Good morning!!!!
   / Good morning!!!! #184,441
has anyone else had problems logging on? I get part way and it keeps saying Can't Find That
and then in a few minutes it clears.
hope your Sunday is peaceful and relaxing.
I was getting that yesterday afternoon quite frequently.
That was some pellet/briquette maker posted earlier.
A whopping 4F here this morning, but it sure seem to invigorate the coal insert it had gotten the living room up to 77F. Cut the air down a bit and opened up all the bedroom wing doors then turned on the bathroom exhaust fans to distribute the heat a bit. Worked down to 74F and actually feeling a bit cool.
At one time we had considered making our own pellets for heat at 5 locations. Looked at a pto powered pellet maker and then a tub grinder to get the correct material size. We were thinking brush and garbage hay with a touch of used motor oil for a binder. But the time and costs started adding up quite rapidly.
Everyone stay healthy and warm.
   / Good morning!!!! #184,443
64°F and no rain.
Time with Scag less than successful All I get are some weak coughs when sprayed with starter fluid. I can see gas coming thru the fuel filter. New plugs and new cools properly gapped. Battery note holding charge, contributing to my frustration. Been on the charger all night.
Did get to watch some football. Packers Forty niners exciting. Sophie cheering on the Packers me the Niners
Looking at another subdued day. Try the sag again and some more football.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #184,444
I should have looked at my camera yesterday.
BEF -
Can you set the camera to alarm for "events", such as when the tractor leaves the barn?
Just knowing he's out you can watch for him to come back, and he still has his freedom.
/edit
My cameras had a setting to send notifications to my cell phone.
   / Good morning!!!! #184,445
Good afternoon
It was 16° when I got up, it’s about 27 now, likely the high for the day. Clear and bright, winds are much lighter than yesterday.
Yesterday went over to airport and shoveled out in front of the hangar for the little plane. My daughter lives very close to the airport, so I went to her house and shoveled her out as well.
Did some more work on the layout for the in-law suite, getting closer, but still not there.
Just finished making meatloafs to freeze and cook later, one meal at a time.
Not sure what to do with the rest of the day, maybe take the little plane for a ride, maybe do some more clean up, or maybe just take the afternoon off.
   / Good morning!!!! #184,446
Anode replacement is usually 4-5 years, but if you have any water issues should replace sooner. When you do a flush every year or so, what comes out?
Good Afternoon Ken,
I have not drained it out since initial install ! When I get back from vacation will drain it. On previous heaters I would get some orange colored water, we have high iron content at this location ! So it has been 1 1/2 years without being drained !
   / Good morning!!!! #184,448
Good morning! Low of 26°, heading to 43°, mostly cloudy. Had a few snow flurries pass by, looking for a few sprinkles of rain through this afternoon.
Drew, which IPhone do you have? I don't want to update the OS if it's gonna mess it up.....
I'll make sure I set the brakes on the trucks ;):ROFLMAO:
Phil, nice work as usual! Wifey really likes the containers and the lighthouse. What wood are the containers made from?
Ken, I have used these anchors with great success! Never had one not hold well.
I, too, have worked in those conditions...:eek::eek:🤬
Scootr, we are about the same parallel, shove that rain our way!.....good that your getting some good amounts. Hopefully no flooding.
Kilroy, glad they worked out some of the program bugs. I'm sure it won't be too long before it gets messed up again.....
I got excited with the video of the pellet maker.... until I saw how much machining was involved....
Now, if I lived close to Paul or Kyle.... then different story....
I was perusing facebook marketplace last night and found a Craftsman garden tractor snowblower, for $300 bucks. It's about 10 miles away. I got very excited only to find that it won't fit on ours without major modifications to the mounts. Oh well ☹️☹️
Not sure what I'll get into today. Maybe do some horizontal mining in the shop. Not too bad out there, but needs a bit of organizing.
Everyone have a great day!
   / Good morning!!!! #184,449
Temp just got above freezing here. Overcast and predicted to go to 39F. Roads are clear.
Overall, not bad, for winter.
Those TBN log in error "cannot find page" or whatever messages are annoying. I usually close the page a couple times then on about the third try it works fine.
Granddaughter is coming over this afternoon but it will probably be too cold to spend much time outside with her. She loves being outside and active.
Prayers for the USA and hope everyone has a safe, warm, well fed Sunday!
   / Good morning!!!! #184,450
Just back from sister's. Good visit! Cold out there!
Lidded box is Chestnut.
Dishes are Cedar and Maple.
Lighthouse is fire wood?
   / Good morning!!!! #184,453
BEF -
/edit
These pics get sent almost immediate, as opposed to the other cam that only send at sync time.
   / Good morning!!!! #184,454
I noticed the slate walkway out to the driveway was rocking around
the joys of the frost heave, at least half an inch.
always wondered what kind of grout would hold that
I doubt that grout by itself would hold at all. But we get very little frost heave around here.
   / Good morning!!!! #184,455
31° things are melting.
roads going to church this morning worse than yesterday due to a lot of drifting that hadn't been treated. Good worship, new mic I installed yesterday helped. Good lunch at the italian place.
after getting home, decided to clean up the driveway. It had drifted over last night. First filled up the pellet box and stacked a few extra on top. it was only half empty, but calling for rain at the end of the week, rather fill it now. Then changed to the bucket and pushed snow.
   / Good morning!!!! #184,458
I had trouble on Friday and Thursday. I am on a PC. I keep this site open 24/7, I am also online 24/7, except when I go to the bigger city once a month.
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
2011 KENWORTH T370 (INOPERABLE) (A58214)
2011 KENWORTH T370...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2014 FREIGHTLINER...
2020 CATERPILLAR 320 GC EXCAVATOR (A60429)
2020 CATERPILLAR...
