Good morning!!!!
   / Good morning!!!! #169,341
Aches & Pains aside it reads this morning that all of us are moving around a little better.
I am slowly changing my outlook to be happy for what I can do versus what I can not do
It's not easy; I am "working on" this myself.
What a beautiful morning with clear skies and sun. I drug myself out on the deck early this AM and basked in the sun like a Galapagos Island marine iguana while enjoying my coffee. The morning low was 39ºF. Clouds have been mixing in as the day has progressed, but it is still mostly sunny. 64ºF ATM and 65ºF recorded earlier might become today's high temperature. It's been a great day just to putter about outside pretending to be productive.
I hope everyone is having a manageable day.
   / Good morning!!!! #169,342
David,
If the parts you're going to be welding or practicing on are galvanized, beware of "Metal Fume Fever" ... and ensure you have plenty of ventilation.
Yup, thanks, practicing in open bay with plenty ventilation and actual post is outside. Way back to build the house I arch welded 11 brackets made from 4inch pipe coupler and large Simpson bracket - a lot of galvanized. This post fix will be less than a single bracket.
   / Good morning!!!! #169,344
Got gasket sealer on OHV covers of husqvarna. Found I had a tube from rebuilding the transmission. Did return with Amazon for new tube I ordered, they credited me and said don’t even send it back.
Getting mower out of shed , I always look up.
It didn’t move until I was done with mower and looked again, and it was gone.
   / Good morning!!!! #169,346
Only focus today is my gate fix. Just practice, practice, practice until I feel I can do a functional fix. Weather dependent of course.
If you're having trouble running a stringer bead, you can just put down a series of overlapping spot welds. That lets you see what you're doing between spots so you can position the gun in the right spot. It also lets the weld cool and solidify, very helpful if you're welding vertical, and especially over head. Just take your time, you'll get it...
   / Good morning!!!! #169,347
I am slowly changing my outlook to be happy for what I can do versus what I can not do.
I couldn’t agree more. After my motorcycle accident, surviving wasn’t a certainty. The next obstacle was mobility and the use of my right arm.
I am keenly aware of the damage that was inflicted every time that I move. But I have taken to saying that I’m doing great, I’m not dead.
I appreciate that I am here and able to pretty much everything that I could before, even have my FAA 1st class medical certificate. So I’m not about to complain about what I can’t do, I’m pleased as punch with what I can do. And friends and family are quick to help with the things that I need help with.
   / Good morning!!!! #169,348
Thanks, RNG. This is a pipe post 2 3/8 diameter. I think it will be a series of overlapping short runs as I’m challenged maintaining a consistent distance over about inch. Not overhead, the break is near ground level
(pic before cleanup & temp fix)
Also note I need to determine how to stablize my hand, especially the side away from the concrete.
Raining now, so practice, practice, practice.
OK, did have a pic of the temp fix
The exhaust connector inside, held in place with a couple screws. I can clean the surface rust well with wire brush. Get to use the concrete for stability for half.
   / Good morning!!!! #169,349
Thanks Frits. What you see in the 2nd pic is not the actual break but new cuts. I even inverted the post top. There is an exhaust connector inserted between and I did flap sand all parts, that rust is strictly surface and will be addressed.
As for reenforcement I have some 1/2” steel angle and thinking I might add in 2 or 3 6inch lengths vertically.
I am also adding additional brace at top of post. Pic later.
   / Good morning!!!! #169,350
When I took the BX to mow last week, my brake controller gave no indication of trailer braking. Looking at the 6 pin to 5 pin adapter I had to move + and blue wires to match the trailer. All turn signals and brake lights worked ok, but still no brake indication on the controller after moving blue wire to matching terminal. The + pin is not wired on the trailer. Guess I’ll be crawling under.
   / Good morning!!!! #169,351
OOOOHH man I be gone to. :eek:
   / Good morning!!!! #169,352
Checked the RTV x1100 for service requirements and discovered that there is a 400 hour difference in the hour counter between when it is running and when it is off but with the key turned. First time I have seen anything like that.
We've had some memorable threads concerning "hours" on a tractor.
Some tractors the hours tick off whenever the key is in the ignition and just turned on, even if the engine is not running.
Some tick off whenever the engine is running.
Some tick off depending on the engine speed. You can idle for hours realtime with little change on the meter, but when you get up to "pto speed" they start counting.
And of course there are many older tractors where the hour meter is broken.
   / Good morning!!!! #169,353
70F clear 10mph wind mid 50's over night...bedroom windows shall be open over night. :)
Been good day for outside to do things,wood stack call for more,areas clean and rake,2 small trees cut and clean up,ditches clean,Mrs. BIG flower boxes prep...after dinner set on the deck with kittens until eye lids get heavy.
Enjoy your evening all.
   / Good morning!!!! #169,354
Good (Sunday) morning. Overnight Low of 1.6C and it's presently 6.8C, hazy with a gentle breeze.
Fortunately, the coronation was on at a very decent hour down here so I was able to watch the whole event. I toddled off to bed at around 2230, as they were making their way home.
Well, I'm off to Church in about half an hour and then the rest of the day is His.
   / Good morning!!!! #169,355
Wasn't quite this morning but after pulled stumps at my dad's I had a couple to do at the house. One came out with no problem.
Other one did not want to give up the ghost.
Had to cheat and hook the truck up to it. I was expecting a tap root from hell but nope, just didn't want to cooperate
   / Good morning!!!! #169,356
Morning all, 52 going up to 70 and sunny.
F
Alien - good to see you back and sorry to hear about your ailments. How are your hands doing, did the operations help?
Be well,
Yes Ken. Hands are somewhat improved. No more numbness and thumb doesn't lock up anymore. It took several ops and countless needles to get to where I am and I don't really want to go through it all again.
A friend of mine (female about 40 years) just had a spinal op like I need. They put some screws in and wound wire around them and filled the middle with some synthetic that grows and becomes part of the vertabrae somehow. Dr said she should be good forever from now on. She is feeling much better after just a few weeks.
   / Good morning!!!! #169,357
The excavator can grip the poles and hold them vertical to set them into the holes based on the test I did today. The problem was that the thumb was scaring the wood pole pretty bad and going easier it lost the grip so gave up on that idea. I did not want to shorten the poles after setting them. So back to manual and I set 5 poles today by using mostly left hand with minimum support from the right. Still need to tamp the dirt better with flat end of digging bar
Also worked on the ledge at the pond now that I had taken the excavator out of the barn. Changed the slope down to the pond to create a ledge wide enough for the RTV and tractor. Did about a 100 ft stretch until I ran into wet clay. So will wait for that to dry out to make more progress. Will also pile dirt up to be able to reach an area that I want to dig out and increase the size of the pond. And then dig up the run way as I back out.
Daughter surprised us and showed up with Brisket and cheese, liquorice, sausages etc from her travels to Europe. We had a good time. Being a conference panel moderator this week went really well for her and she is attending another conference next week for her department.
Newbury thanks for your comment on the hour meter. I think the 300 hour when the key is turned may be more accurate but who knows so I will plan to do the full 400 hour service. Just don't think It went up 400 hours in a year since I don't use it that much.
Joel I dig deeper when encountering a stump not budging and none have defeated me yet.
David that second picture looks good
How are we to know how much we load the FEL anyway. I fill the 72 inch bucket with top on it with wet clay. I am sure it is way overloaded compared to actual rating? Something tells me when there is bounce in the FEL while driving it is loaded
   / Good morning!!!! #169,359
The King is crowned.
And I stayed up and watched the 1st couple hours drastically reducing my sleep time.
68°F and .32 inches rain.
Shot arm a bit sore this morning and a slight headache, but that could be from poor sleep night.
May take a time out for running of the Roses, if I remember.
Prayers for all
Be safe
Have a great day
Probably too late to help, but pharmacist told me if I got those symptoms from the booster to drink a bottle of water as quick as I could get it down And take two Tylenol, which never help me. The next morning, i had a headache and sore arm. Did as he said and within a half hour headache was gone and arm was much better
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A57192)
2008 INTERNATIONAL...
UNUSED RAYTREE RMLL60-60" HYD LAND LEVELER (A60432)
UNUSED RAYTREE...
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2015 Ford F-250 Crew Cab Pickup Truck (A59230)
2015 Ford F-250...
