Good morning!!!!
   / Good morning!!!! #122,841
Winds were mostly out of the west, around 100kts,
Really? typo?
sounds like a hurricane to me
better you than me up there, as I told you...;) Glad your trip went well and hope you got your pie
No typo, winds at altitude are generally much stronger than on the surface. And yes, the Key Lime pie was excellent.
   / Good morning!!!! #122,843
Good Morning!!!! 51F @ 4:45AM. A mix of clouds and sun. High near 65F. Winds light and variable.
Your story about the propane leak got me wondering about automatic shutoffs. The propane stove has one here, which is something of a problem during power outages because the stove and burners won't come on unless the stove gets 120VAC. But it prevents the house filling up with propane if the power goes off and the burner or stove goes out for some reason. I would have thought there would be some sort of thermal switch on the heaters that would stop the flow of propane if the reactor cooled off. Is that not the case?
It also makes me wonder, Drew, if your propane generator has a shutoff valve so that if/when the generator stops making electricity, the propane flowing to it is stopped. There is one on the big Cummins I installed this year, but that thing is run by a little computer that does all sorts of things as well. I got a pretty good start on installing a propane conversion kit on the Honda generator yesterday, and there was no provision for a cutoff solenoid. Now I'm thinking I'll install one, but not quite sure how it would work. If I get a 12V solenoid and wire it to the starter battery on the generator, the valve would be open all the time as long as there's power from the battery. If I get a 120VAC one and plug it into one of the receptacles, propane would flow as long as the generator was running, but I'd have to start it on gasoline and then switch over. I just drained the gas out of it, and hope not to put any back in it again. Time for more googling I guess.
And speaking of generators, have you actually fired yours up and switched the household loads onto it to make sure everything works as expected?
I have one of those HF magnetic sweeps I would have loaned you if you lived closer, Don.:laughing: But recent experience loaning tools that come back broken or not at all have me thinking I'll stop doing it. Yesterday, a neighbor wanted to borrow the hydraulic lift dollies, but I think I'll just go over there with them and help him use them instead.
Gravity seems to be getting stronger out here as well, Ron.:eek: Some days I have a really hard time even getting up out of bed!:laughing:
Good to know Tank Utility stands behind its products, Paul. I installed one on the tank here this year. Got a flyer from my propane company saying they're automatically installing one on any tank that supplies a generator so they can better schedule automatic refills. They haven't said anything to me about accessing my monitor, but I don't plan to let them. I want to buy propane when the prices are low, not when the outfit selling it decides it's time for a fill up.
Sounds like quite a ride, Lou. Don't miss snow driving at all, especially on hills and in the mountains.
No wonder Amazon is building a delivery network. Deliveries here are already slowing down, and it won't be long before UPS and FedEx start losing things...
Don't think I've ever had squirrel. The ones out here eat pine cones, and I'm told they don't taste very good.
Not sure I'd have gone with the red, RS, but some color would be a relief in a stark black'n'white layout. Then again, happy wife, happy life.
Not much luck getting through to the decoupler guy yesterday, as only had an email address for him. Finally got the return instructions and shipping label to return the T-Mobile modem, so I'll do that while I'm in town for groceries today. Also have a couple Black Friday things to pick up at Tractor Supply. They had a nice rolling stool I can use at the welding table. Wrote that one off as a safety item since I almost busted my keester when the top milk crate I was sitting on last time decided to part company with it's bottom brother, leaving me grabbing for the table to stay on my feet.:laughing:
Hang in there, gang, Friday's comin'!
   / Good morning!!!! #122,844
Good morning all, 28 going up to 51, sunny and wind has calmed down
Wind did dry out the ground a bit, maybe get some lights up today on the house.
Popg - I remember flying with the team in Panama where it was 80F at altitude. Then going up north and seeing numbers like yours. People on commercial jets don;t understand the clothing requirements and adjustments on uninsulated planes. Always made trip time more interesting as we had very little heat and certainly no AC in a transport plane.
Bad weather coming,just as the ground starts to dry out. Oh well.
Stay safe and be well
   / Good morning!!!! #122,845
How about a 12v valve connected to the starter wire, and a parallel connection to the battery controlled by a relay with a 120v coil. You would have to add a diode to keep the relay from back feeding the starter though. If it’s being fed from a portable tank to the zero regulator, I wouldn’t bother with it, just turn the tank valve off.
   / Good morning!!!! #122,847
That's what my wife guessed, since no big tree fell over in the yard...but aren't they illegal?
Yeah.... Quantico has a hot line to report excessive noise.
Maybe one of them flew your direction yesterday? There were at least two flying at altitude here, and they were still screaming loud.
   / Good morning!!!! #122,848
24° early, 40° now, big rains moving in for tomorrow night and Saturday.
Looks like Christmas decorations for today, love seeing them, not so much putting them up and taking them down. I asked Ellen if could just roll the lights out in the front yard and turn them on, she was not amused.
I was going to get the Ram serviced, then I realized I’d only put 3200 miles on it since February, at that rate it’ll be six months before it’s due.
I’ve eaten squirrel many times, mostly as a kid, I liked it but I didn’t see the resemblance to chicken. Mom skinned them on a board with nails in it. Mom shot most of them with her Remington.22 bolt action.
In my attic I still have the last squirrel she shot in the mid 70’s, nice mount but the cats won’t leave it alone. I kid her she almost missed him, she shot him with her little .410 and one of the shot took the tip of his nose off. That was the last time we went hunting, she took to fishing more after that.
   / Good morning!!!! #122,849
Was just thinking of a vacation up to the white mts when the kids were young.
I'm buying the BX23 my FIL had, right now keeping it at MILs house to do projects with. It has a snow blade for the front. I should put it on for winter, but she won't even try to drive the tractor.
Hi BEF,
I was fortunate as a kid, many of my aunts/uncles had camps in the lakes region. I spent many happy days swimming, fishing and hiking.
Good luck with the BX23 it should serve you well. I have both a snow blade and the front blower for my BX24, it sure
beats the old farmall cub I used to plow with LOL.
   / Good morning!!!! #122,850
I wouldn't be surprised but this was the boomer many people heard yesterday.
"Witnesses across the area reported hearing the boom or seeing a fireball in the sky shortly after noon on Wednesday, said Robert Lunsford of the American Meteor Society in Geneseo. By 4 p.m., the organization had recorded 78 reports of the fireball seen in Maryland, Michigan, New York, Ontario, Pennsylvania and Virginia."
Also on the subject of snow tires as I didn't see any good place to put this.
For any of you that swap your own tires back and forth or just rotate them,
on my wifes little Jeep Compass for some reason they used lug bolt instead of studs and lug nut.
These are a hub centric wheel and with no wheel studs to help line up the wheels to the hubs can be a royal pain to get set on the wheel hub and lined up to start the lug bolts,
I went to my hardware store and bought a couple of long metric bolts remove the hex head and cut a screwdriver slot in the end.
the Jeep wheel hub;
the wheel hub showing a stock lug bolt and the two studs I made, I screwed the studs in 4-5 turns, then used them to line up the wheel to the hub,
slide the wheel over the studs, start 3 lug bolts remoce the studs and put in the last 2 lug bolts. Took several minutes of bending down and trying to line up blind holes to just a couple of screwing in the studs hanging the wheel and removing the studs. Didn't even cuss Jeep once when putting her already mounted snow tires on.
   / Good morning!!!! #122,851
30°F and cloudy this morning, going up to 46° today.
Our garage door broke yesterday. It started acting up on Tuesday, when it would close, the reopen after about a second. Thought it just needed an adjustment. Yesterday, The Wife said she couldn't get it to open. Went in through the back, and found the chain was hanging and a sprocket with a broken shaft in the middle was laying on the floor. That'll do it. Fortunately, her car was outside when it happened. Service guy is supposed to be out today.
While sitting at the kitchen table last night, The Wife checked her Amazon account and found a notice that a package she was expecting (some rather expensive gifts) was listed as delivered, and "handed directly to resident." She looked at me and asked sarcastically if anyone had handed me a package. We looked outside, and there were two packages laying on the back step. She got ahold of someone at Amazon, and was ripping them a new one the last I heard.
I've eaten a lot of squirrel over the years, cooked every way imaginable. Breaded and fried and dragged through ranch sauce is my favorite. I stopped shooting squirrels probably 20 years ago. They are indeed tasty, but in my opinion just too much work for the amount of meat you get from them.
   / Good morning!!!! #122,852
Amazon, UPS, FedEx, and USPS all hire a bunch of temporary workers this time of year. So there are more mistakes, more "don't give a darn" attitudes, more lost or misplaced packages. Welcome to the holidaze...:irked:
OnTrac (which I've started calling LosTrac) is supposed to make a delivery here today. Owing to previous experience, I'm not holding my breath on that one.
   / Good morning!!!! #122,853
69°F and 0 inches rain.
Continuation of yesterday . Cleanup. And like yesterday, not a blistering pace. I need to get better at clean as I go on this project. Don’t know why I let it get so far behind.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #122,854
...Squirrel...They are indeed tasty, but in my opinion just too much work for the amount of meat you get from them.
Yep. Use to stew them. Not like chicken IMHO. Agree on the work part.
   / Good morning!!!! #122,855
The best part was how irate my Wife got when the woman on the other end of the phone line suggested that maybe it was a misunderstanding on our end. :laughing::eek: My Wife asked her how she could possibly suggest that their delivery driver deliberately lying about the delivery could somehow be our fault. That's when she lost her cool ... and I went to find something else to do in another room.
   / Good morning!!!! #122,856
good trip to primary doc, some chest soreness he thinks is caused by hormonal issues, ordered a brain mri focused on pituitary gland, oncologist wanted a brain mri anyway, they just aren't sure
I had a stroke. ? So an MRI for Christmas I guess. 5500 bucks, I'm not paying for it but....
stopped at local orchard on way home and bought apples. I have one for dessert every night. Braeburns were all gone unfortunately, loved those so got some Jonagolds and Staymans.
now to change back into grubby clothes and go build something in the garage, think it will be a feeder today. Old friend coming over this afternoon to pick out one for his family.
Pin nailer working fine, though I still put a few screws in the back of the birdhouse to reinforce the structure.
actually, no...and I need to. I'm not concerned, I see how it was wired and it would be hard not to work...but yes, sounds like a good project for this afternoon while it's sunny out.
I made an instruction sheet and taped it on the wall in basement. Funny, tried uploading doc, doc.x format won't load, resaved it as old Word format and let's see if this works.
  • Generator Connection.doc
   / Good morning!!!! #122,857
Drew,
Always turn off master before plugging in generator. That would be first step to disconnect street power!
   / Good morning!!!! #122,858
34F and partly cloudy @ 12:15, headed up to a high of 42F. Reasonably warm tomorrow as well, with a high of 44F and low chance of precipitation.
Started washing walls with TSP substitute in living room night before last in preparation for eventual repainting. Quiet activity that wouldn't disturb/wake anyone. It's a big room with high cathedral ceilings so it's going to take a while to complete. Need to get the rolling scaffold moved inside to get the top part of the walls. Ceilings will likely still be out of reach though.
Also started to finish up replacing light fixture in entryway/hall. There are three total in the hall that I will be replacing. I had taken the original fixture at the entry down some time ago and had removed all three new fixtures and hardware from their packaging and set them on the dining table. Someone decided to "clean up" the dining room table and took the fixtures and put them in the hall closet ... now the mounting hardware is MIA ... :mur: ... grrr ...
Amazon delivered the digital to analog converter/DVR for old tv yesterday, along with a replacement for the Moultrie feeder, the Goof Proof shower seat, and the Redi Niche(s) from Redi Tile.
The replacement Moultrie feeder's lid is still warped although not as bad as the first one ... so I'm at the point I'll have to see if I can use a heat gun to straighten it out a little.
It appears that I have made out like a bandit on the Redi Niche(s). I had planned to order a single 16" x 20" niche and Amazon offered the option of purchasing one that was in their warehouse that was "like new" but missing the original packaging. Or at least that's what I thought when I placed the order. I'll have to admit admit that I didn't check out the listing all that closely when I placed the order. What I ended up getting was FIVE Redi Niches ... one 16 x 4 single niche, two 16 x 14 niches, and two 16 x 20 niches ... all for the price of a heavily discounted (around 30% off) single niche. All of them appear to be in fine shape, several even had the original boxes and installation instructions ... but you could tell they had been returned. I guess they just wanted to get them out of their warehouse ... :confused3:
Works out good because I wanted to use a niche in the main bathroom when we redo that one and I had also talked to The Woman about installing a couple of them in the kitchen when I redo the backsplash in there.
First item on agenda for the rest of the day will be to refill feeders. Squirrel feeder is empty, suspect bird feeders need refilled as well. Squirrels are looking to be very well fed at this point ... all rather plump (and possibly tasty ... :laughing:)
Then trip to PO, followed by trips to a number of Home Depots (up to four now, to get all the tile ... :rolleyes:) ... and possibly a stop by Harbor Freight.
I noticed that HF had stopped sending out their 20% and 25% off coupons a couple of months ago (possibly due to pandemic ?)
Well about an hour ago I got a text from them with a link to a 25% off coupon for the Holidays ... wonder what I could use that on ? ... :D
Hope everyone has an enjoyable, productive, and safe day ... :thumbsup:
   / Good morning!!!! #122,859
I agree with Ken, Drew. I'm thinkin' it's not a good idea to be switching the interconnect when the generator is running and the generator breaker is ON. So start by making sure the generator breaker is OFF. Then you can start the generator if you want, then flip the interconnect, then set the individual breakers how you want them. You might even want to put a list together of how each breaker should be set, maybe just take a photo of how it should be and post it with your instructions. Then last thing would be to flip the generator breaker so the loads are transferred to the generator.
Come time to shut down the generator, reverse the order and start by flipping that generator breaker.
This sequencing means that it's pretty likely you'll be doing all of that in the dark at some point, so you might want to keep a flashlight at the breaker panel so you'll always be sure to have one when you need it. If there's a window nearby, get one of those MPOWERD Luci solar lights and keep it on the sill and you'll never have to worry about replacing batteries. You might also want to practice in the dark every other month or so. Having the power go out is upsetting, and in the resulting confusion, the less you have to think about the better. The more practice you get, the better off you'll be.
:2cents:
   / Good morning!!!! #122,860
Good morning! Low only went down to 9 degrees instead of 7.... still bone chilling cold... I have stayed inside.... haven't even looked towards the shop... 11:00 and it is now 34. I will attempt to go out after lunch.
I decided to clean out my junk email.... most of it was just the normal junk.... then I found this one... we got a really good laugh! It is a shame that some people would actually reply.... I thought about sending them back some BS, but them they would know it was a valid email...
Here it is for your entertainment:
Economic and Financial Crimes Commission EFCC,
P.M.B. 0187,
Garki,
Abuja — F.C.T.
Good day,
Hope you get this mail in good health and sound mind. The Economic and Financial Crimes Commission EFCC with the assistance of the FBI has detected from our database that you have been sending money to some SCAMMERS/BASTARDS for one documentation to another, Transfer charges of funds etc and yet you are not getting any funds (ATM Card).
We are giving you the full ODER to STOP sending Money or Itunes cards to them for you will not get anything positive from those thieves that have been robbing you for quite a long time now.
These fraudulent people are here in Nigeria, UK and USA.
Also a report has reached us that you have sent so much money to this scam artist. Please STOP!!! contacting these people we advise you to STOP and use your hard earned money for something good.
However, the President of Nigeria, Muhammed Buhari and the United Nation and IMF are giving you a compensation check of $850,000USD so that you can start life again and be a happy and better person.
Dear Scam victims, You are strongly advised to provide us with the below information.
Name in full:
Home address:
Also a phone number to contact you with is needed.
send the above information to our email Address stated below.
2013 Ford Escape SUV (A59231)
2013 Ford Escape...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
Massey Ferguson 92” PTO-driven rear-mount snowblower
Massey Ferguson...
1999 GMC C7500 S/A Dump Truck (A59230)
1999 GMC C7500 S/A...
HANGCHA CPYD30-XW71F STRAIGHT MAST FORKLIFT (A60429)
HANGCHA...
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
