Good morning!!!!
   / Good morning!!!! #138,321
Roy, I'd just make sure your tractor's hydraulic gpm is at the high range of snowblower spec, not the low end.
The hydraulic snow blowers (at least the one that Quick Attach sells) runs off a hydraulic power pack powered by the PTO drive...totally independent of the tractor's hydraulics
   / Good morning!!!! #138,322
Good Morning.
It’s 66 here in Wichita, going to 96
It’s also 66 at home in PA, but only going to 82.
The heat out here really doesn’t matter, as I’m cooped up in a building that’s the temperature of a meat locker. It feels good to go outside.
Not much to report on unless your interested in how to program a flight plan into a Collins ProLine FMS. It’s nice that there is a good dynamic in our class with the two class mates and the four of us. We usually all go to lunch together and socialize, no class work.
Drew, take a look at-
Roy, not sure about the Deere, but I can take the loader off my Kubota L6060 in a few minutes, I never leave it on to mow. But the mounts stay on the tractor. It’s actually about the same time to drop just the bucket. Having the single multi port hydraulic connector is a huge time and labor saver for that chore.
As far as the snow blower, I wrestle with the same thoughts, but the reality is that no compact tractor really has the hydraulic flow for a blower, so the rear mounted, pto driven hydraulic unit is a necessity, given the cost and complexity, and having to run the hoses up front to the blower, I’ve elected to stay with a 96” hydraulic angle blade. It’s not ideal, and large snows may require that I put a bucket back on to move some snow, but it works. I think that I would look hard at the Erskine front mount PTO driven one if I decided I needed one. The shaft is a much more efficient way to transmit power than hydraulics as well.
I have also given some thought to finding a used 3pt and mounting an engine on it and a SSQA plate to make a self powered front mount. But so far I haven’t acted on those thoughts, and probably won’t.
   / Good morning!!!! #138,323
Morning all! Gorgeous day here at 63 and partly cloudy. High 70's expected with low humidity!
Wife and I are doing fine. We both are enjoying the summer so far.
I had tree roots getting into my driveway and brick walkway so this was the week to make it gone. Tractor did great at getting things cleaned up. I needed a bigger machine to pop the stump out though.
Hope everyone stays safe and healthy!
   / Good morning!!!! #138,324
68°F and .08 inches rain.
Play mechanic a bit today. Install new seat belts on the Scag, new plugs etc in the old Craftsman.
Might watch the NE - Miami game.
Probably take day off from caretaker unit.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #138,325
87 heat and humidity coming back
   / Good morning!!!! #138,326
Simply replace the blade and affordable brake cartridge and your saw is operational
now I get it. Kind of like an air bag going off and once used the whole mechanism is replaced.
In this case an aluminum brake crashes into blade and apparently stops blade in microseconds.
Blade is destroyed though, sacrificing itself and hopefully saving the finger.
Which is why you have to replace the blade and the brake cartridge each time.
Hopefully not often...
all due to conductivity
how could you use this saw to cut metal and not turn off immediately?
granted not a tool normally thought of cutting metal vs wood.
I wonder if there is any conductive wood that would fake it out...
   / Good morning!!!! #138,327
The loader is easy to remove, just a pain to align once it's off. Since I don't mow (except for the field) the lawn (Zero-Turn is much faster), not much need to remove the loader any more
As far as the snow blower...really depends on one's circumstances. I lived in PA (South-central...Windsor to be exact) for several years and we knew every 3-4 years, we'd get hit hard with a good 10-15 inch storm. That's a pretty typical accumulation in Vermont every winter storm. Something I wouldn't even consider in PA is something that could be a necessity in New England. I never owned a snow blower (walk-behind or PTO driven) until we moved here.
I recall looking in to a job in NW PA (Erie area) years ago...probably would have needed a snow blower if I'd gotten a job in that area
   / Good morning!!!! #138,328
A mild cloudy day, 89˚F, hoping TS Nicholas will bring us some rain.
Good news for those who survived Covid.
"Last fall, there were reports that antibodies wane quickly after infection with the virus that causes COVID-19, and mainstream media interpreted that to mean that immunity was not long-lived," Ellebedy said. "But that's a misinterpretation of the data. It's normal for antibody levels to go down after acute infection, but they don't go down to zero; they plateau. Here, we found antibody-producing cells in people 11 months after first symptoms. These cells will live and produce antibodies for the rest of people's lives. That's strong evidence for long-lasting immunity."
   / Good morning!!!! #138,329
Earthworks have started for my new barn today. Cutting out and levelling taking place now and base crusher dust and reinforcing to arrive later this a.m. Good to see it all happening at last. I have done some drone aerial shots etc so will post those a bit later on.
   / Good morning!!!! #138,330
Dennis, do you know how Sawstop works? Light beam? IR? proximity? how does it evaluate friend (wood) or foe (finger)?
I don’t know, I had not heard of it before seeing his.
He had some nice tools, like a 12” jointer, and a big lathe. He turns a lot of really nice wood bowls.
   / Good morning!!!! #138,332
75F and fair @ 21:15, heading down to 68F for the low. Was quite breezy today, made the heat not seem quite as bad.
Started off using the Stihl pole saw to prune low-hanging branches along the driveway. It will need some touch up, after I clean up the limbs I took down.
After that removed the box blade and quick hitch from the Kubota and then mounted the PHD and 2' auger.
Ended up drilling 3 holes up along the road (for oaks), plus one where the old redbud that died was (possibly for another redbud) and 30 holes along the west property line for the forsythias, with properly another 4 or 5 still to go there.
One hole attempted that I could not complete, due to running into a large sandstone rock which will have to be dug out. From earlier today:
There's still another 4 holes or so to dig down here around back of the house (2 for peach trees, 2 for redbud, and maybe one for another magnolia)
And probably a few more if I really think about it.
Have two more days of nice weather before the day with a good possibility of rain comes in (Wednesday) Will need to get the drilled holes filled with screened compost so it can settle with the rain and work on soil compaction over at the barn and get the dirt there tarped before the rain arrives.
Took a lunch break around 15:30 and ended up staying in for a while since it was pretty warm out ... and to let my neck recover ... 😫
Hope everyone had a great day ... (y)
   / Good morning!!!! #138,333
Good evening all. 70F for the start, clear sky, light breeze. Light wind day, sky stayed mostly clear and high temp was 87F, DP 60F. Chapel to start day, then made wife breakfast. Conserve energy rest of day. Going to pass on mowing this week. May take weed eater for a walk. Indian creek will stop running soon if no rain, barely a trickle now.
Covid update: Cooke 3810 confirmed cases, 94 active cases, Montague 2278 confirmed cases, 82 active cases, Grayson, 13773 confirmed cases, 372 active cases. Cooke 0, Montague 0, Grayson 0, new cases.
Dennis great pics, sorry about the truck on your dad's hayfields. Trail looks like super highway.
Ron sorry about limb fighting back. Hope plywood outdoor rated. I missed the king of hill competition
Roy Sounds like your wife has bonded to Margeaux.
Roy sorry about wood stove, we both love our insert.
Drew glad oil change went well. Yes, wont take that long to remove finger. Sorry about shed.
Eric glad weather more seasonable, good luck with wild flower patch.
Billy glad you got some seat time and food plots planted.
Thomas glad show was fun. Grandparents day, no calls from our grand-kids :(
Drew those kinds of rivers will eat us alive.
Paul I don't think I will even see a Collins Proline FMS. thanks for the blade stop info
Phil quite the project. looks nice after cleanup
Buppies heat and humidity returning here as well.
Don we have slight rain chance Tuesday/Wednesday time frame. thanks for natural immunity info.
Doug must be exciting to get barn started.
Dennis different looking pears.
prayer for all, especially Jay/Peg, Kyle's daughter/wreck injuries not healing, Bird/aging issues/, Don/ring bearer/back broken, Randy/FIL living alone adjustments, PJ/FIL fall and stroke, David(moss)/remodel/divorce, Buppies/new cancer on arm, Thomas/gout, Phil/reflux/wife's eyes,Steppenwolfe/son-auto immune disorder/Dad's passing, Grev/wife's eye, Bill/DIL home care, Ted/knee recovery, Doug and wife/health issues/nerve and pain/ wife's eyes, Ken/uncle, Drew/tendon healing, David(sadamo)/Sophie's eye surgery/Back issues, RNG/fire season, Chris/neighbor's granddaughter and Covid issues and Country.
stay safe and healthy you all.
   / Good morning!!!! #138,334
RS, good luck with the wildflower project.
Thanks - I'm sure we'll need it ... :LOL:
For years my wife has been spreading flower seeds from our hay meadow to a patch of grass close to the house. Every year it grows terrific grass, yet very few wild flowers ever germinate.
That seems odd.
This winter I will be allowed to kill off the grass with glyphosate and like you, get down to bare soil. Pretty sure that will allow lots of seeds to grow, just not sure what - could produce the finest ever crop of thistles :)
LOL ... no shortage of thistles here ... (y)
   / Good morning!!!! #138,335
Pears? Lol
Those are Buckeyes.
   / Good morning!!!! #138,336
Did enjoy taking dad for a spin around the farm in my truck. Also played him the sermon I gave at church a couple weeks ago.
But sad to leave.
Then I drove to my grandfathers farm, and the trees have overtaken the field, house and barn
How I enjoyed playing there as a kid. Sad to see the state it’s in.
Then stopped at cemetery to visit mom. Miss her.
Today is also 10 yrs since my oldest sister died too young from cancer.
Other than that, beautiful weather for the trip home.
   / Good morning!!!! #138,338
2021-09-13, 0334
57° right now...high in the low 70's...
   / Good morning!!!! #138,339
Poured first cup of coffee. 63° with mostly cloudy skies. Heading to 72° with thunderstorms in afternoon. Tiki bar roof is back together. Need to install some artificial grass around edges. Hope storms hold off until that is done. PT later this morning. Need to mow grass. Do not think weather is going to allow it.
Buckeye, glad trip went well. Did you bring any Buckeyes home?
Mpham, you need a BH to remove stumps easier.
EVeryone stay safe and healthy.
Good Morning All.
   / Good morning!!!! #138,340
good morning all
warmer muggier day today with some showers tonight and a wetter week predicted. 86 today's high.
I got up and had to turn the a/c down a little, pretty muggy air.
RS, nice straight rows (y)
Dennis, that cemetery looks super peaceful
Alien, good luck with new barn, always good to have more storage
only one cup of black coffee this morning, groan, have labs later and must fast.
Then back to mow the lawn.
2008 CAT D6T DOZER (A58214)
2008 CAT D6T DOZER...
2016 Ford Transit 350 Cargo Van (A59230)
2016 Ford Transit...
2015 Ford F-250 Pickup Truck (A59230)
2015 Ford F-250...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
1755 (A60430)
1755 (A60430)
7ft Pull-Behind Rake Tractor Attachment (A59228)
7ft Pull-Behind...
