Good morning!!!!
/ Good morning!!!! #202,941
Hope you enjoy your time in paradise scotty while we suffer thru winter. There is a direct correlation between low to no sun spot activity and cold weather. The sunspots almost stopped in December still very low
/ Good morning!!!! #202,943
Good morning TBN!!
43 this morning and may get to 70 today.
I agree tinhack 80 Tuesday, 48 yesterday and 70 today. Quite the rollercoaster!
Not much yesterday.
Walking with the dog mostly.
Broke the welder out and ran a few beads for practice and the plasma cutter. Cut up some metal that I think I will weld to my tank as resistance to just pushing the tank for the bridge pushing out again. Wings if you will :)
Not too much on the agenda. Anxious to get the bridge started but it will be a couple more days to get it delivered. As usual "hurry up and wait"!
Time for second cup and see what the day holds.
Everyone have a great and safe day!!
/ Good morning!!!! #202,944
good morning, 33 and iced over with a thick layer of
Used ice cleats this morning walking Cody for short walk. Thankfully they give a very good grip on the ice
Checked over the tractor yesterday and found two leaks. Chased one down to coolant leak and used a long Phillips screw driver to tighten up a hose clamp. The other was an oil leak that turned out to go away after wiggling one of the quick connects for the hydraulics for the snow plow.
Watching the National Prayer Breakfast on tv to see if I can spot D in the audience
/ Good morning!!!! #202,945
Good Morning!!!! 40F @ 5:00AM. Periods of rain. High 48F. Winds light and variable. Chance of rain 100%. Rainfall may reach one inch. Locally heavy rainfall possible.
New 10-day shows Friday as being dry, as well as Saturday and Sunday. I might be able to head south a day early.
I've not done it myself, but lots of info on the 'net on refilling the small propane bottles from the bigger 5 gallon ones. I'm not brave enough to risk cutting or drilling one without first figuring out how to fill it with water.
Hang in there, gang, Friday's comin'!
/ Good morning!!!! #202,946
Good Morning from Central Texas.
At 5am, 66 degrees with same Dew Point. An unusual stretch of warm weather the last week. Wouldn't mind if we had a cold front, just not too cold!
OPINION / Question: Didn't know where to post this, so doing it here. Has anyone "made safe" / "cut into" a propane bottle. I am speaking of the 14 ounce ones like:
Now I know, NOT TO just take a grinder with a cut-off wheel to it ! What I am asking is "has anyone done this". I watched some U-tube videos where they say to block open the valve, fill with water and let that sit a week or two - claiming the gas needs to leach out of the metal ? Sounds safe, but I'd really like to hear from someone who has actually cut / drilled these before I attempt it.
I use these all the time and have accumulated a bunch of them. The local metal recycle places will NOT take them without being cut up / hole drilled in them. Thanks in advance.
Headed to Dallas. Hope all have a better day than I will. ;)
I would use a hacksaw when empty, if nervous use a hacksaw in a pan of water with the bottle submerged. Or a cordless drill while in a bucket of water.
/ Good morning!!!! #202,948
Morning all;
Nice brisk 10F with a blowing fine snow at this time, forecast 3-5" then some freezing rain and possibly a bit more snow this evening. So no plowing till late today or tomorrow morning, keep any freezing rain in the snow.
A bit of limited visibility from the fine blowing snow.
All stay safe and warm.
/ Good morning!!!! #202,949
Morning all!
Currently at 6 going to 29. 3-6 inches on the way with freezing rain to top it off.
Feeling better this morning! Will probably play in the shop while I wait to go do cleanup.
Speaking of the shop I was pleasantly surprised to win an award yesterday over numerous other turners on a world wide turning page!
Not much happening around here. Just trying to make it to spring.
I bought the first one from Harman. Didn't last any better than the last two I got on Amazon. Both of mine have the no shut off issue sporadically. Voltage spikes or drops from the power company are killing mine I think. Not sure, all I know is they get crunchy when you try to adjust them. That signals time for changing! I did find a site that list heavy duty replacements if you can do repairs. Brother in law was lead engineer at Simples time recorder. Easy peasy repair for him.
Coffee time!
Be careful with storm cleanup all!
Hope everyone stays safe and healthy!
I now have a surge protector on mine, and if I need to run on generator, it's the inverter gen that gets used now.
/ Good morning!!!! #202,950
Morning all, 31 going to 41 and cloudy.
Sheet ice from sleet this morning, school on remote for the son.
Got a bench put together for the kitchen.
Still feeling weak, took me a while to assemble as had to take frequent breaks. No sleep.
Congrats on the award Phil, well deserved.
Be well,
Had 6 deer cross the driveway, one at a time. from large to small in order.
/ Good morning!!!! #202,956
63°F and .43 inches rain.
Full, expensive day yesterday. Spent more $ at Costco than usually nothing special. Went HD in Kona and purchased 86 g water pressure tank. Bladder in old one has given up the ghost. Box had been opened, section of cardboard missing so I asked if I got and open box discount. They took off 10% much to my surprise. And I got my usual 10% on top of that. Made the trip worthwhile.
We took Sophie’s new Ascent. Drove and rode really nice. More than doubled the mileage. It was loaded for trip home.
Prayers for all
Be safe
Have a great day
/ Good morning!!!! #202,958
we routinely had explosions when operating a trash waste to energy facility due to people disposing of propane cylinders in the trash. The shredders were located in a room with heavy concrete walls for the same reason to protect the operators
/ Good morning!!!! #202,959
cancelled my trip out today, will go tomorrow.
cleaned thick layer of frozen sleet and ice off car, cleaned off wipers, and temps are now slightly over freezing.
so it's been a quiet day. Made sure the birds got some extra seed since the ground was frozen.
threw some of the cheap stuff out with the cracked corn and millet in it, some ground feeders love it.
most prefer the sunflower seeds
if birds eat insects, I wonder why they don't have bug flavors for the bird treats...besides just leaving mealy worms for them.
they aren't cheap, how about mealy worm flavored...
/ Good morning!!!! #202,960
Submerged in water would be my suggestion as well. Probably hesitate a bit once breached and let water seep in.
2010 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A59230)
2010 Toyota Tacoma...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
24in Hydraulic Auger Skid Steer Attachment (A59228)
24in Hydraulic...
2007 Ford F-750 2,000 Gallon Water Truck (A60352)
2007 Ford F-750...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
