Good morning!!!!
   / Good morning!!!! #156,801
Thanks will check out the thread.
It has strong compression, caps lets in air ok, starter fluid does not make it run despite having good spark whatever that means
Spark+gas+air+compression=explosion
so I'm baffled, but I often am.
   / Good morning!!!! #156,803
me too will check it out more carefully tomorrow. The wire for the stop switch may be the problem. We will see
   / Good morning!!!! #156,806
Pressure test the crankcase. If the seals are worn and leak, it sucks air and makes the mixture too lean. You can close off the exhaust port by putting a piece of inner tube over it and bolting the muffler back on. You will have to make a flange that bolts on in place of the carb with a nipple to attach your test hose. You should be able to pump it up with your hand pump’s pressure side and make sure it holds pressure.
   / Good morning!!!! #156,807
I will check the impulse line first hoping to find a leak before going to next step
   / Good morning!!!! #156,808
many times, the thin diaphragm tears in the one end of the carburetor. Sometimes its the bulb and it's line.
Is the air pressure holding, a test of the diaphragm?
   / Good morning!!!! #156,809
Yes the pressure is holding in both the tank and carb
   / Good morning!!!! #156,810
Couldn’t have the room doors open direct to garage, but If you put in firewall per code I don’t think they could deny it.
I would put bath in a corner, then maybe the bedroom and kitchen.
Yes, I would put the bathroom in the corner, then bedroom (would have an ensuite), then kitchen.
I think the firewall could be eliminated though, by simply making the bathroom as the only room with direct access to garage. Saves all that unnecessary expense.
garage leads to bathroom,
bathroom leads to kitchen
simple, code approved, and cheaper :)
   / Good morning!!!! #156,811
50F and clear, supposedly headed down to a low of 40F overnight ... but there is a frost warning so ...
Moved Woman's hibiscus into the garage along with the coleus and shut the door. Not enough energy to mess with anything else. Probably will not frost.
High hit 63.9F here today. Tomorrow should be a little warmer (calling for 66F) and a little less windy.
Ten Day showing only one day approaching 25% chance of rain in the period, most days showing less than a 10% chance.
Got geo-tex and vapor barrier unloaded out of the van, left the 3 sheets of foam board in it since it was fairly windy. Easy enough to unload them at any point since they weigh next to nothing.
Refueled Kubota.
Got another couple of pallets moved out of the barn.
Spent most of the day screening clay though. That will solve two problems: 1. running low on screened material to use for fill, and 2. gets rid of the big pile over on the south side of the barn, which will give me a place to stage/store pallets.
Probably 70% of the piles (wet and dry) have had their initial screening. Have been putting the material to be rescreened behind the barn where it will catch some sun which should help to dry it out.
Knocked off a little early (before it really got dark) as it was feeling just a little chilly with the wind as the sun went down.
Did not check the hopper feeder today ... but the birds were still on it when I came inside for the evening.
No customers in live trap either.
Starting to get some decent fall colors:
Expect we are about 7 to 10 days from peak colors.
Woman brought home a pizza and wings from Dominos, was ok.
Bowl of Peanut Butter Swirl ice cream and catch some of the 2nd half of the Tampa Bay/KC game then likely will place the order @ Menards for the rest of joist hangers and then grab a shower before I hit the rack.
Hope everyone had a great Sunday ... (y)
   / Good morning!!!! #156,812
Good evening all. 48ºF for the start, light breeze, clear sky. Light wind, mostly clear sky, and high temp was 84ºF. Chapel to start day, then made pancakes for breakfast. Did some energy conservation, and swept off front porch and around gold cart door. Put boat on truck, cleaned out leaves, and recoiled anchor line and propped up motor. Early launch to chase shock boat for more carp removal in the morning.
PJ Nice weather. Good to here you got a nap in :) Good luck with barn remodel.
Don looks like a mini pumpkin chucker.
Drew thanks for the review on barbecue flavored jackfruit.
Bird glad the medicine is working!!
Buppies glad pond is full. what is normal temps after Indian summer?
Scotty I thought you were trying to sort out small rock from the bigger rock.
Thomas good plan for today.
Billy that is a flat temp profile. Glad you got hike in.
Roy hope you are eating better.
Scaredy sorry about no start on ZTR. Hope wife made it home. I like your house plans for Dennis.
Frits glad weedeater running , good luck with chainsaw.
Kyle do they do any checking for mechanical aptitude for the students as they enter the program?
Frits thanks for link.
Paul glad B-day went so well.
Buppies good pics of storm damage.
Ken hope new washer works out for you. Got earplugs for jam session?
Rich sorry first race a wash out.Better luck at neat one.
Drew hope you don't wash away.
Bird all I understood was there are 4 active ingredients and are less then 7% good stuff.
David hope you conserved much energy.
RS Frost advisory this early, ugh. Sorry about ball. Hope you made progress on agenda.
Frits hope diaphragm is it.
Thomas sorry about no back pack blower for leaf season.
RS nice progress glad you got a lot of screening done. Nice pics.
prayer for all, especially Jay/Peg, Kyle's daughter and family drama, /mom's breathing, /learning new job, /friends upcoming new baby, Bird/aging issues/, Don /mom's pipeline process, , Roy /palpitations, /angina, /alligatoritus, /wife ankle,recover from getting sick, Billy /wife back & hip, mom hypertension & congestive heart failure, David(moss) /remodel, /divorce, Buppies /new skin cancer spot and treatment, /elbow healing, /wife knee healing, Thomas /gout, Phil /reflux, /wife's eyes, Frits/ daughters hip replacement /veteran son with mental issues, Steppenwolfe/son-auto immune disorder, Grev/wife's eye, Ted /knee recovery, /retirement, /family issues, /wife feeling bad, Lou / eye issues, Doug and wife/health issues, /nerve and pain, / wife headaches, David(sadamo)/Sophie's new eye surgery recovery, Chris /neighbor's granddaughter and Covid issues, Scaredy/shoulder dislocation, /wife not feeling well, /marriage, / friend stop drinking, Paul/ wife's healing from back surgery, Gale and KY/ tornado victims, Mike /5 year plan, Dennis /retirement plans and land purchase and development, / brother "alligallyitus" and back in hospital, Drew /foot heel issues, /friend cancer diagnosis and recovery,Mike /spine injury and recovery, Scotty, /back pain, Helogabals /second opinion, /wife's friend situation, Ukraine war, and Country.
   / Good morning!!!! #156,813
2022-10-03, 0352
34° right now...high about 60 today...
Stepdaughter gone for the week...might stay home with the wifey
   / Good morning!!!! #156,814
Goodmorning !
Nice, fresh morning here. 4-6ºC
Forecasters are saying something about a nasty cyclone for second half of the week. We will see.
Anyway, was a hell of a weekend
I am making a cabin for my company.
Friday builder put wreath (actually which would be the correct word for that thing ??) on top.
Here we have tradition, that when builders has reached highest point of the building, they put that "crown". then customer has to drop the party. if not, builder fix there filthy old trousers or something nasty like that :sneaky:
Agreed for tomorrow to throw pizza party there
Actually thinking to make my own thread how we are making such barn. Might be interesting for you
Saturday morning wake up early, while spinning in bed decided to go to fancy baker's shop. Spoil kids and wife with fancy donuts and croissant
After morning coffee orgies went in garden to check on mole traps. And there was my first prey ! That little ******* has spoiled my lawn for so long that I didnt feel sorry at all. Has tried all possible repellents, especially because near me is wast territories where he could dug all day long.
Saturday we had national elections for Parliament. Those I voted for went in first place. Not bad, even considering people has voted for ~ 10 % complete populist idiots and another 10 % openly russia friendly dudes. Anyway majority voted for the same politics we used to have and i am happy for this
At evening took my wife to movie. Silly comedy - Ticket to paradise, but she liked it. happy wife = happy life :)
Read news from Ukraine. It seems that those brave guys are doing well. Actually surprisingly good.
Sunday was just for regular errands - mowed grass (without mole mounds !), washed cars.
Wife ordered indian junkfood. Love hot food with cold beer. Good feeling to eat whatever I like, without worrying about belly issues
Today have to run company issues, make some preparations for tomorrow's "party".
Hope you guys will have the same nice day !
   / Good morning!!!! #156,815
good morning all
44 out now, still raining lightly. And more to come for another day or two; system seems stuck off the East Coast and not going away
coffee is brewing, then I'll see how motivated I am
radishes are starting to peek out, hope to have some in about a week, tomatoes are at the end, have to keep a close eye on freeze warnings
lots of peppers still growing
hope the start to everyone's week goes well
Helogabals enjoy your party
   / Good morning!!!! #156,816
46 going to 54 and rainy/windy. Today may set a record for this date...not the lowest temp ever, that usually happens at night, but the lowest High temp for the day. Don't often think about this measure.
Kyle, glad you're getting a chance to motivate some young folks in manufacturing.
Buppies, sorry your beach got hit hard. Thanks for sharing pix.
RS, nice colors. Ours are looking like that, too. Lots of leaves have fallen, too. Last hummingbird left Saturday, and last crepe myrtle bloom...Thay always seem to coincide.
   / Good morning!!!! #156,817
Good morning, low temp was 27 and the high is gonna be about 59°F and sunny. Wind NNW 2 mph.
This cold has kicked the stuffing right out of me. My get up and go has got up and left and isn't coming back anytime soon.
For three days last week it was chicken soup, because I could only swallow liquids.
I coughed so much my chest hurt to cough, but couldn't stop. I got into some OTC cold pills that seemed to help some. An hour after taking two I would lay down and get an hours' sleep before the incessant coughing would wake me up. I got better sleep in my chair sitting upright. I also got into some cough syrup that the dosage was 1 tsp 3 times a day. The bottle had one of those little stoppers in it so that even little kids could pour a teaspoon without making a mess. The bottle neck is one inch wide so the little stopper of flow restriction went into the garbage. Seeing as I am the only one using this syrup I drink it right out of the bottle. It is a non-drowsy formula and made in Germany. Does it work? I don't know but it tastes good.
I phoned my manager last Thursday and begged off returning the truck on the weekend. The annual safety is up the end of October, so as long as I get it down there before that they will be happy. Probably take in down this week. He told me that he didn't need the trailers, so they could stay where they are for right now.
That is all my woes and life complaints for today.
Have a safe day all
   / Good morning!!!! #156,818
Low was 45°, only going to 55°
1.8” rain total since Friday, more predicted the next 2 days.
I have not watched any tv of what Ian did, just what you all have reported here. I just never turn the TV on anymore.
Have a good day everyone.
   / Good morning!!!! #156,819
Morning all, 45 going up to 55 and still raining.
Forecasters said up to 1" , gauge says 3" so they were not very close.
Need to empty the gauge as it only holds 5" of water and they are calling for 1" again today.
Deer are laying in the backyard trying to stay warm.
L4N - feel better soon
Trench and other water draining/redirecting swales working well.
Dog is getting better.
   / Good morning!!!! #156,820
Mostly, I'm not sure about the high school students. But at our facility, they have to have at least 1180 at a minimum on SAT, preferably higher...and if they don't cut the mustard they get cut. But we are training young engineers. They need to know the general scope of mfg, not necessarily how to do most everything machining wise. I'm still learning myself at my age.
They get manual training first, and then exposed to cnc training. I hope to improve their cnc training course.
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2014 Dodge Charger Sedan (A59231)
2014 Dodge Charger...
2012 International 4300 Reefer Truck (A56438)
2012 International...
2003 IC Corporation 3000IC School Bus (A59230)
2003 IC...
2022 John Deere Z930M (A57148)
2022 John Deere...
2018 HINO SA (A58214)
