Good morning!!!!
   / Good morning!!!! #28,501
Happy Birthday MacLawn! Good luck getting your money. :laughing:
   / Good morning!!!! #28,502
Thanks, boys. I'm 66 now, been paying into SS since I was 12, wha', 54 years now? Never taken a dime yet. Yep, chances of gubmint going belly up are mighty high, mighty high.
   / Good morning!!!! #28,503
I'd be worried, real worried. You just went from being an asset to being a liability. :eek:
   / Good morning!!!! #28,504
Happy Birthday MacLawn.
   / Good morning!!!! #28,505
Happy birthday MacLawn may you have many more
   / Good morning!!!! #28,507
Happy Birthday, MacLawn
David Sent from my iPad Air using TractorByNet
   / Good morning!!!! #28,508
I woke up and thought I'd been transported to Larro's back yard...68 degrees going up to 75 today.
Rain likely, thunderstorms at times. Another inside day, mostly doing some staining and polyurethaning of trim
pieces and then a few hours of hand sanding in the new closet.
actually looking forward to colder weather coming in. The ground is so wet I can't do much with the tractor.
I really should be out planting more bulbs. Usually there are some leftovers around but I haven't found any locally. Those little mesh bags of
100 mixed tulips and daffodils. Super cheap, probably the least desirable, but along the edge of the woods facing the road, those bulbs will look just fine. I hope. Shall see if the deer come for breakfast; have had that happen before. Just came along and munched all those delicious little crunchy heads off. Grrrrrrr. Maybe I'll buy a case of Irish Spring soap....
Happy Birthday Mac. It's funny how a bunch of us are creeping up on Medicare/SS about now.
Hey, we made it....
   / Good morning!!!! #28,509
David/MF, how's the new job going? We all hope well.
It must be nice to get back in a routine but I bet you wish you had a little of that free time back again.
Back to being a weekend warrior.
Hopefully all good.
Mostly, you rode that bicycle how many miles? That's almost across the US. I haven't quite followed where you went, but I knew
you were "going"....and having fun. You must be in really good shape.
   / Good morning!!!! #28,510
42 and drizzly, heading to 70. Weather has a fever today, but will be well and return to normal tomorrow.
Got my splitter running yesterday - 19 pulls and it started like magic. :( Finished my splitting just as the rain started, so I'm happy.
We'll probably take down the rest of the Christmas decorations today...always hard to take them down, hate to see them go. But it will be nice to regain the space that our huge tree takes up. We always say we are going to cut one a little smaller, and they look smaller in the field. So they must have a growth spurt while carrying them inside.
Hope you enjoyed your birthday, Mac.
   / Good morning!!!! #28,511
Billy, time for a big shot of Sea Foam in that splitter. Old gas?
glad you got it done, a good feeling of accomplishment.
   / Good morning!!!! #28,512
Brand new gas with Sta-bil ethanol treatment.
I've never used Sea Foam, but was about to buy a can when the man at the hardware store said it would worsen the problem because it had ethanol in it. Not sure I believed him, but bought some carb cleaner instead.
Have you had good experience with it on small engines?
   / Good morning!!!! #28,513
41 this morning high of 64 later today with heavy rain possible. wngsprd have used sea foam for years with positive results. The man who repairs all of our small engines swears by it
   / Good morning!!!! #28,514
Thanks. I'll give it a try.
Billy
   / Good morning!!!! #28,515
absolutely yes and most of the repair shops at least where I used to live used it heavily.
There's alway someone who says "oh that's just kerosene".
I don't know, my engines always started after I started using it.
That premixed expensive super gas in the cans really works well in my chain saws. My echos often start on the first pull. Or at least burp so you take off the choke and it starts on the next pull. Two pulls I'm happy with. I think after four pulls I'd wonder what wasn't working unless the engine had been sitting all year and the gas had drained out.
   / Good morning!!!! #28,516
I've used that premix in the can for our Mantis tiller after having to rebuild the carb, and it is worth the money for such a small use. My chainsaw has never had a problem with regular gas, nor any of my other engines, but maybe this splitter just needs extra love, so I'll feed it some sea foam while I stand over it with a sledge hammer - tough love :).
   / Good morning!!!! #28,517
53F @ 06:00 ... down a degree since 05:00
Looks like it won't hit the 32F mark until about 21:00 tonight ... after that the bottom really drops out.
Got the top bar on the pallet fork backstop pretty well straightened out and welded onto the uprights. Also got the bent parking stand for the landscape straightened out as well. Pallet forks should be ready to paint within the next 48 hours or so. Still have to cut two pieces of 1/4" x 2" for the outside uprights and get them welded on ... but need to service the cylinder for the hydraulic downfeed on the band saw before I do that. It was low on fluid ... made it drop a couple inches at the top of the stroke. I need it to work all the way down ... so I can do a vertical cut on a 10" tall piece of 1" plate for the splitter's wedge.
My helper showed up @ 22:00 so I had him pull the hydraulic cylinder and clean it off in the parts washer. Just have to disassemble it and refill it with fluid. I'm thinking that a little TSC Premium Hydraulic Fluid ought to do the trick :D
I did manage to get the 10" x 11" piece of 1" plate cut into a 6" x 10" piece and a drop ... by using a zip disc in an angle grinder.
Had the kid split a couple of oak rounds, and we did a lot of cleaning and straightening up. Then I let him do a little welding practice. He headed home around 01:00 ... with a piece of expanded metal - that had been two pieces when he started - to show his parents.
Think I'm just gonna stay up ... maybe run the Kubota up to the shed now and adjust the PRV for the 3PH while it's still warm outside ... so I don't lose all the heat out of the shed. Maybe try to get some stuff done outside once the sun comes up ... before the temp drops.
   / Good morning!!!! #28,518
MacLawn,
Happy Birthday to ya ...
Mrs. Redbird sends her regards.
(You too Roy ... :D)
   / Good morning!!!! #28,519
Drew,
Try takin' a whizz on 'em ... (the daffodils and tulips ... not the deer)
   / Good morning!!!! #28,520
12 with temps falling through out the Day.We have light Snow falling,might have to Plow later and clean it up.
SKID STEER MOUNTING PLATE (A60432)
SKID STEER...
204158 (A57193)
204158 (A57193)
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
2006 Nissan Frontier Ext. Cab Pickup Truck (A59230)
2006 Nissan...
2021 CATERPILLAR 299D3 XE SKID STEER (A60429)
2021 CATERPILLAR...
