Good morning!!!!
   / Good morning!!!! #209,361
Went to Alabama concert last night in York PA, 10th time seeing them, and it never gets old. But they sure are getting old. Randy has a hard time walking around, but then I can relate to that.
good breakfast this morning with the crew, bought more concrete mix and one piece of deck wood at Lowes.
Downstairs AC not keeping up again.
   / Good morning!!!! #209,362
Morning fellas. Calling for 88° today with a 50% chance of rain.
Ran down and filled up two 30lb propane bottles for the camper. Still running $23 plus tax per bottle.
Got my gas cans filled up with non ethanol for mower. $3.69/ gallon.
And filled up my diesel cans for the tractor as well.
Plus filled up the truck
Mowed down the high spots and the dog run.
Sasha got the zoomies while I was out there trying to corral her in her kennel
Just sat there squeeking one of her toys til she run out of steam
Gotta drag out the water hose and fill her pool back up.
Wife's doing good. Peaked at the surgery site to check how it's healing. Skin looks normal and healthy.
Thats a huge improvement from last week.
Had to climb up on the roof and clean the condensation drains for the AC units on the camper. They had backed up and started dripping inside.
Pulled my air compressor out next to the camper, used the compressor to blow out the drains.
One in the bedroom has stopped dripping.
One in the living room has a slight drip still
The one for the bedroom was the biggest concern since it was dripping on the corner of the bed.
Sams club later and some grocery shopping to figure out something good for dinner tonight
   / Good morning!!!! #209,363
89F, sunny, and humid here @ 13:15. Nearby LWS on WU says it's 90F there with a heat index/"feels like" temp of 110F ... :oops:
Woke up around 07:30 this morning, was 73F.
Phone hadn't charged so I messed with the charge cord and got it charging and headed out to the couch ... where I promptly fell back asleep until around noon.
Rained a little bit yesterday evening, barely enough to settle the dust.
The big event was sometime early this morning, dimly remember hearing some thunder ... rain gauge shows a little over 0.5" ... with probably more on the way this afternoon if we are lucky.
After neighbor left yesterday I worked on moving one of the trees we took down out of the way. Then cleaned up a lot of the debris on the ground with the Kubota and the grapple in order to drill more planting holes.
Then removed the grapple and stuck the Light Material bucket on and headed up and grabbed a bucket load of screened compost and parked the Kubota back by the first arb planting hole.
Took Cub and dump over to the barn and deployed baited live trap.
Found there were two 2.2 cubic foot bales of peat moss, threw one of those into the dump cart and brought it over and parked the cart by the first planting hole.
Then went and got the Water Buffalo and brought it over, dropped it and hooked the dump cart back up.
My Able Assistant handled pruning any small saplings and roots, since She is closer to the ground than I:
Of course, that wasn't ALL She did ... ;)
Used the extra space in the dump cart mix up the screened compost and peat moss in a 2 to 1 ratio for the planting holes.
Put enough of the mix in the holes where the arbs were setting just above grade and then gave each hole 4 gallons of water.
Removed the arbs from the pots and worked over the roots with the little blue-handled claw to loosen them up.
Then set the arbs in place and filled in around them with more of the soil mix to the top of the root balls.
Then gave them another 4 gallons of water each.
They are going to have to be watered regularly - probably weekly - due to the large trees sucking the water out of the ground.
Used around 1.1 cubic foot of peat moss per plant, about 1/2 bale per arb. We're going to need another 3 bales to finish planting all the arbs ... so will probably pickup another 4 bales.
We ended up getting 3 planted, first one:
Next two:
... that included a break for some light rain, assembling the cold brew coffee/tea maker which came in the mail, dinner, and having to refill the Buffalo ... which was only partially full when we started.
By the time that was done it was starting to get dark so gathered up the stuff that needed to come inside and brought it up to the garage and put it all away and then drove the Cub over and parked it in front of the garden to keep the critters at bay.
Haven't been outside yet today ...but The Woman has and says it's horrid.
That nearby LWS is now reporting that it's 92F there ... with a heat index of 116F ... :oops:
Not sure what all it is on the agenda for today ... but it might not be much outside.
Suppose I could get the mowing done down here around the house.
With this morning's rain the ride shouldn't be quite as bumpy.
Hope everyone is having a decent Saturday ... (y)
   / Good morning!!!! #209,364
Nice work rswyan always pays to be safe your knowledge of safety is very good thanks for sharing
Yeah ... I really should have insisted on using the last couple of lengths of chain. I knew better but let it slide just to be sociable.
Looking back on it, the idea of creating another widow - just to "get along" and avoid being unpleasant - isn't anything I want to be responsible for.
End of tree and the end of the chain we used:
Bottom of the tree he wanted to "push on" with his bucket:
Your venting is being heard.
Prayers for the situation you're dealing with ... with hopes for improvement.
   / Good morning!!!! #209,365
Thanks rswyan taking care of dementia patient is sometimes very difficult and trying at times.
Big storm here just left heavy rain frequent lightning lasted 45 minutes yard very soft
Hello come in PJ
   / Good morning!!!! #209,366
Hello come in PJ
I feel for ya. My grandfather had dementia as well. It's rough, trying, and a big heart ache all rolled into one.
   / Good morning!!!! #209,367
My dad took care of my mom with it.
Got a little deck2 work done, now have temp stairs. Joist tape not coming till Tuesday, Lowe’s wanted $35 for a small roll, I can get 4 rolls for that on amazon, but ordered 2.
Very humid today, shirt was soaked
   / Good morning!!!! #209,368
Picked up the boots from Redwing after being resoled and got new insoles and laces as well. Not nearly as sturdy and thick soles as the Nicks boots but will alternate them between 2 pairs of Redwings and one pair of Nicks
The girls continue to enjoy Santa Fe with hiking, biking and horse back trips and much more. It is a small world and she found a friend she met on her last trip to Riga, Latvia who invited them to visit his vintage store that is only open by appointment and offered the girls a gift from the store. Another friend contacted her to go visit Havana, Cuba together next month. It is unreal how many friends she has all over the world. Attached below is one of the scenery pictures from SF that she sent
RS that was a close call. Glad it went well. The dead trees we took down were all pulled down with long ropes attached high up in the tree by throwing a thin line with weights over a branch and pulling up the bull rope
Buppies, when wife spent 3 months in a nursing home we found out how difficult it is to deal with dementia patients. And that was with 24/7 care and multiple people involved in the care. Doing this being the primary care giver is extremely difficult and taxing. We are always her to listen and give you support
   / Good morning!!!! #209,369
Thanks M7040, Dftodd
Great work Phil
Great deck BEF you are most talented
Hi Drew
Your yard looks like park Ken
Puppy wife and I sitting on porch watching 3rd storm for the day. Does not get any better than that
2018 KAUFMAN 44 FT CAR CARRIER TRAILER (A59575)
2018 KAUFMAN 44 FT...
Pickup Truck (A59230)
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
2002 Toyota Camry LE (A57148)
2002 Toyota Camry...
Jumper Cables (A57149)
14ft Tri Axle Homemade Trailer (A57453)
14ft Tri Axle...
