Good morning!!!!
   / Good morning!!!! #182,101
And we both (at least I do) have all my fingers and toes. I have broken a few bones along the way, though.
I’ve got all my fingers and toes, I made it 68 years without a broken bone. Then a lady in a SUV hit me and ended the streak in grand style. Well over a dozen bones if you count ribs individually.
   / Good morning!!!! #182,102
a warm 60 degrees and raining hard, .7 so far and lots of yellow over this area
got my rain slicker and flashlights ready for when the power goes off
I mean the Christmas lights have to stay on, right?
It is pouring out and the creek is rising.
school board xmas function was fun at a member's home
got some nice home made chili and cornbread, and made an early retreat
I wore my sports jacket and Christmas tie and was over dressed. Oh well.
Been years since I put a tie on. This is an old favorite Christmas tie, one with a music box in the bottom
that played jingle bells. Battery long since dead. I'm going to cut it apart and put a new battery in it, which likely
means it won't get worn again...
no one seems to dress up any more. Not even for church for many.
times are changing
I always thought dressing nicely was a show of respect.
yet we all know you can't judge a book by its cover.
nice people come in all sizes and shapes
well I'd rather over dress than under dress. Hostess liked my tie and knew I made the effort, that's
all that counted.
very glad I have the battery backed sump pump. With rain coming down like it is, pump runs pretty often.
I just know before this night is through I'm going to be getting soaked turning on the gen outside, the whole process thoroughly
waking me up and then I rarely sleep well with gen on.
   / Good morning!!!! #182,104
Harry update:
Apparently he does not have enough chew toys, he just came into the living room carrying one of Mrs’ 3lb dumbbells. . .
crazy critter…🤣😂🤣
   / Good morning!!!! #182,105
Good (Monday) morning. Overnight Low of 11.3C and it's presently 24.7C, mostly sunny with a slight breeze.
The Christmas gathering was a lovely affair at 'The Camel Farm', great food & company. Home by 1800.
Today will be a dhobi day, getting prepared for my Brisbane friend's visit. Tonight is a Parrish Council meeting followed by supper at the Rectory.
   / Good morning!!!! #182,106
35F and cloudy @ 18:30, heading down to around 30F for the low in the overnight. Highs in the 30's/40's for the rest of the Ten Day ... :(
Helo - sorry the kid had to witness that tragic incident.
Went to bed around 22:00 on Friday night and slept around 4 hours until around 02:30 or so when I woke and got up. Made a double helping of oatmeal. Was up until around 06:00 and then went back to bed until 14:00.
Woman had made plans to go out with neighbor lady to some kind of Riverdance-type thing @ the Goodyear Theater last night. Neighbor lady brought her new squeeze along so She got to meet him. Woman wasn't hoping for much but ended up quite impressed with the performance.
I took the opportunity of Her being gone to do the gas line work that involved shutting off the main valve coming into the house. First order of business was vacuuming all the cobwebs around the main electrical panel so I could put its cover back on. Main gas valve is directly above that panel and I wasn't going to mess around getting up there with the cover off. Long overdue.
Valve hasn't been turned in probably 40 years and was a little stiff but I used a combination wrench as a cheater and got it shut off no problem.
Then I shut the water heater off.
After that I started removing the gas lines. The first was the supply going to the downstairs fireplace. That yielded one 93" piece of 3/4" pipe, two 66" pieces of 1/2" pipe, two 1/2" gas valves, one 1/2" union, one female 3/4" ---> 1/2" reducer and a number of shorter 1/2" pipe pieces and 1/2" 90 elbows. The line feeding that got plugged with a 3/4" pipe plug.
After that I removed valve/capped stub line that fed the incinerator before we removed and junked it. That yielded a 3/4" ---> 1/2" reducer, another 1/2" gas valve, and some 1/2" nipples and a cap. Swapped in a 3/4" 90 street elbow ---> 3/4" nipple ---> 3/4 gas valve ---> 3/4 plug.
All joints were doped and sprayed with leak detector to check for leaks. then I went ahead and turned the main gas valve on and checked all the joints for leaks. Even sprayed down the main gas valve while I was turning it back on ... just to make sure ... ;)
So now I can finish running the rest of the hard pipe for the gas line to the garage without having to shut off the main gas valve for the house.
At that point I decided I'd take a stab at replacing the water heater anode (finally !!!) ... no soap ... the B&D impact driver wouldn't touch it even with repeated attempts. Will have to give it a try with the 1/2" air-operated Craftsman. So I went ahead and turn the water heater back on and relit the pilot.
Got the shelving at the northwest corner of utility room moved and got the cobwebs in the area up in the floor joists where the gas and electric will pass into the garage vacuumed while I was at it.
Woman was relieved on Her return to see there were no explosions and the house was still standing.
With that all handled I headed back up to the garage later and went back to untangling and sorting through the 6 gauge wire to feed the sub panel. There is plenty enough to run the feed, although there some nicks in the outer casing in spots. But nothing a little heat-shrink tubing can't handle.
Also got the drop leg doped up and assembled, coming down from the gas line on the ceiling. Still need to install the manual gas valve and automatic safety shutoff on that.
Went to bed around 08:00 this morning, got up around 15:00 and caught the second half of the Browns/Jaguars game
Woman made a pot of beef stew this afternoon, was very tasty ... (y)
Not sure what I'll get into this evening.
Torpedo heater is down to around 1/4 tank.
Hope everyone is having a decent Sunday ... (y)
   / Good morning!!!! #182,107
Looks like a good spot for a Reznor!
Or a "BIG MAXX" by Mr. Heater ... ;)
   / Good morning!!!! #182,108
I notice Mrs. made some peanutbutter fudge sooo later tonight while she sleeping I have try couple...hope she didn't count the pieces like last time.
That's one my wife will never make, she's deathly allergic to peanuts. But her mom makes it all the time.
peebles got sent to the basement again for pulling off more light bulbs from the tree.
40deg, and got 1.11" of gentle rain today.
Good worship, good lunch with the usual gang, and got a short nap this afternoon.
And tonight after getting home from evening worship, my wife slipped wearing her slippers (on carpet) and fell hard, injuring her wrist. Don't think it's broken. She also did a face plant. Even had a cut on her palm. She was in our walk in closet. She took pain meds and iced it.
   / Good morning!!!! #182,109
44F steady rain,rain increasing towards end turning to snow with 30-40 gusty winds.
Finally got all branches limbs clean up 3+ hours of not fun,Mrs. made tomato soup with grill cheese ham and tomato sandwich which should had building permit :eek: Curl upon the couch ahhh little Scooter and I curl up on the had (y) nap.
Plans for the evening...dinner,watch some football and numb it in recliner with kitten.
Enjoy your evening all.
You could leave her an easy number...1 :ROFLMAO:
   / Good morning!!!! #182,111
Good evening all. High temp only made it to 51ºF. Did not get bike maintenance done or front porch swept. Did make it grief counseling, after dinner watched some of the Eagles/Dallas game. Had it on in a window on computer, that does slow posting process down.
Saturday evening 7:14 posts.
Paul I remember a Mattel vacuform toy(had one). Most of the tooling did not try to achieve much detail and I got bored worth it quickly.
Ron glad you can help neighbor. I take no one wants them for firewood. Hope today's tree work went well. Nice cardinal.
Bill the oatmeal does not add to the cholesterol, but if the rest of the diet is poor, you won't see the effects.
Helo sorry about upset to your sleeping schedule. Hope that improves soon. Thanks for the link. What the police did yo your daughter after that experience can't be said on a family friendly website. Really glad daughter is not hurt. Just spending time with her will help. Prayers for all involved.
Scotty glad field is good. I thought 50ºF was t-shirt and shorts weather ;)
This morning postings.
Bill hope you got to the lights and treating the BB and bucket got done.
Buppies enjoy the snow if it comes. Thanks for the prayers. Prayers sent.
Billy Glad you found the tree. but we need pics.
Kilroy sorry Bailey not happy. Hope church and shopping went well.
Drew the family time can be rescheduled. Hope you enjoy the socializing. Good to know generator is ready.
Frits sorry to hear about the deer incident. hope all ok and car not too damaged.
Frits thanks for story.
Scotty sounds like nice agenda for the day. Hope it went well.
Paul hope you fix works for the camera emails. Glad you had the 14yo to go on the roof. Sometimes it's fun just to watch others fly :) Glad you got the grain and pine shaving in barn, sorry about missing friends play.
Thomas branches won't get away.
Don sorry parking lot jammed, and no shopping. Glad you got yard edged. Sorry to hear about knee kept you awake.
Drew wise precaution.
RNG glad you now have some groceries. Glad entertainment system fit. Hope you were able take advantage of the opportunities.
Scott(vt) glad breakfast went well, what a nice looking group of grandkids, nice pic
Ken wife did great job on cookies.
Ted sorry motivation got away. QC and cleanup on wife's baking, hmmmm need an apprentice? Hope decorating goes well.
David only slept in 10 minutes, you need to do better, maybe a nap today :) Sorry about battery, not sure why include replacement battery in new car documentation.
Two_bit have a safe trip.
Dennis hope the power jack is correct size. Sorry about the 100 pic plan not enough. Tough story about the boy playing on the fright cars. Bet they were scarred for life. Gnarly pic
Thomas sorry branch cleanup was so rough. Mrs soup and cheese sandwich sounds good. Mrs know you well doesn't she :)
Paul sorry about lady ending your no broken bones streak.
Frits Glad you did not get hurt using homemade cannon.
Drew sorry you were over dressed. Glad food was good. Hope you can get new battery in and tie still wearable
Don that looks close, but the label seem to indicate some extra flavorings in coffee
Kilroy dogs love toys that smell good :)
Randy(wag) glad Christmas gathering was good. Hope laundry went ok, meeting and supper went good as well.
RS I could never copy your sleep patterns. Glad you were able to cover parts for gas line. Sorry water heater anode did not surrender gracefully. Good to you have the parts to move forward.
Dennis glad good day except for wife slip and fall, hope nothing broken or sprained.
prayer for all, especially Jay/Peg, Kyle /Daughter, /mom's breathing, /friends upcoming new baby, /son's migraines, Bird /aging issues, Ron /heart, Billy /mom hypertension & congestive heart failure, David(moss) /remodel, /divorce, Buppies /cancer, parathyroid,blood sugar /wife healing, Thomas /gout, Phil /reflux, Frits /veteran son with mental issues, /granddaughter with Evans Syndrome, Ken /dad possible dementia, /chronic fatigue, Diet not working, Steppenwolfe /son-auto immune disorder, Mark /sister liver transplant and recovery, Grev /wife's eye, Ted /knee recovery, /retirement & disability red tape, /family issues, Lou /eye issues, /heart issues, /wife hip replacement, Doug and wife/health issues, / hand nerve and surgery, /fall and recovery, / wife headaches and heart eval, / David(sadamo)/Sophie's hip or leg pain, Scaredy/shoulder dislocation, /marriage dissolving, / friend stop drinking, Dennis /retirement, /neighbor issues, /land development, /favorable winds not in the forecast there, Drew /back operation issues, /friend's wife cancer diagnosis and recovery, Scotty /back pain, Helogabals /wife's friend situation, Fatjay /father broken hip, ******, Ukraine war, and Country.
   / Good morning!!!! #182,112
Waiting for coffee to finish brewing. 29° with cloudy skies this morning. Heading to 36° with sun and a few clouds. Finished clean up a neighbors. Got talking about a ad he saw for a Kubota B2910. With low hours. Got ahold of seller. Went up north of me to check it out. Bought it. 500 hours and well taken care of. Will be delivered today. !/3 the cost of the Kubota mower I got a quote for last week. Today I will be making a place to put it in barn.
Mostly, thanks for latest updates.
Everyone stay safe and well.
Good Morning All.
   / Good morning!!!! #182,113
2.47 in of rain yesterday started snowing last night about 9:45 PM did not stick other areas got a dusting pretty while it fell power went off came back on reset clock kind of thing. Very windy this morning high low 40s
Nice find Ron hope all works out new tractor to you always fun.
Prayers for all silent or spoken our Country Helos daughter, mostly
   / Good morning!!!! #182,115
Morning all! Currently 42 and raining. A few gust of wind coming at us also.
Not much going on today. Wife is going for hair cut and visit to her parents this morning. I think I will putter in the woodshop a while.
We have a meeting with our financial advisor this afternoon to see how things are going. Wife still can't touch any retirement funds for 2 or 3 more years. [I robbed the cradle]
We are living on my retirement funds and constantly drawing on our savings to keep up with inflationary prices! Will be nice when she can start collecting!
Worked on a New Years wood project for about an hour in the morning.
Warmed up enough yesterday that I was able to shut off the stove and give it a quick cleaning. Didn't do much else as it's hard on my neck and hands. Had a good visit with one of my sisters in the afternoon.
Oh well!
Time to make another coffee!
Hope everyone stays safe and healthy!
   / Good morning!!!! #182,116
32 and snow on the ground about like in m70's photo. Lots of rain yesterday...will check gauge at dawn. May have to bring it in to thaw it. Should get to 48 and be windy.
BEF, hope your wife is better, and no trip to the doc is necessary. We're too young to be slipping down. ;)
Got a nice hike in yesterday during a "hole" in the rainstorm. Didn't finish decorating tree, but did watch our annual favorite, White Christmas.
   / Good morning!!!! #182,117
good morning all
so delighted my power stayed on last night
2.55 inches of rain, water ditch will be huge this morning.
Buckeye, so sorry about your wife. Just tell her that 30 good looking guys want her
to get better. That should help. ;)
well this is pretty good coffee. I expected it to be a little bitter, but it's not. Smooth, not quite as
sweet as i would like, but very good coffee. I used half the regular amount and it still came out black.
some milk and a teaspoon of sugar and it was just fine.
lots of early emails flying around my family regarding our get together tonight. Brother in VA simply waiting a few hours for storm
to pass. Cold front coming in bringing snow from the West.
ho ho ho
   / Good morning!!!! #182,120
Good Morning!
God has given us another chance to get it right (or at least not screw up too badly…).
31.1F going to mid-40s, drying out today.
Geocery shopping excursion went well, I re-formulated potted pork leftovers and turned the broth into brown gravy and added a half-pound of fresh mushrooms and more garlic/dill/thyme and it came out really good,mserved over small elbow macaroni. Then spent the rest of the day keeping those pesky couches in their proper location.
Low energy expenditure day for today while everything dries out. May add a few more exterior decorations today, but much later. Need to tote in some more firewood, too, since I just added the last pieces to the stove. Then maybe catch up on some accumulated actual physical books!
i hope everyone has a happy healthy safe blessed day!
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52709)
(INOP) 2016...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
2014 VOLVO A40G OFF ROAD DUMP TRUCK (A60429)
2014 VOLVO A40G...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
