Good morning!!!!
   / Good morning!!!! #169,361
Frits, have you considered suspending posts from excavator with a rope looped around, maybe something like a clove hitch or double half hitch? Something that would hold it straight but loosen easily.
   / Good morning!!!! #169,364
Probably too late to help, but pharmacist told me if I got those symptoms from the booster to drink a bottle of water as quick as I could get it down And take two Tylenol, which never help me. The next morning, i had a headache and sore arm. Did as he said and within a half hour headache was gone and arm was much better
I did take an ibuprofen this morning and both arm and head are fine.
   / Good morning!!!! #169,365
I got both sides of the driveway cut back. Did it all with the hoe. Knocked a 6" Pine over after undermining a bit. I have been wanting to do that for years.
Got a low down V notch cut in one of my dead trees that is now a widow maker. It is busted about 40' up. Where it is designed to fall it wont hurt a thing.
Tomorrow is tin work.
   / Good morning!!!! #169,366
The hour meter mystery solved. When in doubt look at the manual. Number without engine running is hour, number with engine running is miles
David good idea
   / Good morning!!!! #169,367
Morning all, 52 going up to 70 and sunny.
Finished planting the Forsythia, all 25, while the rain kept hitting here.
Finally got something done !
Today off to Brewfest on the river with a bunch of friends and then to a Kentucky Derby party. Hopefully it's not as muddy as last year. Not sure how much I will get done tomorrow.
Alien - good to see you back and sorry to hear about your ailments. How are your hands doing, did the operations help?
Mostly so close yet so far. I guess no way to modify engine to work? Hope you find a suitable replacement
KC - glad back is getting better
I have a wood dolly for my backhoe, it takes a while to swap since everything for the 3pt needs to fold up etc. but building my dolly certainly helps. I need to keep the BH on for a while to move some tree trunks then it's time for the flail and forks to move the branches and rocks.
Be well,
Thank you!
   / Good morning!!!! #169,368
Thanks, RNG. This is a pipe post 2 3/8 diameter. I think it will be a series of overlapping short runs as I’m challenged maintaining a consistent distance over about inch. Not overhead, the break is near ground level
View attachment 799181 (pic before cleanup & temp fix)
Also note I need to determine how to stablize my hand, especially the side away from the concrete.
Raining now, so practice, practice, practice.
OK, did have a pic of the temp fix
The exhaust connector inside, held in place with a couple screws. I can clean the surface rust well with wire brush. Get to use the concrete for stability for half.
For stabilization, if you have ever seen any old-times with painters, a rod/stick placed one end on a surface away from “target area” while held with supporting hand can provide something for working hand to lie upon while performing the take, and you can move the stic around for optimum support.
   / Good morning!!!! #169,369
We've had some memorable threads concerning "hours" on a tractor.
Some tractors the hours tick off whenever the key is in the ignition and just turned on, even if the engine is not running.
Some tick off whenever the engine is running.
Some tick off depending on the engine speed. You can idle for hours realtime with little change on the meter, but when you get up to "pto speed" they start counting.
And of course there are many older tractors where the hour meter is broken.
And my 1962 Case - with original Case gauges - does not have an hour meter.l.
   / Good morning!!!! #169,370
Don’t forget Cow Hitch or Magnus Hitch, depending on texture of the pole… 😁👍
   / Good morning!!!! #169,371
Good evening all. 66ºF for the start, light breeze, partly cloudy sky. moderate wind with brisk gusts, partly cloudy sky until after dinner, and high temp was 86ºF, HI 92ºF. Bike rid to start day, 59+ miles. Lunch then nap, felt lot better after nap. Dinner with step daughter and her husband, were able to sit outside. Included are two pics of pulley that goes on end of crankshaft, to show what needs to be changed. Smaller pulley drive the propulsion system.
Bill there might be a video on how they do it in 30 minutes. Bet it is carefully set up and who does what carefully choreographed.
David good luck with your practice.
Buppies search resumes Monday morning. sorry to hear cyst is back and you are back on antibiotics. prayers sent
Ron glad you had a suitable temp tire to mow with. Glad you got so much done. nice moon shot.
Dennis glad you finally won.
Drew hope work session went well and celebration of life was uplifting.
Billy glad you had a good day. Hope you can get rest of wood split soon.
Drew small wonder they put coronation off for months.
Thomas yes it does. Hope there is a replacement motor.
Thomas hope you got wood stacking done. Sorry about junk blowing across road.
Kilroy wonder who made that decision ;)
Bill good luck with trees. Some of the guy have very active imaginations :)
Paul nice mowing work, glad GS worked so hard he needed nap. Glad you got some RC flying in. Pulley is 2 pc and has second pulley piggy back on first. It is part of blade brake system on Husky self propelled mower.
Kilroy hope you can get payment straightened out. Yup nothing is ever easy.
Dennis sorry breakfast crew bailed. Sorry about pin holes not lining up.
Ken glad you got forsythia all planted. Hope good day with brewfest and Kentucky Derby partys. Nobody said they had a good way to turn whole engine on lathe.
Paul nice pic.
Frits good outlook on life. Good luck with establishing parameters you and shoulder can live with.
RNG glad you got some rain, hope you can get mowing done before dry season. Good luck with fresh air feed. Sorry fuel pump acting up again.
Drew glad you had some fun discussions with the young parents. Sorry about wrist and hands not happy.
Drew fun story.
Dennis glad threads chased on tractor. Hope lug bolts show soon.
RS hope you had a good Saturday. Nice pic
Jay good to hear you were able to sun yourself.
Dennis interesting visitor.
Thomas glad day went so well
Randy(wag) glad you enjoyed the coronation. Hope Sunday was good.
Joel glad you got stumps out. nice pics
Doug glad hands are better. Hope you can get the operation for your back.
Frits sorry excavator did not work out to set fence posts. Glad manual method worked. Glad daughter showed up bearing gifts.
Joel nice pics
Bill good to hear hoe getting a work out after the delay getting it on the tractor.
prayer for all, especially Jay/Peg, Kyle /Daughter, /mom's breathing, /learning new job, /friends upcoming new baby, /son's migraines, Bird /aging issues, Ron /heart, Billy /mom hypertension & congestive heart failure, David(moss) /remodel, /divorce, Buppies /new skin cancer spot and treatment, /back surgery healing, /wife knee healing, Thomas /gout, Phil /reflux, Frits /veteran son with mental issues, /granddaughter with Evans Syndrome, Ken /dad possible dementia, Steppenwolfe /son-auto immune disorder, Grev /wife's eye, Ted /knee recovery, /retirement & disability red tape, /family issues, Lou /eye issues, /loss of brother, /heart issues, Doug and wife/health issues, / hand nerve and surgery, /fall and recovery, / wife headaches and heart eval, / David(sadamo)/Sophie's and David's new eye surgery recovery, Chris /neighbor's granddaughter and Covid issues, Scaredy/shoulder dislocation, /marriage dissolving, / friend stop drinking, Paul/ wife's healing from back surgery, Dennis /retirement, /neighbor issues, /land development, /favorable winds not in the forecast there "alligallyitus" and back in hospital, Drew /foot heel issues, /friend's wife cancer diagnosis and recovery, mike /wife's healing from surgery, Scotty /back pain, Helogabals /second opinion, /wife's friend situation, Fatjay /father broken hip, Ukraine war, and Country.
   / Good morning!!!! #169,372
Muggy day today high 90˚F but south of San Antonio was under a heat advisory with a 109˚ heat index, so I feel fortunate. One tractor driver quite and the other was promoted, so the promoted one is my relief driver since he has to sub whereever their is a staffing shortage.
This evening during our hike we saw a man on the trail holding something behind him and running, I thought he was holding string and pulling a kite, but when we got closer he was holding his phone and videoing his turkey attack. The same turkeys we saw attacking a car when we arrived. I got my phone out as we were walking toward the turkeys on the trail but we went very slow and methodically and they did not attack. We did however see a large snake on the trail and a fox crossing the road with a rat in his mouth.
   / Good morning!!!! #169,373
61F and mostly cloudy @ 23:59, headed down to around 57F for the overnight low.
Reasonably productive day.
Got the all the mowing down around the house finished up, along with the rest of the front yard.
After that I used the B&D battery operated string-trimmer to cut down all the weeds around the four small (2' tall) oak saplings up along the road that we had transplanted previously. Got all the debris from that raked up and dumped over at the compost pile, also caged them to keep the browsers away:
Pruned the lowest side branches off of one 6' tall oak that is up there, as well as trimming back a bunch of multi-flora rose that was growing out of a shrub. All that got taken over to the brush pile. Still some more trimming to do on the larger trees up there.
After that I moved the old Craftsman table saw and B&D/Dewalt radial arm saw over to the barn to make room for the Unisaw.
Once that was done I came inside to scarf down my half of the Jimmy John's Italian that The Woman had brought from her trip out shopping earlier today.
Before I could get to that though, I noticed a 'coon out the kitchen window at the feeders ... so I snuck out with the 12 gauge and gave him a blast. Apparently he had heard me coming cause he was already making tracks when I rounded the corner.
Shot was probably from 75' or better ... so hopefully there was enough spread that he at least caught a few pellets. He tried to go up a small oak tree about 3' or so and then thought the better of that and headed off towards the neighbors.
Caught a little bit of the BoSox/Phillies game and LA/Golden State while I was eating and afterwards as well.
Just finished up moving the Unisaw down to the garage a bit ago:
Dropped the pallet forks up in the shop after I finished that, will see if I can't get the SSQA "wings" welded on that tomorrow maybe.
Still need to get that mealworm feeder put up. Looks like I'll need to make a trip down to Eddie's for some mealworms too.
Hope everyone had a great Saturday ... (y)
   / Good morning!!!! #169,375
I would really like to know how a BH is supposed to go on in 30 minutes. It only took the two of us 2 hours to get that sucker on.
But it is on and I cleaned out both ends of the culvert that I own.
The township one at the road, they can earn their keep and clean it. Tomorrow is stump and small tree day.
OK, so I guess it’s safe to take my rear blower off and put the backhoe on.
   / Good morning!!!! #169,376
Coffee has finished brewing. 53° with cloudy skies this morning. Heading to 73° with morning rain and cloudy afternoon. Changed house and RO filters yesterday. Ordered new set of filters for next year. Got tire unmounted and tried to fix leak in side of tube. No luck. New tube showed up later in the day. Will get it installed later today. Need to start putting weed killer down around paver bricks.
Mr and Mrs Cardinal.
Prayers and best wishes for everyone.
Good Morning All.
   / Good morning!!!! #169,377
good morning all
hoped to sleep in this morning but things running through my mind....
including, sigh....all the tools I left at the local school for workers to use while I was off at memorial service at my own church.
MIA
gone
no one knows where my pull cart and Makita tools and gardening equipment is.
Am pretty sure their caretaker put them away where I can't find them, but now the emails are getting livelier...
where are Drew's tools?
am not concerned, but really don't want to replace a thousand dollars worth of cordless tools, including my stash of 6 makita batteries.
one hour window when event coordinator left at 2pm and I showed up at 3pm to find an empty bench where all my stuff was piled.
44 going up to 77 today, very nice sunny day, with light rain tonight.
going to wash the car
I think there's a big fat red strawberry waiting for me too.
Ron, good reminder, I have to change my water system filters today also. Since I still get green stains on white sinks, not very satisfied with
performance, but then I went in with a smaller unit. Acidic water plus old copper pipes.
   / Good morning!!!! #169,378
Paul nice pic.
Drew fun story.
Joel nice pics
Spoke to AmEx. Payment was never Ccepted on vendor’s end, so was recredited back to our account and placed into “Pending” status. Had them cancel that payment entirely, and advised that an identical payment would be resubmitted momentarily and to ensure it is not flagged suspicious. Resubmitted payment, which apparently worked that time. Emailed copies to vendor of all the transaction confirmations, plus the AmEx email regarding the “pending” transaction (made before the due date) which a note “suggesting” they find out the problem on their end with the rejected payment. Yay. . .
   / Good morning!!!! #169,379
good morning all
MIA
gone
That is horrible. Any chance of security video?
   / Good morning!!!! #169,380
Good Morning
44 with a high in the low 70’s today.
Yesterday was slow moving, but got a few things done. Went to daughters house to put up some shades and have lunch with her.
Did some cleanup in the shop and a little bit of paperwork before oldest son and grandson came up to fly models, youngest son and his wife and dog came to visit as well, daughter showed up with her two dogs, so we had a regular dog festival going on. They all stayed for an impromptu cookout.
This morning I’m getting ready to do to Sarasota again to pick up the people that we dropped off on Wednesday. Should be back early this afternoon, I’ve got the drone charged up, we want to try to take some air to air video of the RC planes. We’ll see how that goes.
The runway is noticeably better than it was prior to rolling.
Won’t get anything done tomorrow, as I’m off to Marsh Harbour, but when I get back I shouldn’t have to go anywhere for a few weeks, but that is always subject to change. One of the problems of working for yourself is that you are stuck with a taskmaster for a boss.
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
2012 CATERPILLAR 308D CR EXCAVATOR (A59823)
2012 CATERPILLAR...
2020 DRAGON ESP...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
iDrive TDS-2010H...
