Good morning!!!!
   / Good morning!!!! #162,801
In reading about different Mini-split installs, the only thing I have seen on the outside units is if the prevailing wind blows into the discharge side then a wind block of some sort is recommended. Also to be installed high enough as to not be buried in snow, if you get any.
With any AC unit, the outside unit should not be installed in the sun. Late afternoon sun shouldn't be too bad, just not high noon sun.
All the ones I have seen have minimum clearance specifications. Most have side and front intake/exhaust and some have rear intake too. Would be bad to block those. The ones I looked at even had overhead restrictions. This was from 4 different manufacturers. Fuji, Mitsubishi , Mr. Cool and LG.
   / Good morning!!!! #162,802
Buppies, Those Boston Whalers look slick. I didn't look up the price but I bet it is HIGH.
Chris
I saw a 2016 model for $669000 wow
   / Good morning!!!! #162,804
Speaking of dropping keys, I have a great story for you. My wife was trying to open a padlock on the boathouse, and she dropped my whole set of keys… Into a big O pipe! It went straight down a couple of feet before curving and heading off to another building. Tried fishing them out even though she wasn’t sure they fell there, but then had to get the backhoe out on my tractor and dig a big giant 6 foot deep trench until I reached the area where the keys were. Took a couple of hours of digging, but in the end it was a success and the keys did not get wet.
Yes it was a dumb idea to leave that big O pipe sticking up and open right beneath the padlock. That won’t happen again, as the pipe is now been cut and buried.
   / Good morning!!!! #162,805
Thanks for all the birthday wishes.
46F, cloudy, and steady rain @ 14:00, currently under a Winter Weather Advisory. Had heavy rain earlier, LWS reports total 0.60" accumulation so far. Precipitation will change over to snow later as the front comes through.
Got hopper feeder and the two tube feeders refilled on Monday, also three suet feeders. The mix for the hopper feeder had some dried apricot bits added to it.
Five bags of garbage/trash hauled up to the road and put in the cans, also recyclables bin which was full.
Started a fire in the double barrel stove up in the shop on the way out to the road, was 42F inside when I lit it. Also got a bunch of cardboard burned.
Got several loads of crap from the garage hauled up and put inside shop including several jugs of drained oil which still need to be drained into the 55 gallon drum. Hauled two empty jugs back down + about 40' of 3/4" copper pipe that I'll probably use for the reconfiguration of the water softener and pressure tank.
Temp inside the shop had reached 60F by the time I knocked off at 17:00 to get cleaned up for dinner and that was without running the squirrel cage blower for circulation.
Did not get pallet moved down to the barn.
Was over at relatives for birthday dinner by 18:00. Had a great dinner then watched a movie we had never seen.
Came home around 22:00, ended up catching the last episode of the first season of "Three Pines", an Amazon Original crime drama series The Woman has taken a liking to.
After that started to watch another movie - Woman wasn't able to stay awake for that last one and headed to bed. She was asking how it turned out this morning. Will probably have to cue up the rest of it at some point so She can finish it.
Scored a very nice fleece blanket for keeping warm on the couch from the relatives.
Tuesday did end up being an energy conservation day mostly ... but I did get that pallet moved down to the barn and forks up to the shop.
Started up the Cub and ran it for a bit while I was doing that to clear whatever ethanol gas was still in the lines. Might do that a little more next time I'm over there just to be sure.
Checked in shop while I was up there and it looks like I should have enough 1/4" x 1 1/2" flat stock for the "wings" for all the loader implements (light material bucket, shrub bucket, pallet forks, and grapple) ... but forgot to grab the drill guide and Jacobs keyless chuck and bring them down to the house ... 🤬
Got another 2" foam board panel trimmed to height for the south wall in the utility room in the basement, also made a cut that needed to be done to accomodate some duct work.
Was unable to locate the combination square I had down in the basement. Got thinking about that last night and remembered I had one up in the dining room for the project there.
Did get all the fishies fed. The Julidochromis marlieri have cleared out an area under their rocks and look to be getting ready to spawn. Going to need to do some relocating of other fish to larger tanks due to growth.
Woman got on a tear cleaning out the pantry yesterday. Seems we have pantry moths again and She commented She needs to pick up some traps. I scored another box of raisins for the birds out of that, looks like there will be some more dried fruit of various types as well.
She headed off to Her neighbor friend's last evening for dinner and their regular get-together.
Took some hot water out and flushed out the deer feeder and stuck some whole corn in it. Hopper and tube feeders have been holding up, will likely need to refill hopper by tomorrow if not later this afternoon as the cold weather will have them feasting.
Got a couple of mounting holes drilled and counter-sunk.
More work done out in the garage, more stuff stowed away and more collected to be moved up to the shop.
Middle to north end of the workbench on the west wall cleared off and cleaned. Got the top screwed down in one spot where it was warped and uneven with the adjacent panel. Still have some more work to do on that.
Fishies all fed again.
Unsure what all will be on agenda for the rest of the day, certainly no shortage of items though.
Hope everyone is having a good Thursday ... (y)
   / Good morning!!!! #162,807
31F snow coming to end rain arrives in couple hours mostly all night,that should melt 1 1/2" of new snow.
Work day was steady pace all caught until Monday ;)
Food shopping done for the Mrs. Pickup full tank gas and park,feet up,house nice warm,recliner feels good on the back pockets with feet,safe to say not shall be accomplish this evening.
Enjoy your evening all.
   / Good morning!!!! #162,808
My dad would let me back up the truck at the freight terminal to go into parking space between two other trucks starting at a young age. One day I assumed the space was empty and did not see the little VW Beatle parked way into the parking space. It got crushed for sure. Dad had a lot to explain
Years ago with my first car, a 1975 Chevy Impala, I was driving on one of the more poorly-paved local streets and stopped for a light right into a pothole.
next thing I know, there is this dude knocking on my window saying he is sorry for rear-ending me. I thought I was getting robbed! But he was driving a Fiero and went under my bumper, and I hadn’t noticed because of the rough road. . . His hood was wrecked, I had a minor crease in my gas tank. . .
   / Good morning!!!! #162,809
If you don’t mind my asking: A) What’s your total aH storage capacity? B) What are your panels (wattage+number)? We put in a small system to run our fridge and some security lighting (4x1000 AGM; 4x375W panels) but I find that one day of rain/clouds and I and plugging the fridge into the extension cord.
of course we installed the system just before Winter Solstice, but still. . .
I need to disconnect the one ”big” 500 lumen dusk2dawn LED flood and see if that helps.
THANK YOU!
Not a problem
Totally off grid - Hamakua side, Big Island, Hi
36 Trina 280 & 16 Phono 250 in 48 volt array (fixed) 14080w
Adding 12 Hyundai 365 (4380) 18460w total
Radians GG8048A/GS4048A w GSLCs
4 FM 80 charge controllers
Hub 10.3
FNDC w/3 shunts
Mate 3s
OpticsRE - MMKL - Ninole Hi
15 SimpliPhi 3.8 (57kw) (1125 AH)
14Kw Kohler 14RESA Propane
Charging Only
2FX3048T
Hub
FNDC. - shared shunt feeds from Radian FNDC
Mate 3s
10Kw MEP 803a Military gen
Honda EU7000i
Davis VantagePro2 Wx Station
On line at: Personal Weather Station Dashboard | Weather Underground
We manage to suck up about 30kwh/day.
   / Good morning!!!! #162,812
Not a problem
Hub 10.3
FNDC w/3 shunts
Mate 3s
Charging Only
2FX3048T
Hub
Mate 3s
Honda EU7000i
Thank you! That is significantly larger than our setup. I believe my first upgrade will be to the storage capacity. . . On the never ending To-Do List. . .
   / Good morning!!!! #162,813
I can top that one. We hit a bull crossing 1960 in the Spring area of Houston in our Chevy Impala 1979. Messed up the front part of the car. Calling to report it we get this what make and model was it we hit. It is a bull mam. Yes but make and model please?
   / Good morning!!!! #162,814
In case we get thirsty they are getting ready for us. This is the old firehouse in Middletown converted to a distillery. They were getting deliveries of barrels today. This was on the way back from the red barn sandwich place
   / Good morning!!!! #162,815
Not much sleep at the farm last night. Always listening for mice. And other issues. We left a little earlier than planned due to incoming storm. Was flying the drone and heard thunder, looked at Radar. Holy cow, storm covered most of Ohio. Was in real heavy rain, fog, hail on way home.
So home now, relaxing.
   / Good morning!!!! #162,816
This afternoon I was taken stock of the black smith tools that I want to set up in the lower floor of the barn. The main anvil is a Hay Budden NY from the 1800's and is in very good condition. It has good rebound and ring. The small one is a Columbia. The tongs are collected from an old blacksmith shop going out of business as well as two leg vises. The tin anvils were collected from an auction as well as the ring anvil and swage block. The forge works quite well on black smith coal.
   / Good morning!!!! #162,817
That is some really cool stuff.
   / Good morning!!!! #162,818
Thanks for the mini-split info. I will definitely do more homework.
Only one item off the list today, flushing the tankless WH. Went good, not too much crud in there, just made the flush water cloudy. It was a bit more involved than I anticipated, even though I read the manual 3 times.
Time consuming because the cleaning solution has to be circulated, then rest, then circulate, continue for 1-2 hours.....
The water supply input filter was very clean, no sediment build up at all.
Glad that job is done for another year. At least I know what is involved for next time.
Didn't feel like going up to the store for the filters that came in.... tomorrow...
Wifey made chicken soup from the Costco chicken. Delicious! Oh, and scratch made dinner rolls.... mmm, mmmm, mmmmm.
Time to put the feet up....
   / Good morning!!!! #162,819
Fritz, neat tools. Especially old tools. Put them to good use!
Kilroy, hope you got the mast up today.....
BEF, glad you got home despite the storm. Do you remember what day it is?
I usually look at the Ipad to tell me.....
   / Good morning!!!! #162,820
Good early (Friday) arvo. Overnight Low of 19.8C and it's presently 26.4C, lightly overcast with a gentle breeze. Summer is finally here, although that brings its own problems such as the threat from bushfires. Oh well, that's 'life', eh?
A nice sleep-in as I have no more guests. A fair bit of bedding/towel dhobi to get through and, of course, I need to do a run into town as the PO alerted me to a delivery. Fortunately there are a couple of things that I can do whilst I'm there.
Depending on time, I'll either chain-harrow/mulch Paddocks 3 & 4 later on today or tomorrow. I'll need to grease the FEL too, as I've got a hay rounds task to do Sunday arvo.
Toro Greensmaster 3150-Q Riding Mower (A56859)
Toro Greensmaster...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A59823)
2015 GENIE...
Great Dane Van Trailer (A56438)
Great Dane Van...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
2014 CATERPILLAR 930K WHEEL LOADER (A60429)
2014 CATERPILLAR...
