Good morning!!!!
   / Good morning!!!! #159,881
Pic of the volcano:
   / Good morning!!!! #159,884
volcano activity is beyond my comprehension ... thanks for posting, stay safe
   / Good morning!!!! #159,885
I am back from North Bay. Gas was $1.479/L or $5.59/ US gal. Took $69.oo worth, so my fuel conservation goal has been met for November, under $100.oo.
check, here is the page at Best Buy. https://www.bestbuy.ca/en-ca/search?search=ups+battery+backup
Tiger direct has them too IF you are close to Markham, I think the Markham store is still in operation.https://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=ups+battery+backup
I also use a surge protector on both fridges and water softener. Just a cheapy one, plug it into the outlet and plug the appliance into it.
   / Good morning!!!! #159,886
I’m such a mileage slackard
Less than 2k on my exercise bike this year
Less than 12k on wife’s 2016 Pilot since 2016.
Less than 20k on my 2019 Ridgeline since 2019.
   / Good morning!!!! #159,887
as the tail end of this system swept through, rain stopping with a lot of wind, the power went off.
Annoying that so did my pc so I clearly have something not turned on properly with my UPS. Or maybe it's only the screen not coming on.
Need to check the plugs.
so propane gen wailing away, 453cc of air cooled din and vibration, joining the rest in scaring all the wildlife.
this time I am prepared, or at least I think I am.
I installed a gizmo on the main panel to set off an alarm when street power comes back on. I had to throw a switch to turn the alarm on, not automatic at all.
Most of my neighbors have gens so hard to eyeball when power comes back on.
turned off electric hot water heater, it should run everything else with about 45amps. Oil furnace has a draw, and something just made the gen gulp and get loud.
Time to inspect. I want to see what just kicked on. And just kicked off.
   / Good morning!!!! #159,888
Blue dot is us in relation to eruption
Can’t see the show as Frits posted.
Still blue sky here, but with some haze.
   / Good morning!!!! #159,889
Not sure I even hit 1k on the bike.
I haven’t even put gas in my new Mazda. Been driving the Subaru.
   / Good morning!!!! #159,890
The rain is gone, sun even came out some. Very windy at times, then nothing at times. Wind has cranked up again.
Power is on. Starlink internet went down for 21 minutes but is back.
Pellet stove full but still off 47° now, high was 53°.
Might make Bible study tonight. Haven’t been there in 2 weeks due to sickness.
Kitty enjoying my lap.
   / Good morning!!!! #159,891
   / Good morning!!!! #159,892
We are down to two vehicles:
Sprinter Van 180,000 miles
Ford dually 350 50,000 miles
Both drive like new
   / Good morning!!!! #159,893
all is well. My old 110V POS water jet well pump in basement has a horrible amp draw when it kicks on. Blinks the lights in entire house.
Gen doesn't enjoy it at all. But good to run the gen under load. 50A rv style cable coming into subpanel running most of primary panel. But gen only puts out about 45A at 240.
I turned off the dehumidifier downstairs since I'm also running the new freezer. 3600 rpm gens are hard on my bad ears. I may put my headphones on.
Just have to listen to the alarm buzzer going off.
This noise is why I'd really like a solid state alternative.
   / Good morning!!!! #159,894
Turned on my dish network receiver for the first time in weeks. It says channel not authorized on all channels. So I just did the unplug reset, waiting for it to come back.
Last time I tried it didn’t work either, except then it wouldn’t lock onto the satellite. Apparently it’s finding the satellite now.
I really need to cancel dish and save $110 a month.
   / Good morning!!!! #159,895
PECO says maybe power back on 7:30pm.
best use of a gen, keeping the xmas lights on
that big fella is going outside tomorrow .
   / Good morning!!!! #159,896
David, you are on the right side of the island and as far away as you can get from the vulcano. And I believe the flow of lava is away from you as well. As long as prevailing winds are in your favor you are good
   / Good morning!!!! #159,897
Gas today was $2.74 at Costco here, closer to $3 /gal at the regular gas stations.
For surge and low voltage protection, I use these:
If power drops (low voltage/ brown out) they kick off. If there is a surge, they kick off. They will stay off for a minimum of 3 minutes until power becomes "stable". I found packs of 4 or 6 cheaper on Ebay.
The small investment saved our portable heat pump A/C unit which was running during a quick chain of a power on/off --on/off -- on/off. The only downside is that if there is a power draw from whatever is running when the surge happens, the protector is now trashed. It only permanently gets trashed for the high draw items though.... like a refrigerator or A/C. Other light draw items, it just trips, then comes back on.
   / Good morning!!!! #159,898
I do want to get an UPS for the pellet stove. If we loose power, the program for timer / scheduled burns gets erased. Don't want that to happen during the night. We could get mighty cold......
Some are quite expensive.... others so cheap that I am afraid they aren't any good..... any suggestions? Looking for around a 1500W capable one.
   / Good morning!!!! #159,899
Good (Thursday) morning. Overnight Low of 11C and it's presently 15.7C... temperatures are actually dropping since I awoke. It's overcast with a steady breeze. No rain in my gauge to end November's total (104.3mm) but the aerodrome had 1.8mm.
After my trip into town yesterday I got stuck into chain-harrowing, then 'mulching' Paddocks 6/1/2. The only problem with running the Z-turn over the dried horse droppings is that I get covered in a fine layer of horse-droppings-dust.:( Even after blowing/brushing myself off I still have that horse-poo scent on me. Fortunately, it's a nice smell (at least to me it is).
I'm sure that I'll get up to something today. Take care all.
   / Good morning!!!! #159,900
I do want to get an UPS for the pellet stove. .
I’ve thought about it but never did. I ran my pellet stove once on my large generator and since then the control board is a little wonky, it won’t let me shut it off. To turn it off I have to turn knob to off, then open the pellet lid, which has a sensor and will turn stove off if left open.
Tiger loves the heat.
2019 KOMATSU D65WX-18 CRAWLER DOZER (A60429)
2019 KOMATSU...
2005 Mitsubishi Fuso FE84D Auto Crane 3203 PRX 3,200 LB Crane Utility Truck (A59230)
2005 Mitsubishi...
2014 Aerway Aerator (A55973)
2014 Aerway...
208735 (A60430)
208735 (A60430)
UNUSED RAYTREE RMSC78-78" HYD SOIL CONDITIONER (A60432)
UNUSED RAYTREE...
2017 Toro Workman HDX-D Diesel Utility Cart (A59228)
2017 Toro Workman...
