Good morning!!!!
   / Good morning!!!! #215,561
Good Morning.
24° to start it’s on its way to a high in the middle 30’s, snow tonight.
Spent most of yesterday in front of a computer with Fusion 360. Did not have much success locating friends underground pipes, getting a lot of false (or at least random) readings. Not sure what to make of it, but I couldn’t give him concrete guidance where to hand dig, just a general suggestion.
Did play music last night with a different cast of characters, but had a good time.
Today started by meeting daughter for breakfast, and then taking a holiday table cloth to wife at a holiday market.
Probably do some more 3D modeling, I need to make a trip to the hangar, but no major plans.
It did just dawn on me that I don’t have the driveway markers in, but at least the plow is ready to go.
So maybe put in the driveway markers, at least around the bends, and the edges of the parking lot.
   / Good morning!!!! #215,562
No luck on Jeep, did get 2nd key and locksmith put his reader on and it came up with a short to ground on HVAC.
That is after I replaced the relay and the PWM controller.
Hopefully not the computer, but the wires back/forth seem fine.
Fuses all look good.
His reader picked this up and my cheap OBDII didn't.
   / Good morning!!!! #215,563
67°F and no rain
Project finally completed, can relax. Be tempting just to do that today, but likely not.
At some point during our absence, one young boxer girl at end of her heat escaped from the outdoor crate. Hopefully, she is still a virgin.
Nice meal at the Japanese noodle house with friends.
Prayers for all
Be safe
Have a great tractor day
   / Good morning!!!! #215,564
Good Tractor Morning,
So Dennis, what’s the prognosis on your shoulder ? You can’t keep that up forever 😉. My prostrate gets me up every 3 1/2 to 4 hours. My right shoulder is much better than it was, but I’m still not doing pushups 😉
Is this what we get for all our deck work this past summer ?😂
Drew, I was still awake at 4. That’s when I was trying to get back to sleep.
Shoulder is slowly getting better. Everything I read said it just needs time. Not bad pain as when I had to keep icing it, but bothers me with use, so have to stop. Not needing as many pain pills now.
   / Good morning!!!! #215,565
My only motorcycle "accident" was riding my brothers Honda 250 in the winter, went to turn around, and the tire slid on ice and down I went on my left side, hurt my left elbow real bad. Had xrays, they said no breaks, but to this day it still gives me grief.
   / Good morning!!!! #215,566
Good breakfast with all the usual gang. Grabbed some more fry pies at the mennonite meat shop. Picked up more BBQ sandwiches (2 for $5) and a half rack of ribs ($9) using coupons, will be used next week.
43deg out seems warm, snow overnight and temps drop all day tomorrow.
   / Good morning!!!! #215,568
It certainly is running lean, and that is by design. Not much you can adjust on “modern” carbs, usually just the air bleed for idle mixture. Don’t be afraid to use the choke, a small amount when engaging the mower when cold would solve your issue.
which is exactly what I do when I don't want to wait, give it a half shot of choke until mower starts getting up to speed and then off choke
thanks
   / Good morning!!!! #215,569
26F with fog and very light snow @ 15:15, calling for a low of 10F overnight. Low this morning was 24.9F.
Woman snuck out this morning before I got up and did some grocery shopping ... good thing as it was getting slim pickin's around here ...
She's now cleaning the kitchen.
Going to head down here in a few and start trimming up some foam board to fit on either end of the north wall and see if I can't get that put up, at least on the east end (drain pipe for the laundry room is blocking putting up the piece on the west end ... 🤬 )
Getting the drain pipe moved for clearance on the west end will probably require another Fernco coupling which I do not currently have.
Might unload the next set of shelves ... assuming that I can find a place to put all the junk that is on them ... 🤬
Need check/empty the debris collector on the whole house vacuum.
More cleaning/organizing, drain line for the brine tank should be ready.
Beyond that just see what other mischief I can find to get into.
Got one bag of trash brought up last night for Monday.
Revisited the wiring for the well pump the other day and got another look. It's wired up through the original Red Jacket pump control box ... which probably had a start/run cap in it originally:
Whoever worked on that and left it in that condition certainly wasn't following "best practices"... idiots ... 🤬
Will eliminate that box and just wire it up through the box that came with the Cycle Sensor ... once I figure out how to remove the KO's on the new box (it's hard plastic, don't want to destroy the box while trying to take out the KO's)
Current pump is a "2 wire" but of course it actually has 3 wires running to it.
Would like wire in a simple on/off switch right there to kill the power at the pump and Cycle Sensor so I don't have to walk over to the breaker box.
Crack in the north wall, now sealed:
Hope everyone is having a decent Saturday ... (y)
   / Good morning!!!! #215,570
Good (Sunday) morning. Overnight Low of 12C and it's presently 18.3C, clear with a howling wind... if anything is going to re-ignite that bushfire, this'll do it. The wind direction should turn it back on what's already burnt, though. Yes, I took the flagpole down.
I'm off to Church in a few minutes and then the rest of the day is His.
Pretty much the same with me. I still have a motorcycle endorsement on my drivers licenses just in case. 🥴🤠
As do I, although I haven't ridden in over 12 years. I sold my 'bike' (400cc Burgman maxi-scooter) as the rego, here in Tassie, for a bike was the same as a car/ute.
   / Good morning!!!! #215,571
My shoulder injury is finally back to normal after doing PT for two years. The Dr said it was rotator cuff injury but he did not recommend surgery and instead referred me to Pt. Went to a few appointments and then continued on my own.
I work out daily with a routine concentrating mostly on upper body strength. Hoping that will avoid future injuries, so far it is working for me
Not sure what I will get into today. Need to get wife settled after getting up and getting her the 25 pills she takes daily
Great news on the shoulder. (y)
That's lot meds for one day :oops: hope soon count will go down.
   / Good morning!!!! #215,572
27F cloudy sky.
Been good day got everything done I wanted tomorrow looks like slow day. :)
Army & Navy football game going to be nail bitter to the end...both side lot pride in their eyes.
Plans for the evening little as possible.
Enjoy your evening all.
   / Good morning!!!! #215,574
big shooting at Brown University outside Engineering building where exams were going on.
Have heard through family who have friends with kids there may be up to five or six dead.
senseless
I took Electronics 101 in that building.
   / Good morning!!!! #215,575
senseless
damn
   / Good morning!!!! #215,576
Individual MC licensing didn't come here until about 1970 or so. I could have gotten mine just by listing the motorcycles I had owned (V.I.N.s not required). I had decided that after the accident that could have been life changing that I wasn't going to ride EVER again that I didn't need a license.
   / Good morning!!!! #215,578
When I worked at Canadian Pacific RR one of my jobs was to supply the van alley (where they kept the cabooses) with 25 lb block of ice for the ice boxes.Chop a 400 lb block in two then into 8ths and supply 8 ice boxes. There was almost always a case of red flares waiting for me. Most of the other guys wouldn't do it for them, but I had no problem, especially when not only was CPR paying me but I was getting the free flares (the good 30 minute ones) every week. I still have an ice pick from those days, back in the late 60s.
   / Good morning!!!! #215,580
Good evening all. 37ºF for the start, partly cloudy sky, light breeze. Very light wind, sky became overcast, felt like front coming through, and high temp was 62ºF. Made coffee to start day, bike rid, 75 mile, 14.7 average. nap and dinner at Manulito's.
Resuming Dec 6 post 215,176:
Drew hope you enjoyed the snow
Bill hope plowing and town run went well.
Ron Ipad updated, and now you can listen to audio. Hope clean up went well. Nice squirrel
Dennis glad your tree is up. Hope you got your cards sent. I am planning on sending cards, may be late. getting them out.
Drew Thanks for food pantry stories. nice snow pic.
Happy(NC) glad you have all the cross members up to snuff. And tractor wheel back on. Glad you got manuals organized.
Thomas hope you accomplished your agenda.
Don nice to know YouTube is your friend. Hope you get more rain.
Mike hope you can enjoy your snow, sorry about accidents. Hope daughters took hint and animals fed. Hope you got lights up soon.
Buppies hope you were able to get tire fixed. Sorry care giver fail to show and no communications. prayers sent
ArlyA hope packing was successful and good trip to camp.
Drew like your pot storage system. Glad you can find the stove again. nice pics
Buppies nice pics.
Ken glad good trip to NYC. Hope you don't get too dizzy working Jeep. Nice pics, thanks for sharing.
Rich B1 thanks for pic
Fuddy interesting story and pic.
Drew I remember when turtles got stolen. Sorry they got stolen.
prayer for all, especially Jay/Peg, Kyle /Daughter, /mom's breathing, /son's migraines, Mike /BIL in FL, Ron /heart, David(moss) /remodel, /divorce, Buppies /cancer, parathyroid, blood sugar /wife, Thomas /gout, Phil /reflux, Frits /veteran son with mental issues, /granddaughter with Evans Syndrome, Ken /chronic fatigue, Diet not working, Randy(wag) /sister stoke, Scott(vt) /wife's back pain, Steppenwolfe /son-auto immune disorder, Grev /wife's eye, Ted /knee recovery, /retirement & disability red tape, /family issues, /wife back issues and cancer, Lou /eye issues, /heart issues, /wife hip replacement, Doug and wife/health issues, / hand nerve and surgery, /fall and recovery, / wife headaches and heart eval, / David(sadamo)/Sophie's hip or leg pain, Eye recovery, /back issue, Scaredy/shoulder dislocation, /marriage dissolving, / friend stop drinking, Dennis /retirement, /neighbor issues, /brother's lymphoma, /dad surgery recovery, Drew /back operation issues, /friend's wife cancer diagnosis and recovery, Scotty /back pain, Helogabals /wife's friend situation, Fatjay /father broken hip, Ukraine war, and Country.
1766 (A60430)
1766 (A60430)
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58214)
2014 MAGNUM...
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
Traxmax Kubota Stand-On Track Loader Skid Steer (A59228)
Traxmax Kubota...
2018 F550 Bucket Truck (A61306)
2018 F550 Bucket...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
