Good morning!!!!
   / Good morning!!!! #162,431
sister's power is on but not some of her neighbors.
Lot of folks without power in CA right now
I bet RNG has this site on his pc...
similar map provided by PECO. Maybe they buy the software from same place. Nice you can click on your house and it will give status update, of sorts.
frits, my MB rv had a 188hp diesel that was surprisingly peppy. Granted small rv. Sounds like you have a big truck engine in your van.
at the moment I'm envious of your towing ability...
   / Good morning!!!! #162,432
I have the same engine in the van. Agree it is peppy for the size engine and HP. But it is not good for heavy duty towing
The dually truck is the tow vehicle.
   / Good morning!!!! #162,433
Your service area is likely by PSEG> The recent expansion of the Sewaren station to replace the old coal fired plants should have been good for reliability of the electrical system. I had some experience with PSEG where we relocated two 400 MW plants to Saudi Arabia
   / Good morning!!!! #162,434
riptides
BTW, woodchuckdad on TBN recently installed a Mr Cool, this is 2nd of 2 part video I think.
Thanks.
My issues are, I don't go near electric. I ended up wiring the Milk House, but not hooking anything up to the panel. So I needed a pro for the panel work, breakers and whatnot.
Then the Milk House itself, its generously applied concrete over steel mesh over petrified true 2X8's or 2Xx2. Getting the holes into the walls for electric boxes and Mr. Cool are most challenging. Yesterday it took the better part of the day hanging the in door unit. 95 percent of the day was drilling the Mr. Cool holes. LOL.
Here is the template work that was used to pre-drill everything and the new access hole for the lines.
Here is a small victory. (you can see my problematic electrical outlet hole in the wall, not more than four feet to its right, I had no issue running the line).
   / Good morning!!!! #162,435
No, not the phone company. This company started out doing phone and cell phone services. They dropped all the phone service about a year ago.
Now they do nothing but fiber optic internet. We have their "mid" package which is up to a gig download speed, for $85 a month, including 2 additional mesh routers. No charge for install or equipment.
We still have 6 pair copper coming in, but don't use it at all.
We use our POTS line for any customer service temp calls, because you never know if it will kill the battery just as they finally pick up, or if a bird flies past the cell tower and we go from maybe-two bars down to zero. . .
   / Good morning!!!! #162,436
22 outside right now, heading to mid 40's. Should be a nice day for more outside work. Rain should move in towards the evening.
I hope to finish the line work and close up with insulation and foam board the remaining side of the Milk House today.
If I can cut some firewood up, I will have met my goals for the weekend. Definitely not as busy as the rest of the GM crew. I need to step it up many notches.
Hope all have a good day, be safe.
   / Good morning!!!! #162,437
Thanks.
Check your local Community College - some of them have classes for homeowners, and putting in a breaker is really not as bad as you may think. Of course, there are also potential issues about local permit requirements. . .
   / Good morning!!!! #162,438
Thanks.
Great job locating MR Cool. Hopefully you can locate the outside unit so you don't have to coil up the line set
   / Good morning!!!! #162,439
PECO on our side of River, PSEG on NJ side. I worked for a small supplier of parts and measuring equipment (Schlumberger) into the power production industry, mostly turbine parts.
Because my boss was an old GE turbine engineer. Called on a number of PSEG plants, do not fondly remember Edison NJ. My eyes would always be red and itchy after several hours in that area.
That whole area around Newark airport and the Turnpike, the cogen plant, all adds up to some nasty air pollution.
High voltage lines cross the Delaware in many areas, so yes, the grid I guess includes PSEG.
always liked machinery. And power plants have some seriously cool machines. Being near a running turbine in a steam plant is fun.
Being near a kerosene fired gas turbine, basically a giant version of our home generators, using what PSEG at least used to use Pratt & Whitney
jet turbines hooked up to a generator. Noisy, very noisy. And the exhaust was yellowish brown. No emissions. Reminded me of a B-52, very dirty airplane.
maybe now they have all been retrofitted with emissions controls. Hopefully. These are peaking units, the very last ones to come on.
still makes me feel a little eerie looking at Limerick cooling towers, out in the middle of an increasingly populated area.
but nuclear, or fusion, is our future. I don't think we can build enough solar panels or windmills fast enough. And they all, ultimately, look ugly.
C'mon fusion. Clean energy first.
but until then, let's make what we have works. Let's not imitate California...
I reminded my sister's husband to go check oil level in their whole house gen. Those two are not mechanical at all, arty.
But he did my avatar so he is forever in my debt. My sister has been getting my mechanical advice for a long time.
She knows I research stuff. Spent a lot of time with them spec'ing out their Generac 22kw gen. Which has been running a lot in the last few days in Muir Beach CA.
   / Good morning!!!! #162,440
Good evening all. 47ºF for the start in Joplin MO, overcast, light breeze. variable cloudy light north wind, High temp was 59ºF. Decide not to call wife's sisters to arrange visit, I think she just wanted to go home. Hit road 8:30, home at 2PM. 1300 miles in 4 days, truck got 25+ mpg. I think it will be a while before she goes back to STL.
Scaredy sorry events are happening that you did not start and don't like. Prayers sent. Good to hear you have a lot of support, and your truck back. Hope you find the Men's Meeting as helpful as I do. Could not open pic.
Bill we don't have mashed potatoes left over, and those that are get made into potatoes pancakes. Than for recipe. Sorry about no windrow warning. Glad you had fun plowing and visiting with your customers. Hope you were able to conserve plenty energy.
Ron Glad install of new mesh router went well. hope you get back ordered outdoor router arrives soon. Nice squirrel pic.
Drew glad you worked out no sink before you bought. Good luck finding what you need.
Mike hope you get some wood, start some strips, and make a hole for the mini split. nice pic
Mike another project?
Phil glad chain mods done in time. Good to hear weight control working.
Kilroy good to hear wood stove helping keep HAPVAC quiet. Good luck with Starlink mast and install.
Paul glad FL trip good. Always good to hear you got to make music with the guys. Hope Punta Gorda trip went as well.
Thomas hope you got your kindling processed, and steady progess happened.
Buppies good to hear bear missing, sorry about tick. Good luck with limbs prayers sent.
Drew good luck with deciding how to handle wanderlust.
Buppies would need to win lottery to afford that on!
Dave welcome back
Billy hope you get the outside work done before the snow or rain.
Don seems weird you are planting Yaupon after hearing you and Rick clearing yaupon. Good luck with digging the hole.
Jim glad hanging tree now down hope you can cut it up soon. Good to hear wife home. Hope drone time was good
Frits hope bill for oil not too bad. 21 mpg sounds good for sprinter. Hope you got enough spares.
RNG hope no new wind damage. Hope you can get box lock unjammed. Glad grapple worked on grill.
Ken good to hear min split boss approved. Good to hear progress on garage, hope the basement is seeing progress as well. Our cut trees were save for fire starter.
David good to hear stalled projects getting proper disposition, and guys won H&F. Hope cottage renovation goes well.
James hope you get the proper pump and that it works well.
Ted sorry about issues with drip line and pond heater. Hope more progress today and grocery shopping was successful. Had safe return trip, Thanks
Ted hope detailing went well.
RS that was very long day in garage. Sound like lot of progress made. Hope more progress today.
Randy(wag) glad your encounter with possum went better than mine. Wife was trying to coax it out of a home it was making in the bay window, and left it to me to finish job. He was not gentle!
Thomas sorry about driveway boo-boos. Hope kitties not in too much trouble. Pie sounds good.
Kilroy hope your plan works.
Ted sorry drip line did not thaw out and manual water needed. Nice speed.
Kyle to bad Peacock only one broadcasting race.
Bill stay warm.
Dennis thanks for pic.
prayer for all, especially Jay/Peg, Kyle /Daughter, /mom's breathing, /learning new job, /friends upcoming new baby, /son's migraines, Bird /aging issues, Ron /broken arm and heart, Billy /mom hypertension & congestive heart failure, David(moss) /remodel, /divorce, Buppies /new skin cancer spot and treatment, /elbow healing, /wife knee healing, Thomas /gout, Phil /reflux, /wife's vioce, Frits /veteran son with mental issues, Ken /dad possible dementia, /uncle's surgery, Steppenwolfe /son-auto immune disorder, Grev /wife's eye, Ted /knee recovery, /retirement & disability red tape, /family issues, /wife feeling bad, Lou /eye issues, Doug and wife/health issues, / hand nerve and surgery, /fall and recovery, / wife headaches and heart eval, / David(sadamo)/Sophie's new eye surgery recovery, Chris /neighbor's granddaughter and Covid issues, Scaredy/shoulder dislocation, /marriage not doing well, / friend stop drinking, Paul/ wife's healing from back surgery, Dennis /retirement, /neighbor issues, /land development, / brother "alligallyitus" and back in hospital, Drew /foot heel issues, /friend's wife cancer diagnosis and recovery, mike /wife's surgery, Scotty, /back pain, Frits /daughter recovery from surgery, Helogabals /second opinion, /wife's friend situation, Mark /wife colon surgery, Fatjay /father broken hip, Ukraine war, and Country.
Rain interfered with install, but at least I have the materials. I did get the hole drilled in to wall to the outside 😁👍 AND was able to do some figgerin’ and figgered a better way of raising the mast than my original plan, AND was actually able to do a sortakinda mock-up mast-raising because a couple months ago I bought a Silky tree pruning saw with the 21’ telescoping handle — and the mast will be 22’, so the tip of the blade is about the height of Dishy when it is laying flat.
Mockups are a good thing!
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A57453)
(1) HD 24ft Free...
SKID STEER ATTACHMENT HAMMER (A58214)
SKID STEER...
2024 Keystone RV Sunset Trail Camper, VIN # 4YDTSSN23RS350167 (A57453)
2024 Keystone RV...
2006 Mac Truck CXN613 (A56436)
2006 Mac Truck...
