Good morning!!!!
   / Good morning!!!! #179,881
Good Morning!!!! Good Morning!!!! 54F @ 6:00AM in Orcutt, CA.
Partly cloudy skies. High 82F. Winds W at 5 to 10 mph.
Bandages looked good under the white fishnet, Don, sorry they didn't work out. Maybe your knee is asking you to ease off a bit? Hope you get some relief now that the staples are gone.
My buddy and I got everything loaded for the trip south on Wednesday, including a 1775 lb. piece of equipment loaded on a rented tilt deck trailer I'd picked up that morning. Went easier than we thought. Got a comfortably early start yesterday on the trip down. Remembered to cancel the traction control on the van for the trip up the driveway, and made it up with no problem at all. It was smooth sailing until a tire on the trailer suffered a blow out about 2/3 of the way there, way out in the middle of nowhere. Shredded the tire, and sparks from the steel wheel and trailer axle dragging on the pavement started a grass fire at the side of the road. Fortunately the fire department was able to confine it to about a 1/4 acre, though we had to move the van and trailer a couple times to stay ahead of the flames. And there was a dirt road running parallel to the freeway that kept the fire out the adjacent pistachio orchard. There were thousands of acres of them in that part of the drive. Finally got a wrecker to come for the damaged trailer, and a driver from the rental company, Herc, to come over from Bakersfield with a replacement trailer. Transferred the load by the side of the road, in the dark, and finished the trip at about 11PM. The trailer rental was originally set up for a week so as to allow us to make several trips, but I don't think the single axle replacement trailer is up to the job, and I don't want a repeat of what happened yesterday. So we'll return that trailer to the Herc branch here today, and see if we can get a double axle tilt deck to take back with us for the next two runs. Can't wait to see the bill on this misadventure.
Come to think of it, Herc used to be called Hertz Equipment Rental, and the last trailer I rented from them had a blow out when I was dragging home the Kubota side-by-side. That trailer had two axles, so I was able to take off the bad wheel and get home. The grumbled something about charging me for the tire and I pointed out that it would not have been a problem if they hadn't put a cheap Chinese tire on the trailer to begin with.
Now just gotta get my buddy up outa bed without coming off like a slave driver...
TGIF gang.
   / Good morning!!!! #179,882
Good morning, low of 33°, heading up to 65°. Sunny and dry.
RNG, quite the drive this time! Hope they don't hit the wallet to hard..... Hope you can swap it out for the dual axle.
Phil, I bet that bowl breaking was a quick shock! Good that you just got a minor injury. Does that happen often?
I was procrastinating disconnecting all the drip valves.... being that the temps only stay at freezing for a short time... wrong decision..... found 2 split valves yesterday. Hope that I learned a lesson......
More mudding of the drywall is on the agenda for today. Only 6 more corners to do.... then a second coat.... then the texture. Probably going to do a 'skip trowel' finish. Using the hopper texture gun more than likely won't end in a happy ending ---- I can see that drywall mist floating in the main house..... and the relevant loud yelling that would ensue....:eek::rolleyes:
I am very disappointed with out trees changing color this year. They started, but then those 2 really cold nights stopped the change.... now they are just "freeze dried" -- crunchy but no color.
Everyone have a great day!
   / Good morning!!!! #179,883
successful trip getting pcv valve and hose changed in rv.
I think it was the valve, hose looked fine, kept it as a spare.
could not go fast enough on way home to tell if whistling whooshing noise gone but
I will be cautiously optimistic it was.
looked good inside,dry, and pretty clean
filled the bags too full in bagger yesterday, luckily did not back too far up the pipe
   / Good morning!!!! #179,884
54F and sunny @ 12:30, heading up to around 59F for the days high. Supposed to be breezy this afternoon.
Started rebuild/reassembly of softener valve yesterday.
Will likely use the nice weather today to get more strawberries planted in the ground.
Woman wants to continue mulching the flower bed so I'll need to bring some mulch around, only 7 bags left.
Hope everyone is having a decent Friday ... (y)
   / Good morning!!!! #179,885
My totals in Hours for mowing each year with the ZT:
2019 41.4 (bought end of May)
2020 60
2021 60.7 (I split between beginning 2020 hr and end 2021 hrs, did not keep details.
2022 63.5 (Front 28 times, Field 18 times, Creek 14 times)
2023 45.7 (Front 20 times, Field 16 times, Creek 13 times) (probably will mow 1 more time)
2023 Lot 14.1 (6 times with ZT, does not include first mow with BX)
   / Good morning!!!! #179,886
68°F and no rain.
Not very productive yesterday. Evaluated a couple reorg solutions without making a decision. Guess I’ll do that today. My shelves are populated with a variety of enclosures to hold stuff like nuts, bolts, screws, tape, etc. some stacked 4 high meaning I have to move 3 to get to the one I want. Think I have what I need to make a simple rack solution.
Guys won H&F after a delicious meatball and spaghetti dinner.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #179,887
Ron, years ago I used a GPS program on my iphone to determine speed in my golf cart. Not convenient, but fun. Let us know about this solution.
   / Good morning!!!! #179,889
Prayers for all
Be safe
Have a great day
I bought this to hold storage bins. Another unfinished job, as I haven’t mounted it yet. I want to put on a cart with casters to store it under my work table.
   / Good morning!!!! #179,891
It's not unheard of but shouldn't happen if you pay attention and use good technique.
Things go bad when you rush or get distracted.
It has happened to me maybe 5 or 6 times when I first started out and didn't know better.
   / Good morning!!!! #179,893
Been on hold an hour waiting for Dish Network customer service, or lack thereof. The music is most annoying.
Did get netting fence down from around the garden. Zip tape is still elusive, so I ordered a roll from amazon. I wasn't comparing the same type the other day, but they are a couple bucks more than lowes, but didn't feel like a trip just for that. wasted much of a nice day. Did locate a ft stick of 3" pvc pipe stuck up in the basement ceiling, but did not retrieve it.
turned pellet stove off today.
dish offered to lower my bill from $118 month to $68 month for 1 year, plus next month only $28. Not sure I believe them yet, will have to see the bill. Talked to kevin in India.
   / Good morning!!!! #179,895
Good Evening Guys ,
PC, it was 78 to start and went to 88 ! Not much to report, all we do is swim, eat and 🍺, not necessarily in that order !
Buppies, hope your wife is feeling better !
Dennis, please let me know how you make out with DISH ! We have two accounts with them, one in Vt and also Ct ! I feel we pay to much, and would love to lower our bill !
David, nice job on the charging station !
Don, glad your making progress on rehab !
Phil, glad you weren’t hurt ! 🙏
Hope all have a great evening !
   / Good morning!!!! #179,896
Ahhh, unfinished jobs…I can relate.
I have a box of something similar. Can be mounted in single rows. Unfortunately I don’t have any readily available wall space.
So this gives an idea of my starting point.
So I’m putting together some frames for the plastic bins to slide. Glue will have to dry overnight before I stress.
   / Good morning!!!! #179,897
45F partly cloudy.
After short day at work decided to take backpack blower for nice afternoon hike...nope gust wind were blowing wrong direction 🙄 got the driveway and culvert post marker place,than walk way snow boards place,than heck of nice guy shows up visit ask how the Kubota running if I needed anything,he did front to rear check on this and that...that's some rare today I was impress. :)
Plans for the rest of the evening...little to none. ;)
Enjoy your evening all.
   / Good morning!!!! #179,898
Good Evening Guys ,
I have dishes in 2 locations on one account. I just don’t tell them otherwise. I own my equipment.
However my box stopped working at least 2 yrs ago. I rarely watch tv anymore, so I’ve only kept it going for my dad to watch.
   / Good morning!!!! #179,900
That’s why I want to put on a roll around rack.
2018 FORD F-450 XL SINGLE CAB FLATBED SERVICE TRK (A59823)
2018 FORD F-450 XL...
2003 Big Tex 10PI...
2021 Ford Mustang Mach-E AWD SUV (A59231)
2021 Ford Mustang...
2020 Dodge Charger Sedan (A59231)
2020 Dodge Charger...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
Tank Only (A59076)
Tank Only (A59076)
