Good morning!!!!
   / Good morning!!!! #207,441
Our ex mark really mows a nice pattern looks striped without striping kit just uses a lot of gas two mowings 5 gallons of gas gone. 29 HP has advantages and disadvantages. It will mow grass 1foot or taller no problem and very comfortable to ride on with head phones on I hear nothing
31 HP pre emission diesel is pretty frugal on gas and not having to deal with gas cans is a big help using the farm diesel tank for refueling. Replacing with today's ZT Kubota with similar HP and 72 inch deck as well is 27,000 dollars. Ouch
   / Good morning!!!! #207,442
68F and Sunny @ 10:00, heading up to around 80F for the day’s high.
Refilled hopper feeder first thing yesterday, also scattered some seeds for ground feeders along with old bread.
Suet feeders were basically empty so those will get refilled today, along with the tube feeders.
No spraying done yesterday due to wind.
Got entire front mowed after “polishing” the underside of the deck.
Got 45 winter squash and pumpkin seeds planted in pots and moved around back to the shelves.
Tomatoes on the shelves out back are now big enough (12”+ tall) that we can start getting those in the ground, along with some of the summer squash and cukes.
Have more tomatoes in the little greenhouse in the dining room that need to be moved out to the shelves in back.
Moved over the boards for the raised beds from the barn and got the ends cut to length for three frames.
Today I’ll get the long sides cut to length, trimming off the one bad end each board seems to have.
After that start sanding them to clean them up a bit.
Outside dimensions on the beds will be 45” x 93”.
Have appointment this afternoon to have the sutures in my neck removed.
Hope everyone is having a decent Tuesday.
   / Good morning!!!! #207,443
68°F and .43 inches rain
Interesting day
Curious as to what a Dolphin Sigma pool vac looks like
That’s about $1200 worth. Did find a bit of water in the motor box. Motors tested out fine with a battery. Dried out pcb but not tested. So today I will put back together
Very nice Happy Hour. I went with the fajitas.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #207,445
Interesting day
Prayers for all
Be safe
Have a great day
That looks very different from my current Dolphin, think I have a model or 2 down.
Replaced the cable and rollers so far in 6 years.
Hope your fix works, salt water in the motor box does not sound good.
   / Good morning!!!! #207,446
scott, regarding your urologist; when he has his left hand on your left shoulder and his right hand on your right shoulder...
he won't even give you the courtesy of a reach around.
Well, I got my nuts tightened up and the yard arranged and the BH on. Now unless you know where to look you cannot see the snow blower at all. That was enough work for today.
Tomorrow I'll attack the stump I have been working at for the past year. It should be pretty rotten by now. IF the wind is out of the south and not raining, then I will knock some trees down.
   / Good morning!!!! #207,447
Urologist Appt. Also?
   / Good morning!!!! #207,448
78°
Another day on deck2. Never get as much done as I think I will, but got 4 posts notched for headers, and think I have posts in final position to anchor the bases to the concrete.
Discovered my final elevation is at least 1/2” high, due to green wood.
A dry 2x8 measures 7.25”, green are 7.5”.
I will make it work
   / Good morning!!!! #207,449
Evening all!
72 and sunny out. Heading for coffee with my buddy in a bit.
Got the deck pressure washed yesterday and both car interiors cleaned today.
Figured I'd stop in and post a few projects I finished.
Zebra wood pocket box. Cherry tray and an oval ash tray.
That's it for now will post again in the morning.
   / Good morning!!!! #207,451
reminds me I need a checkup too
getting a little loose...
wonder what kind of torque wrench should be used? ;)
80, sunny with a little haze
More like a pinch valve :)
   / Good morning!!!! #207,452
Good (Wednesday) morning. Overnight Low of 2.3C and it's presently 11.8C, clear with the occasional gust.
Well, as per usual, it's 'into town' day for the PO (yeah, I postponed picking up my parcel(s) 'til today) and groceries.
   / Good morning!!!! #207,455
Apparently mine no longer a current model, definitely out of warranty. Spent too much of the morning disassembling and cleaning the motor box. Fair amount of corrosion. Did get it all cleaned up, but gave up finding my tube of silicone grease. Good chance I just used it all. So will have to get more before reassembling.
   / Good morning!!!! #207,456
Long day today passed out in chair ate too much sugar too high.
Paver broke conveyor pump blew seals part comes in today probably no work today not good.
Prayers for all our Country
   / Good morning!!!! #207,457
Coffee is cooling in cup. 64° with clear skies this morning. Heading to 82° with later afternoon thunderstorms. Weed control never got done yesterday. Because of winds. Did some more barn recognizing. Today I need to do gutter cleanup. From all the Maple tree helicopters before afternoon thunderstorms. That should be enough for today.
Everyone stay safe and well.
Good Morning All.
   / Good morning!!!! #207,458
good morning all
enjoying first cup of coffee, looks like a nice day though hazy (wildfires??) and hot.
no plans for today other than building my new pergola when young friend comes this afternoon to help me.
have been putting out some seed/nuts mix for birds as a treat, blue jays come, find the large nuts, and fly them
back to the nest, I assume stockpiling. I have a family of very happy fat doves that ground feed each day.
Plus variety of cardinals and red winged blackbirds.
hope you all have a nice day.
Buppies, feel better, sorry about paver pump. Must be a bit messy working on that machine, I always
wondered how machinery handling such sticky stuff kept going.
   / Good morning!!!! #207,459
Good morning TBN!!
59 going to mid 80s again. Clouds likely to build this afternoon.
Spent the day walking the dog and the weed eater. Finally have the area looking pretty good.
Itching to get back to the bridge but still waiting on some help.
Time for a second cup.
Everyone have a great and safe day!!
   / Good morning!!!! #207,460
Good Morning,
Ct,55 to start going to low 80’s. Partly sunny but muted skies with the smoke moving into the region. Tomorrow looks to be very warm and humidity rising with a chance of thunderstorms. Looks like I will work on Friday.
Scotty - pool setup looks great, like the layout.
Thanks Ken, still need to install the hand rail to get out of the pool, the holes are filled with yard debris. Also need to bring out all the furniture. 😉
78°
I will make it work
Dennis I built the mailbox pole replacement last year out of 6x6 pressure treated post that wasn’t totally dry. The top end has a bit of a tilt to it now. I should have let it totally dry out before erecting it !🥲
Still it will never come down in my lifetime, unless hit by a truck coming down the road 😉
Hope all have a good day 🙏
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
Gravely Pro Turn 460 60in. Zero Turn Commercial Mower (A59228)
Gravely Pro Turn...
1993 Military Potable Water Tank Trailer (A59228)
1993 Military...
2016 Ford F-150 Pickup Truck (A59230)
2016 Ford F-150...
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
1719 (A60430)
1719 (A60430)
