Good morning!!!!
   / Good morning!!!! #210,941
[emoji[emoji6][emoji6]][emoji6][emoji[emoji6][emoji6]]" data-quote="buckeyefarmer" data-source="post: 0" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">
They acted like they didn’t understand English when I talked to them before. And I mean Acted, they understood. They cut limbs from trees, then threw them in my yard. Did same to my neighbors. They just don’t care.
Name on doors of vehicle?
   / Good morning!!!! #210,942
76F and sunny @ 11:30, heading up to around 81F for the day's high. Low temp this morning was 48.5F.
Got meds doled out first thing yesterday.
Refilled hopper feeder, also scattered some seed for the ground feeders.
Re-drilled planting hole where the tulip tree was.
Took Cub and mowed around pine tree to blow the needles in towards the base of the tree.
Got 2 more welded wire cages undone so they can be placed around the red maple and ginkgo trees, took those up along with 5' rebar stakes and dropped them off at the trees.
Trimmed down weeds around ginkgo tree.
Took Buffalo up and emptied the water remaining in it: ginkgo tree 8 gallons, large Rose of Sharon 10+ gallons, last 2 small oaks 4 gallons each.
Then took Buffalo down and dropped it back by the garden and hooked it up to refill on low flow.
Cleaned off top of deck on the Cub while I was waiting on the Buffalo to refill.
Also got Stihl blower out and blew the loose dirt out from in front of the garage door.
Then went after the stuck-on dirt, loosening it with a weeding tool, got about half done.
Buffalo finally full after about 45 - 50 minutes so I went back and shut off the water and disconnected it.
The only thing that looked really thirsty were the Beefsteak tomato plants in the grow bags which were drooping ... so I went ahead and watered them, double the normal amount which filled the catch pans under the grow bags (64 oz vs. 32 oz)
Then checked to see what needed picked, came away with another 4 yellow squash, 1 zucchini, and 4 okra.
Hooked the soaker hose on the indeterminate tomatoes and gave them a 45 minute drink on low flow.
Woman took the garbage and recyclables up to the cans at the road.
On agenda for today:
Refill tube feeders.
Some gluing and clamping of those 2 x 12's where they are split/cracked.
Hook up soaker hose on the brassicas and give them a drink.
Move long hose around front so I can hook up the pressure washer and clean the asphalt pavement in front of the garage, in preparation for putting down cold patch.
Swap out the 24" auger bit for the 12".
Pay a couple of bills.
Other than that see what else comes up.
Hope everyone is having a decent Wednesday ... (y)
   / Good morning!!!! #210,943
Raining and wind blowing here and this is what our radar looks like. Its 50 here now. The radar is in Marquette so Huron mountains block it for us, if its low anyway. Weather is coming from the NW.
   / Good morning!!!! #210,944
69°F and 0 rain
Successful replacement of my charge controller, system back to full Iarging capacity. Not sure if I should be grateful I didn’t find any problem, and I checked top to bottom or frustrated that 1 component went bad and I don’t have a reason.
Both Sophie and I spent some time on her EGO Z turn. Gonna take some time to adjust. A very different feel from her other mowers and tractors. That 1 bad battery failed to recharge. Glad a replacement is coming.
Need to spend time getting my LS running.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #210,945
was a busy morning but had to cancel roofer because Penndot decided the pave job they just did was faulty, so now they are doing it all over again, this time going fully out to mid road. They started right in front of my house, road is now oiled, I told roofer to come tomorrow so his truck didn't get covered. They thought that was a great idea.
got the car washed and partially waxed and the rv partially waxed.
everything seems to be reasonably caught up so time to rest
paver just started, shaking the house
   / Good morning!!!! #210,947
So she had been hankering an Amish clothesline as she's been having trouble up and down deck steps with laundry basket. So I adapted to the new post and old clothesline. She's happy still.
Clothes lines, ahhh the memories. While just in grammar school my Mom had on of those umbrella types, 4 sides, multiple lines, start in middle and work your way out. Yea, hanging out and retrieving the clothes was one on my responsibilities. No too bad except for Maine winter when the actually froze to the line.
Parents got a house on 100 acres when I was a freshman in HS, clothes line similar to yours. on pulleys, just stand on the back porch to load/unload. Mom didn’t get a dryer until I was out of HS.
I put up a pulley line for Sophie, but she has to use a stool else sheets etc would be on the ground and the line would be a decapitation hazard. Still hard to beat the fragrance of air dried.
   / Good morning!!!! #210,948
I was probably in jr high or early high school when we got a modern washing machine and a dryer. before that it was the wringer washer, with 2 large rinse tubs. We had to help wash, run the clothes thru the winger. When done, drain the wash tubs. We had clothes lines in the basement for winter time, and outdoors. Such memories. Eventually we moved the washer / dryer upstairs to the back mudroom. I did the plumbing, so think it was in the mid 80's after I had moved to MD.
   / Good morning!!!! #210,949
I have a Maytag engine for the old style washing machines. I keep threatening to find a working machine to put the engine on, lol. She much prefers clothes/sheets dried on the line to using the dryer.
   / Good morning!!!! #210,950
my grandfather had one of those wringer washers in the basement of his house but I never saw it used.
My mother got a modern washer and dryer pretty early on. She was going to law school raising four kids.
she got the washer/dryer; my Father was content to stick with old beatup chevys he could leave at the train station
and not worry about. He had zero interest in cars. Never got fancy appliances but always cheap white ones.
trying to remember during the 60's if we had golds and greens in the kitchen. Actually my Mother got a new kitchen
with dark green Mercer tile. And white appliances.
as kids growing up, early on we did all our own wash and ironing. Good skill to learn. Ask any single guy.
speaking of which....am pleased to report the second rinse experiment was totally successful. No more smell.
could be these new modern washers on automatic setting just don't flow enough water on standard "eco" setting.
am thinking that second rinse might be my default from now on.
paving is done outside. Had to drive to Doylestown a little while ago after neighbor called and said car had died and could I take
him to car rental place. Sure. Got dressed again and did my good deed for the day. He is one of my regular tomato recipients and I
get the nicest thank you note cards from his wife.
had to cut across fresh pavement getting back into lane and I did it slowly.
did I win the Powerball yet? :unsure:
2005 Caterpillar 740 Off Road Articulating Water Truck, S/N CAT00740PB1P009728, Cat Turbo Diesel (A59076)
2005 Caterpillar...
EZ-GO Electric Golf Cart (A57149)
EZ-GO Electric...
2014 TROXELL 130BBL VACUUM TRAILER (A58214)
2014 TROXELL...
2016 Toro Reelmaster 5510D Fairway Commercial Reel Mower (A56857)
2016 Toro...
New/Unused 8in Bucket (A57454)
New/Unused 8in...
WINCH CABLE DRUM (A58216)
WINCH CABLE DRUM...
