Good morning!!!!
   / Good morning!!!! #117,721
Paul, with your musical talents, does that bother you much? When you aren't thinking about it...
remember the story a ways back where I went to the Ram dealer and ordered a new door speaker, sure it had blown out.
No, it was the tinnitus. I have 80 percent hearing loss in left ear, not good on the "stereo" effect...headphones help though.
Not gonna lie ... yes, it is a considerable hindrance. When I was still playing live, it wasn't too bad. The only practical issue was if someone on the other side of the stage to my left was trying to talk to me.
In a recording studio, though, it's completely different. I can't hear many higher frequencies at all, and many others are severely limited. Some of that is due to the natural deterioration that comes with age. But, the damage/tinnitus plays a significant role as well. So, when I record something, I have to be mindful that I'm not overdoing (or overcompensating and under-doing) the high frequencies in the tones of whatever I'm playing. When mixing and mastering, stereo imaging is always a challenge. I have a good monitoring system in my home studio now, and spend a lot of playback time turning my head so I can hear with my less-damaged right ear, putting my head directly between the two speakers, turning around 180° to listen to it from behind, and sometimes walking down the hallway and listening from afar. I can also switch easily from stereo to mono in the recording software, and do that a lot, too (get the mix right in mono, then start in on adjusting stereo panning).
Ultimately, it's just another challenge to work around or through.
   / Good morning!!!! #117,723
Drew, really good news!
You asked RS about his loader, I can’t help you there, but mine is a matter of folding the stand down, removing 2 pins, unplug the hoses and back out. Takes about 5 minutes. But I found I can mow just fine by just dropping the quick change bucket so that’s all I do anymore.
   / Good morning!!!! #117,724
I’ve had tinnitus since starting an aspirin regimen in 1995, some meds like prednisone make it worse, but it never goes away. You learn to deal with it. Sometimes at night on the deck I’ll mention how loud the crickets and frogs are, and Ellen will tell me they aren’t singing.
   / Good morning!!!! #117,725
MFW a little far out for us. Should have minimum of 5 inches 21A pug mill stone asphalt 9.5AL for surface mix. I recommend 2inches compacted asphalt any more is just taking your money. Paver preferabley 20000 pounds three to five ton roller for compaction of mix. If you are planning to use heavy equipment on it specs would change. I also prefer low rap mix if possible. Hope this helps
PS I am about 4 or 5 hours from you
Buppies,
Yes sir, you are unfortunately WAY TOO FAR away to help me.
Be well sir!
David
   / Good morning!!!! #117,726
Technically they were fully approved. I've kicked out my tenant, I've bought another house. Technically I can sue them and force them to close. I only get their small earnest money immediately if I release them from litigation.
NO, buyers should not just change their minds at the end of a deal, and we should not allow it. Breaking a contract for no reason is not cool.
But I agreed and let them out of the deal. I get the EMD, and last night I had 5 showings.... Hoping for good news today...
Be well,
David
David with mortgage rates so low hopefully you will have no trouble selling your property again. In my neighborhood it looks like houses are selling in a week or two. That's how it was when the market was hot several years ago. I can't understand this economy. It looks like the economy should be in the dumps but it seems to be off to the races. Good luck.
Chris
   / Good morning!!!! #117,728
Here is how it came out in the living/ dining area. I hope they can do the same with the bedrooms. All will be 3/4 thick boards.Walnut to tile and walnut to oak boards. The oak installed myself when we built.
   / Good morning!!!! #117,729
Digging hole for pole turned out to be a non issue. Yesterday’s rain made soil soft for easy digging. One of the poles that support lean too on pole barn had rotted at ground level. Put new pole next to it. Bolted and used adhesive to tie them together. Thought another pole was bad. But only need some fresh dirt around it. Was back in house by 9:30.
RNG, good bad joke. 🤠
Drew, I have same tractor as RS. I use FEL to raise front wheels up high enough for MMM to roll under. Mower has swivel wheels at 4 corners. So it rolls easy on concrete floor. Then I drop FEL back down. There are 3 hook up points that take a couple of minutes to hook up. Then hook up mid PTO. Taking FEL off tractor is like Randy said. I also just drop bucket sometimes also.
   / Good morning!!!! #117,730
Chris, I found it very helpful thank you and motivated me to send some suggestions for HEPA filters to my Quaker Meeting so maybe we can finally open up on Sundays.
Toppop, your Massey is a very modern design, like a modern swiss army knife, not sure RS's older tractor works that easily. Let's see if he says five minutes...
Ron, thanks I remember trying to do this on lawn and not concrete and it was a hernia producing event.
Plastic Bear Statue (A55853)
Plastic Bear...
White Metal Roof Panels (A55758)
White Metal Roof...
Ingersoll Rand Air Compressor (A52377)
Ingersoll Rand Air...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2016 Jeep Wrangler Unlimited SUV (A55853)
2016 Jeep Wrangler...
