently ? , maybe 19C (Aerodrome). My outdoor sensor has frozen, so it looks like I'll be searching for a new weather station. It's clear and calm.
A fairly low-key day is planned. Paddock #4 was cleaned up yesterday late-morning.
The 'Mad Agisting Horse Woman's Daughter was, again, here yesterday arvo so the School must have been flooded enough that an extra day was needed to 'air it out'. Indeed, the horses are away for the weekend at 'Pony Club'.
I'm still applying ear-drops to the Right ear. Things are either slightly improving or my brain is adjusting to the difference/imbalance.:oops: Nothing that I can do about it, so, "She'll be right".
Weather station update: I re-set the outdoor sensor & changed the batteries in the station and it seems to be working again... we'll 'see'.
   / Good morning!!!! #186,400
Goldens are smart and can be calm enough to be service dogs.
Wouldn't a sharp pair of wire cutters do the trick? I have never had staples, so I don't know what the Dr. uses.
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2009 Kubota RTV1140 (A57149)
2009 Kubota...
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
2018 Kubota RTV500 4x4 Diesel Utility Cart (A59228)
2018 Kubota RTV500...
WHIRLPOOL REFRIGERATOR/FREEZER W/ICE MAKER (A60432)
WHIRLPOOL...
2019 TAKEUCHI TL10V2 SKID STEER (A60429)
2019 TAKEUCHI...
