Good morning!!!!
   / Good morning!!!! #181,361
Good Afternoon,
Ct, 20 to start going to 35 maybe !
Sorry for the late check in, am working today ! Nothing to really report, other than we get two of our grand kids tmrw, and have them until Saturday, so that should be an adventure ! :)
Have a great day ! 🙏
   / Good morning!!!! #181,362
Up to 33°
Rode bike some this morning
I cancelled my oral surgery for next week. I’m going to see how long I can go before another tooth infection. I’ve had no issues since the last infection a month or 2 ago.
I keep several kinds of penicillin/amoxilyn ready and on the first sign of a tooth going wonky, two days of that and it really helps. Never want to overuse penicillin
but I have had many tooth/jaw infections that I've learned to always travel with it. Slowly but surely, 1500 bucks at a time, all my teeth are turning to crowns.
Then no problems, right?
un huh
I think the bad teeth have a crack or other issue and you are just more prone to problems.
for me a new crown is such an unpleasant procedure, the noise/vibration drives my neck and tinnitus crazy and I get a massive
headache from it.
Next time I swore better drugs ahead of time.
I told him I can afford one crown a year. Wish they only cost a British crown...
1 Crown is worth about $0.0016.
I'd surely pay that...
   / Good morning!!!! #181,365
Can I pick your brain for a minute?
We have StarLink, I have the correct Ethernet adapter for it.
if I don’t particularly care about how many different networks I am broadcasting…
and since I have several old DSL routers that still have functioning WiFi capability…
can I run a hub or switch to the StarLink Ethernet port, then hook up the WiFi routers to the hub/switch, and increase my WiFi coverage around my property by mounting one on each exterior wall? Devices should switch networks reasonably seamlessly as long as they are all configured in each device, right?
Or is my proposed attempt at doing things on the cheap by recycling kludge doomed to fail?
I’d say yes
Have an 8 port switch off my SL adapter (not bypassed) then
2 wired Eero, 5 WiFi - 2 ssids Mesh system, my primary around the house.
1 older Apple Extreme - 2 ssids 2 older networks when we have guests
1 Ubiquiti AP with its own switch and 2 Eero -3 aids 2 networks for Cottage and 1 broadcast to get most places on the property
Some downline switches
Well, you get the idea
   / Good morning!!!! #181,367
Scott, it's a fine tooth brush holder isn't it. Just screw your tooth brushes in the holes.
Now that's machinist grade...
34 in rv, I set the propane furnace on 50. Will go back out in an hour and see how it's doing, see if propane level gauge moved.
tomorrow will be warmer but tonight is 22. Tomorrow I pump pink stuff through the lines to finish the job.
most importantly want to drain the toilet drain valve. I have a new one but want to salvage the existing one.
when I pulled the anode out of the hot water heater, it was dry, so the low point drain does seem to work.
my focus tomorrow is the area around the fresh water pump, under the bed. So far it has been bone dry.
   / Good morning!!!! #181,368
34F and "Fair" @ 15:15, which will be the high for today.
LWS reports the low this morning was supposedly 14.5F ... that's not good ... given we still haven't gotten the strawberry plants mulched (15F can kill off the crowns) Definitely on the agenda for tomorrow.
Got hopper and both tube feeders refilled yesterday before it got dark, also scattered cracked corn for the ground feeders ... squirrels were on that in no time. Birds also showed up before I even had feeders filled.
Also got some bills scheduled for payment. Cub Cadet will be paid off before next summer ... (y)
Thought I had the studs located in the wall to put up the plywood piece for the electrical panel so I drilled the plywood and proceed to screw in the piece. The two screws on the left side hit a stud while the two on the right completely missed ... 🤬
Will have to try screw anchors or toggle bolts on the right.
Electronic stud finder seems a little dicey ... will try a fresh battery and see if it does any better.
Located some pieces of scrap plywood I can use to attach the gas line to the garage ceiling just need to cut them to length.
Was heading back out to the garage last night from the kitchen. There are two poured concrete steps going down to the garage floor. Lights were off, had stuff in both my hands, opened door and stepped out onto the top step and closed door behind me. Big mistake.
Got disoriented in the dark while fumbling around trying to find the light switch to turn it on and took a dive ... falling down onto the steps/floor and hitting a 5 gallon bucket of ice melter which had a drill sitting on it on the way down.
Interestingly, aside from the sheer dread and panic as it was occurring, I was not hurt - no real pain, marks, or bruising. Consider myself very lucky as it could have been a lot worse.
At any rate, that was it for the day, spent the rest of the evening on the couch.
Agenda for the rest of today:
Fill up a bucket with some whole corn and refill deer feeder up behind shop.
Maybe cut those pieces of plywood to mount the gas line on the ceiling.
See if I can locate some anchors for the plywood piece for the electrical panel.
Finish up a small Menards order for some odds and ends for the heater project. They have a deal going for their driveway markers: $1.99 with $1.99 rebate (limit 20) so will grab another 20 of those. Plus loose cellulose insulation is on sale ... so probably grab a couple of bales of that.
Beyond that whatever comes up.
Hope everyone is having a decent Wednesday ... (y)
   / Good morning!!!! #181,369
27F partly cloudy.
Been good got everything I wanted done and more.
Around 2pm notice 4 Does and 3 fawns walking nose to tail heading to soft woods from the field, :unsure: little early for yarding.
Plans for the evening...have taste for French toast least couple sausage patties,feet up watch little you tube sharing bowl ice cream.
Enjoy your evening all.
   / Good morning!!!! #181,370
Alma is about 60 miles too far northwest. Try New Hudson.
Other than Detroit, South Shaffer, Alma and Bay City, oh and the Mackinaw Bridge, I know nothing about MI. I know where Gaylord is too, eh.
Many winters ago I had an asphalt haul from Nanticoke, ON to Alma, MI. I also had a beet juice haul from Bay City, MI to Scarborough, ON. The beet juice was mixed with magnesium chloride to make ice melt for spraying on the highways and hospital parking lots. Delivered the ice melt to a hospital in I think it was Highland Park. There was a very specific route to get to them and I was NOT to deviate from that route. Didn't bother asking why having hauled through Detroit when I hauled freight.
As far as English goes, my Dads first cousin was an English professor at New York University for many years. She hated the fact that I smoked, but she still left me 50 grand when she passed.
Cold is relative. What you perceive as cold at 20°F is warm to me after putting up with a couple of weeks of 40 below.:ROFLMAO::ROFLMAO:
   / Good morning!!!! #181,371
"Had some people comment on black kid not speaking "black""
What I think is really amazing is people who can switch back and forth. I have heard British people who speak both english and american. I guess some people just have an ear for languages.
Bob Hoskins in “wHo Framed Roger Rabbit?” Comes to mind…
   / Good morning!!!! #181,372
very doable, but you just have multiple networks to maintain. If you have a favorite router you prefer, just put starlink in bypass and use your own router after it. It's what I'm now doing but with mesh system.
What’s to maintain once it is set up?
   / Good morning!!!! #181,374
Anybody else notice the deluge of ads on these pages lately? The number of them is bad enough, but some of them are from raunchy sites like orchidromance. AdBlockPlus is stopping some of them but not all. I guess there's no place safe anymore...
   / Good morning!!!! #181,375
Good (Thursday) morning. Overnight Low of 8.5C (due to wind chill) and it's presently 14.2C, overcast and 'blustery'. There was 0.7mm in the gauge @ 0900.
Not much on for today aside from a doctor appointment @ 1430; a follow-up from the blood-work last Friday.
As I've mentioned before, Australia officially changes 'seasons' on calendar dates vs. celestial occurrences... So, today is the last day of "Spring". Naturally, I'm wearing a jacket outside during this cool-snap. o_O
   / Good morning!!!! #181,376
Adguard Adblocker works here now adds it is a Firefox extension.
   / Good morning!!!! #181,378
RNG, try to turn off Adblock, then clear your cache, turn off the device, then turn it back on after a few minutes. Then, before any website visit, turn Adblock back on. Then have fun!!
I have some experience with this...... when I opened TBN on Monday, it was bombarded with ads.....
the above procedure cured it for me.... no more ads.
   / Good morning!!!! #181,379
Successful day! Got the new storm door installed, cleaned up all the "stuff" needed for install, got the packaging materials out to the trash (before they came), old door and hardware moved out to the hobby shack. Then brought some more pellets up on the deck.
The door took longer to install than expected, but aligned to close tolerance. This door has double weatherstripping, hopefully it will be beneficial against the cold winter wind.
Fritz, that was a nice corner cabinet you made. I'm going to measure and draw one up tomorrow. Then get a list together for the sawmill. Got a few pieces to do for Christmas presents too....
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
2007 Ford F-150 Ext. Cab Pickup Truck (A59230)
2007 Ford F-150...
2013 VOLVO EC250DL EXCAVATOR (A60429)
2013 VOLVO EC250DL...
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2020 CATERPILLAR 299D3 SKID STEER (A60429)
2020 CATERPILLAR...
