Going to modify my chains, I think
/ Going to modify my chains, I think #1
wheelbuilder
Platinum Member
Upstate, NY
1988 Bolens/Iseki 1502, also Sears GT5000
My little bolens/iseki came with 4 link ladder chains. They help some and make the ride pretty rough with the 3 point blower on. My Dad found an old set of chains that are similar length, but for a narrower tire. I'd hoped to make these into 2 link ladder chains, but I think I'm going to try adding the shorter cross chains in at a diagonal on the 4 link chains. Hopefully it smooths the ride and adds some grip.
Anything I should be cautious of ? Clearance shouldn't be an issue.
/ Going to modify my chains, I think #2
If it's for a narrower tire are you going to have to add on to the cross chains for them to be long enough.
Or are you going to fasten to your cross chains, going diagonally from cross chain to cross chain.
Sorry, yes I'm planning on going from cross chain to cross chain. Eveything looks like it should lay flat enough and not be twisted. If it doesn't work I guess I'm only out for my time and can put the old set back as it was. The more aggressive chains are out of budget for now.
/ Going to modify my chains, I think #4
If you go from right to left and then left to right doing kind of a zig zag it will be similar to some of the chains that are supposed to be quite good.
Good luck, let us know how they work out for you.
/ Going to modify my chains, I think #5
I had an old tractor with ladder style chains and chains from a Volvo 4 x 4 military truck.
Rather than mess around trying to piece chains together, I just laid 2 sets of the military chains on top of the ladder chains and secured them
Dave M7040
Well, I got them cobbed together and onto the tractor today. They're somewhat smoother riding, but still not what I hoped for. I think I will look into making them into an H pattern or regular 2 link ladders in the spring unless the traction over the winter impresses me.
/ Going to modify my chains, I think #7
I also went the route you want to go on my Mitsubishi.
Did however need to buy some chain footage to double up my cross links.
It really makes for a smother ride with very rare slippage as well.
Also no slippage results in no noticeable 'skid marks' on pavement.
Suggest U simply order on line the extra raw chain footage U need to complete the build up.
Or again check local car scrap yards as they would have recuperated some chains over time.
Years back I purchased on EBay when shipping was more affordable as I needed all 4 wheels chained up on my plow truck.
My setup has a mix of studded as well as welded V style.
The studded way outlasts the V style and I don't drive on pavement, only gravel road beds.
/ Going to modify my chains, I think #8
I bought real V-bar tractor chains for my first tractor. Chained up on all four wheels - it could climb right up one of my big 'ol pine trees or the side of one of my out buildings. The rear chains were heavier than the Gates of Creation and quite difficult to instal. Rode like a COB - almost totally unstoppable.
One of the reasons I upgraded to my 2009 Kubota M6040. It's sufficiently heavy - 10,100# - to not need chains.
/ Going to modify my chains, I think #9
Got a picture of the results?
If you make them into an H pattern they will ride rough.
I ran 2 link spaced chains on a tractor for several years,
they worked better then standard 4 link spaced but that was all.
the Oliver has 2 link spaced and the IH 574 has a set of the Euro style studded,
the Euro style studded work several times better then the 2 link and have a good ride.
The standard 4 link spaced and the 2 link space and the H patterned or Duo chains all rode rough,
and had a spin slip and grab traction on my steep hill.
The studded Euro design is the only chain I have used that didn't have a slip and grab traction jump,
and many times required tire speed to chew for traction.
I did get a picture today. I figured out I was missing a piece. The ride is better now, I haven't had a chance to check if they grip better in the dirt, or on the driveway. Hopefully I get a couple nice days next weekend not doing car maintenance to play in the dirt.IMG_20201129_143139.jpeg
/ Going to modify my chains, I think #11
For an inexpensive option it looks good and it may be very effective for you,
good luck.
/ Going to modify my chains, I think #12
I run two sets of cheap ladder chains on the HT-23, A V-bar set over a regular twist set.
Rides OK for pushing or blowing snow. In summer, I take off the outer V-bar, but leave the lesser set on. Chains don't show in turf the way spinning rubber does.
/ Going to modify my chains, I think #13
Speaking of chains...with 4 wheel assist (4WD) does also adding chains on the front wheels provide meaningful improvement in traction over just doing the rears?
Is it worth the trade off in expense and change in ride to add them to the front also?
/ Going to modify my chains, I think #14
I would say that every situation is different,
every tractor is different, then add in the style of chain being used.
I run the studded Euro type on the rear on a heavy tractor (10,000#),
I have chains for the front but I very seldom use them, only when heavy Ice storms are forecast.
On a couple of even larger tractors we run front chains because of rear tire clearances.
Then there is one with a single front wheel chained and an opposite rear wheel chained, again for clearance issues.
If you are using a front blade to plow and are running it angled you could likely find front chains beneficial.
The studded square or diamond pattern euro chains will provide a ride that is not much different then the rubber only ride,
but with an extreme traction difference.
Adding chains front and rear will effect your tire lead lag ratio, as will just front or rear chains.
/ Going to modify my chains, I think #15
Thanks Lou...makes sense. Plan is to get the Euro style, but was unsure if both front and back were needed.
Looks like it is best in the long run to get them.
Like a life jacket...no time to go find one when it is needed at a critical moment.
/ Going to modify my chains, I think #16
I run 2 link, V bar chains for a logging buncher on 14" turf tires.. This from a custom chain making shop..
I bought a set of ladder chains from John Deere that were the approved part number for my tire size that were a horrible fit and virtually totally un usable.. It got a full refund..
No chain is going to be a highway smooth ride, but reasonably smooth depending also on the base you run on.. Mine start out pretty smooth, then when the frost goes 2 meters deep it gets rough again, and smooths out again with spring..
I do not use chains on the front.. Running in 4x4 helps with getting around, but running chains on front is too harsh on the gearing and such to be worth it..
My 5 cents of opinion...
/ Going to modify my chains, I think #17
Many if not most CUTs state that the front drive is an assist.
That being said I would not really feel comfortable chaining them as the strain might be detrimental to the more delicate drive line.
For that reason I only chain my rears, but I have studded crosses every 3 link so I don't 'slip and grab'.
Nice smooth ride with plenty of traction even on icy hills.
So I got to try out the chains in a spot I usually slip quite a bit. I usually plow the lawn's leaf pile into a small gully so they can compost. I normally need the diff lock to back from the edge, even with the chains in their old ladder config. Today, no problems, so it appears to help in that spot. I did figure out some of the roughness to the rider I missed the last diagonal where the chains link back together.
Got that in and I'm pretty content.
Snow is the next test, this last noreaster was too far east to give them a try. I'm ok with that, but I do like my seat time.
/ Going to modify my chains, I think #19
:thumbsup:
So the first serious snow of the year and they worked fine. Nothing loosened up and the grip was far better. Not even a hang up going around the long to make a path for the dog. I think having the weight one the angled links helps keep the traction consistent. I may get longer chain in the spring so the link can tie in at the sides.
