Good morning!!!!
/ Good morning!!!! #146,981
2022-03-09, 0525
20° right now...high in the upper 30's today...
UTI has alleviated somewhat and as some suggested, laid off the coffee and booze (except for beer, which seems to help, actually). I should be getting an antibiotic prescription filled today.
Still working from home for the next day.
Slow and easy get some rest Roy.
/ Good morning!!!! #146,982
Thomas, sounds like a real nice mailbox you had. Sorry it was damaged. Can you repair it?
Stop at granite store where we purchase posts show them picture and ask if they could fix...nope,new post about $400 :oops:
/ Good morning!!!! #146,984
33F snowing ending around midnight.:(
Gallon gas went another 10 cents over night 30 cents in 3 days...$4.39 gallon.
Busy day...dump run,critter food stops,build temp mailbox stand put in place,service and tuck away pickup snow plow until next winter.
No plans this evening other than feet up.
Enjoy your evening all.
/ Good morning!!!! #146,987
Rockbridge is a very pretty area.
Didn’t hear back from real estate agent yet..
I think this will sell quick, although current pics show trees has grown up a good bit since google photo. Google shows it mowed, pics show lots of small trees growing. Apple Maps shows it getting overgrown. Owners live above culpeper va. Another 20 acre lot behind it, totally woods. That owner likes in Yorktown.
This one is almost 16 acres. On a ridge going up the mountain, not flat but looks like ridge top is flat.
/ Good morning!!!! #146,988
I wonder about the adhesives they use on these granite counter tops, drill it first and a stainless steel pin?
/ Good morning!!!! #146,989
They have a special glue and fill in with mortar. That glue is amazingly strong.
Think 3 or four small steel pins would stop it from twisting over time.
Tile place will have the glue and anything else you need.
Seems like this would be a bit under $40.:)
Lost power for an hour or so, PECO fixed it pretty quick. Generator is getting a work out though.
/ Good morning!!!! #146,990
Bore out 6 inches each side, steel rods, epoxy?
Posted before reading other replies
/ Good morning!!!! #146,991
Drew is there somebody who specializes in this might have a solution?
/ Good morning!!!! #146,992
Maybe, thanks. 3 ENT's said have a nice life, nothing they could do for me. My left ear still feels like it's filled with fluid three years later.
I was told there was no cure for Menieres. And no known cause.
I'm going to try the noise cancelling earbud and see if that helps.
35 out now, 52 tomorrow.
/ Good morning!!!! #146,993
It's not just the weight, it's how the weight is distributed in the aircraft...
Any airplane that is used to carry paying passengers has to have an actual weighing every three years where the fuel is drained and the cabin emptied, then put on load cells and leveled. The weights from the individual load cells are then used to calculate the center of gravity. Any repairs or equipment changes in between weighing are documented, and generally a revised weight and balance report is generated by calculation rather than weighing.
It is eye opening how small the actual center of gravity range actually is. This airplane is over 50 feet long, the allowable CG range is less than 10”.
/ Good morning!!!! #146,994
mostly, you know if you stopped shaving you wouldn't have a blocked up drain from the shave cream AND wouldn't have the expense of blades either. Something to think about.
/ Good morning!!!! #146,995
Good evening, guys, Sharon’s surgery on her broken arm went very well today, and she is now resting comfortably back at home. Very good prognosis, very good outcome, couldn’t ask for more.
And Bill, thanks for the suggestion review using ashes on ice. I had forgotten about that! And since we have a fire in the fireplace every night, we generate a lot of ashes. One nice thing is ashes are not heavy like sand.
Thanks again for all the well wishes, and happy birthday Mrs. PopG!
/ Good morning!!!! #146,996
Glad to read the surgery went well, James 🤙
/ Good morning!!!! #146,997
Good evening all. 24ºF for the start, partly cloudy sky, light breeze. Light wind day, minimal clouds, and high temp was 57ºF, DP 22ºF. Clean ashes and restoke the insert, putter for a bit then back to the mower. Did get drive shaft bearings replaced, old ones had over 1/8 inch ply. Couple more hours to finish, oil change, blade sharpen, air filter change, and spark plug. Thinking about waiting on blade and filter till after scalping. Did get bike ride in, no nap :(. Getting 1 last load of wood tomorrow. Gas prices have gone up this week, 3.90 to 4.09 in area.
Kyle Good luck with cylinder, gas here is close to or over $4/gal.
Dennis good luck with interview.
Doug sorry about tractor, hope needle help.
Roy good to hear feeling better, more than 2 beers.day counter productive to hydration efforts.
Billy good to hear you got some rain. Glad tablet working better, I have no tablet experience
James praying for successful surgery. sorry so slick there.
Drew hope Costco visit went well.
Buppies thanks for the info. getting plenty of water now, care to share :)
Drew thanks for the link. We have had very low humidity this winter and no extra flu this year.
Buppies we have a roller coaster going here.
Ken glad boss happy with new light. good luck with tire track eliminaton.
Paul glad FAA mtg went well. Please tell the missus happy birthday.
Bill sorry about the meeting, glad plowing went well. sorry about the chains wearing out.
Don look forward to floow up. hope no frost damage.
PJ let us know if it works. Weight data helps determaine balance/CG in airplane, inproper CG calc. more dangerous than just overweight.
Dennis you are young :)
Randy glad you have the time to BS each other, Hope all clubs meeting is productive.
David glad to hear progress continues
Drew sorry for the lack off help, good luck with the noise reduction ear piece.
David glad beer helping with kidney stone prevention.
Thomas sorry about no repair possible. Sorry about gas prices, we have 40-50 cent increase in 1 week.
Drew sorry about the lack of progress. Wonder if new earbud would be any better.
Paul not much CG movement allowed.
Bill boss like clean shaven, 3 days growth rubs her cheeks raw :(
prayer for all, especially Jay/Peg, Kyle's daughter/friend PT from Covid, /mom recovery, living alone, Bird/aging issues/, Don /mom's pipeline process, Randy/FIL living alone adjustments /MIL Covid /son's FIL death /new cancer surgeries /cataract surgery, Roy /palpitations, /angina /UTI, Billy /wife fall, David(moss) /remodel /divorce, Buppies / wife head wound healing, Thomas/gout, Phil /reflux, /wife's eyes, Steppenwolfe/son-auto immune disorder, Grev/wife's eye, Ted/knee recovery/retirement, Doug and wife/health issues/nerve and pain/ wife's eyes /rib, Ken/aunt fall injuries, David(sadamo)/Sophie's new eye surgery follow up, Chris/neighbor's granddaughter and Covid issues, Scaredy/injuries from fall, Paul/ wife's disc issues /dog seizure, Gale and KY/ tornado victims, Mike /5 year plan, Dennis/ brother "alligallyitus" and improving, James /wife's fall and recovery, Ukraine war, and Country.
stay safe and healthy you all.
/ Good morning!!!! #146,998
Well heck I'm up early, my wife woke me up to see the damned bear that was destroying the bird feeders,
got that sob run off and wide awake for now.
Looking I say a yearling just under 200 pound.
reached up and tore one feeder that hung off the eave of the house, got up on the deck and pulled down a suet feeder and big seed feeder.
Destroyed all of them, took off when I hollared at him.
This is a picture from an Arlo cam that looks out to the driveway.
/ Good morning!!!! #146,999
Good morning, low temp is 16 and going to a high of 25°F. Wind W 7 mph. A mix of sun and cloud.
A town run is in the cards for today. After that conserve energy.
Income tax is all done up and ready to go to the accountant, I will mail it 'registered' today while I'm in town.
Have a safe day all
/ Good morning!!!! #147,000
2022-03-10, 0527
25° right now...high in the mid-40's...
Winter storm watch just post for Friday into Saturday...5 to 10 inches...
Wife and stepdaughter heading to Boston later this morning to pick up another stepdaughter and her daughter
UTI seems to have passed. I got the antibiotics yesterday, but I think the beer did the job...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
2005 Kobelco 135SR Hydraulic Excavator (A59228)
2005 Kobelco 135SR...
UNUSED FUTURE ELECTRIC WET POLISHER (A60430)
UNUSED FUTURE...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
2006 Acura RL Sedan (A59231)
2006 Acura RL...
Toyota SR1-BET35 3,500LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
