Good morning!!!!
   / Good morning!!!! #158,011
Drew, not exactly warnings on Mauna Loa, but increased awareness. Nothing for us to be personally concerned about other then effects elsewhere.
   / Good morning!!!! #158,012
45F and cloudy @ 23:00, rain has moved out. Heading down to around 42F for the overnight low.
Wind was blowing and the leaves coming down earlier, probably 75% or better down at this point:
And I was loving it ...
Mainly because at least there is one gutter that is covered that I no longer have to clean ... :LOL:
OTOH, the washing machine is now leaking ... :(
There was some extended discussion about that this afternoon and apparently my suggestion that it might be just a little bit before repairs could be accomplished (... and perhaps a laundromat could be utilized in the meantime ?) was tantamount to a suggestion that someone be deprived of the very air they breathe ... with cruel intentions.
The first issue is that at least one of the isolation valves for supply lines (at the wall) to the washer is seized ... so the water supply can't easily be turned off there.
Second issue is that the next set of isolation valves down the chain also cuts off the water for the kitchen ... so if/when the repair is attempted, the kitchen will be without water ... for however long it takes to at least fix the isolation valves for the washer itself. Plus those valves aren't looking real great either. IIRC, the last time I repaired the washer those were frozen up as well ... but I was able to get them freed up.
Third issue is that I'm racing to get the barn buttoned up before the weather gets really ugly - which thankfully it has not done yet but I sure know it's coming - so I can get a floor poured.
Fourth issue is the diagnosis: not really sure what the issue is at this point. Will need to tear into it and get the cover taken off to see whether it's the seal on the drum or something else like a hose, etc.
The good news is that if it's the drum seal it's fairly cheap and the repair appears to be pretty straightforward.
The Woman went over to neighbor lady's for dinner, and she had another couple over who brought dinner as well. The husband grilled some pork loins and his wife fixed homemade apple sauce. Both were very good.
The Woman made flan and took that over for desert, as well as an apple crisp ... which unfortunately got burnt on top (during the discussion of washer repairs ... :rolleyes:) ... while She was trying to brown it up under the broiler.
Meanwhile I got the order for the 90 ceiling joists and the four rolls (8' x 100') of ceiling vapor barrier placed and proceeded to the Menards in Kent to pick those up.
Took the rebate checks along and used them to pick up two exterior LED lights for the barn:
The one for the front of the barn mounted above the overhead door is 15,000 lumen, 5000K dusk-to-dawn unit. This one will replace the existing HPS which either has a bad bulb or is otherwise kaput.
50,000 hour life and 5 year warranty on both.
The second one is for the south end where the second man door is: a 7,000 lumen, 5000K flood dusk-to-dawn unit. Will mounted up high on the gable.
Think I will wire both on switches.
Got the 90 2 x 4's pulled and loaded in the van, along with the four rolls of plastic for the ceiling vapor barrier.
Fortunately, there was a pile of 2 x 6's right next to the 2 x 4's ... so I didn't have to stand the entire time and could sit while picking out some reasonably good ones.
Woman was worried that I might not be able to see well enough in the Outdoor Lumberyard to pick out good ones.
She's never been there at night - the lighting ain't a problem ... :giggle::
Took the opportunity to fill the van with diesel at the Meijers who has some of the lowest fuel prices around while I was over there.
Now I need to go see if I can find my aluminum pipe wrench ... :rolleyes:
Hope everyone had a great Hump Day ... (y)
   / Good morning!!!! #158,013
Breakfast was really good. Couple of the longtime waitresses greeted us warmly, even asking how the dogs. Portions are such we never clean our plates. Sophie takes own container and it was well known the leftovers were for the pups.
Decent progress with the Starlink install. Need a new hole to thread cable from inside to out as inspection revealed not possible to use existing. A challenging location, but doable, just need to be careful.
My new iPad was delivered a day early so I get to set that up tonight. New case supposed to arrive tomorrow. Then I will need to reset my ipad Air and send off to our son.
   / Good morning!!!! #158,014
Visiting my Daughter, Son In Law, and Grandson for a couple of days. Will check in when I can
Have a great day all
   / Good morning!!!! #158,015
2022-10-27, 0347
59° right now...that's today's "high" as well...
Mostly, we had a steady rain yesterday from ~0600 until noonish. Good soaker!
When I got home, I saw the oak in front of the house dropped almost all it's leaves so I ran the ZT over the walks and under the tree. Didn't really "mulch" as I didn't lower the mowing deck
   / Good morning!!!! #158,016
Coffee has finished brewing. 28° with partly cloudy skies this morning. Heading to 53° with mostly sunny skies. Did not got many chances to blow leaves away from buildings. Some kind of moisture was falling all day. Did get walkway to garage cleared. Will work at that today. Need to clean leaves out of garden pond also.
One Sandhill Crane is always on look out while other eats.
Everyone stay well and safe.
Good Morning All.
   / Good morning!!!! #158,017
Good morning. 53 going to 59 supposed to be sun today
Lots of leaves came down yesterday. Reminds me to check on gutter cleaning service and set it up for another year. Also checking into changes to medical insurance coverages.
Did not get down to Alexandria yesterday so will do that today. Also the ignition coil for the chainsaw was still the wrong one so will return that and see if they can figure out what the right one is. Will bring the old one. Changed the chain on the Makita chainsaw and got a file system for sharpening. 3/8 inch file pretty small
We both woke up earlier than normal for whatever reason.
   / Good morning!!!! #158,018
57 and breezy, going to 64. Sunshine never arrived yesterday until sunset. All day sun today.
Ron, nice crane photo.
Scaredy, enjoy your visit.
Did some mowing for a couple of hours yesterday...some scraggly areas, and mulched leaves under the trees.
Found a dead doe in my field...actually watched a buck find her. This field has grasses and wildflowers (weeds) that are too tall to see a deer lying down, but I wondered why the buck was walking circles around something, and then pawing at and nudging it. He finally bedded down there. 4 hours later he left, and I checked it out. I think it was hit by a car...looked healthy, had been lactating, and no arrow, gunshot, or bite wounds.
   / Good morning!!!! #158,019
45 high in 60s today working close to home today
Nice picture Ron
Prayers for all silent or spoken Scaredy L4N, Kyle, Leslie, our Country
   / Good morning!!!! #158,020
Good morning, low temp 31 and going to a high of 43°F. Wind W 5 mph. Sunny!
Well, I got the summer tires stowed in their place for the winter, also got the shelves installed on the shelving units. Now I just need to get the stuff moved over from the shed I keep the tractor in.
I got the factory class 4 hitch installed ($250. for the hitch) and the tire swap done to the tune of $566.oo all in.
Thanks to Mercedes' (parent company of Dodge) over complicated trailing arm suspension, I now have two more bushings that are on their way out and should be replaced in the next year or so. I'll do it in spring with my income tax rebate.
I didn't get to the driveway yesterday, so I will do that today. Also have a town run to take care of today and put 20 bux worth of gas into the Dodge. (2.8 U.S.gal.)I will fill it right full in North Bay where the price is at least 20 cents cheaper per Litre. ($0.756/US gal.) After the town run it is come back home and veg.
Have a safe day all
Ingersoll Rand Air Compressor (A52377)
Ingersoll Rand Air...
2016 Chevrolet Sonic LS Hatchback (A53424)
2016 Chevrolet...
2014 Dodge Charger Sedan (A53424)
2014 Dodge Charger...
2007 KONECRANE SMV25-1200B STRAIGHT MAST FORKLIFT (A51406)
2007 KONECRANE...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
