Snow Going through second stage bolts
/ Going through second stage bolts #61
Also, I am running my blower at PTO Speed (not a slower speed). I do throttle it down when I engage it, but them throttle up before blowing snow. Failure is happening at light load on the motor and not a heavy snow load or when blowing debris.
JR
Can I make certain I understand your info.
I understand you to say that you have the part shown in black on your blower except that it is painted orange. Correct?
It is not the one with the Green arrow pointing at it in the photo that is failing?
Is the bolt shown by the green arrow just a normal bolt with no grooves in it?
My friend had a new blower installed on his tractor in December. It has the style with the black hub but everything is orange so a factory blower not a dealer modified one.
The photo below is of the spare shear bolts the dealer gave him.
The bolts with the grooves are for the auger.
The shorter grade 2 bolts with no grooves are for the fan hub.
Can you advise if your fan hub shear bolts are the same as the shorter ones with no grooves and yet you are experiencing shear bolt failure.
The slip clutch you are asking about is a heavy thing with a clutch disc sandwiched between two steel disks. The two steel disks are clamped together by springs. the clamping effect transfers power through the clutch disk.
You can adjust the point at which the disk slips by increasing or decreasing the tension on the springs.
Where you see them is on pto's for a bush hog which is experiencing drive-line shock loads all the time so rather than having frequent shear bolt failures the clutch slips, you just carry on.
I have never seen one on a snow blower and never ever on a front mounted blower. The clutches require maintenance to ensure they slip when needed and are not frozen together because if they are frozen expensive things break.
In looking at the photo of the spare shear bolts my friend has. It looks like the short bolts have grade 5 marking on the bolt head. I am going to ask him to take a photo of the bolt head as these bolts were given to him with the new blower
Dave M7040
The U joints appear to be in phase to me.
I did not see any other problems. The gear reduction seemed to be fine. There was one long bolt on the side that was loose which I tightened, but in general everything seems fine. There is a little play in the front U joint to the shaft, but not very much. Any suggestions from these photos?
/ Going through second stage bolts #63
JR
My posting is going to be in reverse. After I wrote the material suggesting your blower was turning far too slow hence breaking shear bolts, I went to the Messicks site and looked around at exploded views of your blower.
The first big observation is it came with a 3 point hitch. I am not a small Kubota expert but most 3 pt hitch blowers are intended to run at the back of the tractor not the front.
There is a reduction gear assembly, actually sprockets and chains available which can be fitted to the blower assembly if its speedd needs to be slowed down because of a high speed pto which some small Kubotas do have.
The driveline on the Messicks site looks nothing like you have but exactly like a rear pto shaft would look.
I believe someone has seriously modified your blower to make it fit on the front and they did not have the knowledge to do it.
The blower could even be turning backwards which I would like you to check
Dave M7040
What is puzzling me is this. Your pto shaft turns a sprocket hidden behind the black plate but which appears to be much smaller than the sprocket which is visible with the chain wrapped around it.
This is slowing down the rotation of the shaft with the fan on it to perhaps 1/4 of the pto speed assuming your pto is coming from a mid pto on your tractor.
That shaft goes through the fan at the same time driving the fan at about 1/4 pto speed.
Next the shaft goes to the worm gear box between the two halves of your auger. This gear box is slowing down the augers again by a significant fraction.
If my interpretation is correct, the whole system is turning far slower than a normal design.
The end result of this slow turning is a great increase on the shearing force on the shear bolt(s).
By way of a comparison in the opposite speed direction, some large tractors have 1000 rpm rear ptos. The blowers they will drive have reduction gear boxes to lower the speed of the blower fan to around 540 rpm and the augers to about 140 rpm. The shear bolt in the pto shaft which is turning 1000 rpm
/ Going through second stage bolts #64
JR
Let me first say I have never even seen a snowblower until I went on TBN.
Do have a lot of PTO hours though, starting at the age of about 7. So 30 years on...
Very valid points made on UJ phasing etc etc.
I'm wondering what rpms those mid PTOs run at and also how many teeth on the sprockets on both the OPs machine, and your friend's one. Sounds like too much torque ie. it's geared too low.
( I broke a UJ yoke on a 1000rpm mower by running it for 20 minutes at 540rpm as the control in the tractor only changed the readout, the selector was on the rear end outside. Mowed OK but obviously nearly double the torque was being applied at nearly half the speed. ) Be interested just to know how the gearing is in relation to standard if it's been converted as you suspect.
/ Going through second stage bolts #65
JR
Dave, the model you want to look at is the B2781A or B2782A, the difference in the "A" model is that they add the reduction chain drive (PN: 70060-03496) and replace the 3 point brackets with the female quick hitch (PN: 70001-00840).
The reduction chain drive slows the 2500RPM mid PTO down to 540RPM at the fan input shaft.
The reason they do this is that Kubota does not make the blower, they outsource it to RAD (as do Deere, NH, Massey, LS, etc). They all use the same RAD snowblower assembly (shell, auger, fan, etc). The brands just get different brackets to match their quick hitch and the correct color paint. They also use the same snowblower assembly for 3 point blowers with different brackets and no reduction chain drive.
Edit:
Here are some pictures of a B2781A: Used KUBOTA B2781A
UsedEquipmentImage.ashx?fileName=17141-0.jpg UsedEquipmentImage.ashx?fileName=17141-1.jpg UsedEquipmentImage.ashx?fileName=17141-1.jpg UsedEquipmentImage.ashx?fileName=17141-2.jpg UsedEquipmentImage.ashx?fileName=17141-3.jpg UsedEquipmentImage.ashx?fileName=17141-4.jpg UsedEquipmentImage.ashx?fileName=17141-5.jpg
Aaron Z
/ Going through second stage bolts #66
Aczlan is right about the PTO rpm. The mid PTO that runs this front snowblower (and the belly mowers, etc.) is higher rpm than the rear normal 540 rpm. The reduction gearing is necessary and is not causing the blower to run too slow.
Guys, I really think owners with these blowers need to focus on some key things: The blowers are all made by RAD. Numerous users among MF and Kubota & no doubt other brands of host tractors are breaking shear pins/bolts at FAR TOO GREAT A RATE. The common points are the single manufacturer, RAD, that all the units are front-mounted, and the discovery that RAD has changed their protective shear design at least once. Instead of chasing so many theories, this manufacturer should be forced to back the product via the dealers and those who sell them. They owe you a solution.
Just to confirm what was already said, the blower in question is not adapted for this tractor, but was bought new with the tractor as a front mounted blower.
From post 61:
Correct.
Correct. The Green arrow bolt in post #54 is not failing, it is the Shear Bolt with the purple arrow failing. I am torquing approximately 10ft-lbs, but I have tried 5-20ft-lbs with the same results.
Yes, it is a normal bolt with no grooves in it. I bought about 20 of them at the Kubota dealer, and they looked up the part number for my blower, so I am pretty confident that this is correct.
One more thing, the U joint at the gear box as a little loose and had a bit of wobble to it. I tightened down the set screw on the side and this quieted things down a bit, so I will see if this will help. I did one pass of some drifted snow this morning and no shear failure, but only about 10 minutes of use. I will look at it more tonight.
I don't really have anything to reference, but review the photo below to see if this all looks correct.
Does this look correct with where the spline is and how the U joint is attached to the spline shaft? I have never taken this part apart, but it looks kind of strange, almost like it should be all slid back and in the bearing housing to the rear.
/ Going through second stage bolts #69
I had a Farm King 74" which was rated for 40 - 70 HP. Ran it on a JD 4200 with 26 HP.
I couldn't put enough original shear bolts in there. They just broke. They even felt like they were made from aluminum when I tightened them.
I went to the hardwarestore and bought a hand full domestic bolts and it fixed the problem. They still broke, but did last 10x longer.
/ Going through second stage bolts #70
Does the fan turn perfectly smooth and without rub by hand? My rear PTO shaft on my yanmar is completely freewheeling by hand when not engaged and engine off. I just finished a custom front mount JD snowblower that runs off a chain drive from the rear PTO. This driveline should have more friction than yours yet I can still turn the whole thing easily by hand. If you can't you need to figure out why. There's another thread currently where a guy clearly has water in his gearbox and he can't turn by hand. If there are any hard spots in the rotation you should investigate those hard spots, such as the chain sprocket being out of round and putting tension in the chain in one spot, or the fan rubbing the housing in one spot (Deere blowers have a tendency for both).
I notice that you have a lot of bright metal around your fan drum, and also behind. I've seen paint worn around the drum but behind is really interesting and I wonder if you are rubbing the fan against the rear of the housing. As has been said in my experience you can send some pretty good size gravel through these without breaking a bolt. The deer blowers use a 1/4" grade 5 bolt as a shear pin with a similar leverage on the fan so should be about the same.
Just another final thought. Set your shoes up a little bit more so you aren't getting any gravel through the blower at all. If you keep breaking pins when hitting absolutely nothing you know you need to investigate your blower some more.
/ Going through second stage bolts #71
I had a similar problem. 2 different causes resulting in auger bolts shearing. Top sprocket
/ Going through second stage bolts #72
I have been running a 5ft Agro-Trend 3pt mounted snowblower for 20 years. I don't use it many times per year but when I do it is usually rough and a workout in heavy snow. In mountains of WV. I can recall throwing large gravel accidentally for long distances, picking up chunks of ice that went through the blower sounding like a bush hog that just hit a 2x4. I drive it with a 24hp Kubota B2150. I have never replaced the original shear bolt. Never a problem (yet...) So I have to wonder what on earth is wrong with your rig. I've never owned a Kubota brand snowblower but I heard they are made in Quebec for Kubota by a company with a pretty solid reputation. What you describe is just not right -- something is haywire. The shear bolt must fit very snug/tight and cannot have any play in the hole. Go read the manual and don't count on the dealer to give you the right shear bolt. Does the rotor turn fairly easily by hand (when the tractor is shut off) and not seem to be catching on something or wobbling ? By the way, shear bolts are normally intended to break when excessive loads occur and are NOT normally high grade bolts. Plain old grade 2 usually. I would not go putting in a super strong bolt until I figure out what the problem is. The manual should tell you what grade bolt to use. Checked the lube in the gearbox ? ... Let us know what you find !
Had the same problem twice during my ownership, 2 different causes. 1st top sprocket set screws work loose allows the shafts to move forward enough for auger to contact housing. 2nd the chain has lost lubricant and there are stiff links developing they then ride up the sprocket and really engage, act like an impact hammer and the shear bolt shears
When the shear pin is sheared, the fan turns smoothly without rubbing. I think all of the bright spots where there is no paint is from sand going through it. I tried pulling it front to rear, and I cannot make it drag. My driveway is paved, so the only sand I am getting is from my driveway when I send it, or from the road sander at the bottom. Generally this stuff is all 1/8" or less. Maybe there is a chance that the sand is just the right size to jam between the fan and it's housing, but others do not report this happening.
One other possibility that I am considering is that the last universal joint going into the snowblower seems to loosen up easily and has a bit of a wobble to it. There is a setscrew in this that seems to back out quickly, and I will try and keep it tight with locktite, and I may disassemble it and see if I can tighten it up with a new key, since I am running out of ideas.
/ Going through second stage bolts #74
Sounds like a logical reason for it to loosen up.
Aaron Z
/ Going through second stage bolts #75
Instead of focusing on the setscrew, it might be worth considering the u joint fit that you are asking the set screw to deal with.
Look at some of the loctite products in this booklet designed to tighten up the fit of the parts themselves.
Start around page 16 up, http://www.loctite.ph/php/content_data/LT4680.pdf
Dave M7040
/ Going through second stage bolts #76
I am not familiar with snowblowers at all.. but pto and driveshafts yes.. would it be advisable, to the OP, if you are going to disassemble the UJ from the shaft?- I'd consider replacing set screws with roll pins. They will hold tight
Good Point. There are two things holding my U joint to the shaft. One is a bolt going though the shaft and U joint, and the other is the setscrew that pushes on the shaft that takes the wobble out of it. It seems like it would be better to replace the bolt with a roll pin, which would take more of the wobble out and make it tighter before the set screw is tightened. Do others have this bolt through the drive shaft, or is it a roll pin normally? A roll pin makes sense, since I never have to take this U joint out when changing attachments .
/ Going through second stage bolts #78
Every UJ I have seen on a pto has had a double roll pin ie a little pin inside a bigger one. The only reasons I can think of that they've used that setup, is access, and low hp. Could be difficult to drift pins in and out if it is right in there? You will know the answer to whether it's do-able. Maybe the manufacturer used the bolt for that reason, if you damaged the UJ it may be easier to remove the bolt? Then again, designers draw things and engineers build what's on the sheet. Often little feedback back to the design team.. your problem intrigues me!
/ Going through second stage bolts #79
Mine had a trouble with the drive gear loosening up and the shaft would move back and forth. I had to clean out the thread and use new loctite on them.
Also I've seen some over tighten sheer bolts. The type with self locking nut on the auger (with two cuts on the bolt) need to be snug tight. On my BX2750D the fan uses split lock washers and has one sheer cut on the bolt. I tighten these until the split washer is flat, no tighter. It's easy to "pre sheer" the bolts if you're not careful. Maybe? These bolts are not designed to tighten the assembly together, they're designed to sheer and protect the assembly.
Hope this helps you figure it out.
/ Going through second stage bolts #80
I have just been back tracking through the thread to find pictures and be sure I'm on the right one myself...
If that shaft is spinning at ~2500rpm then I would definitely not be running that bolt and setscrew setup. That could explain your "timebomb" that you described, the operating time being similar between failures of the shearbolt. Someone above suggested some type of locktite that may be of use to you, and it doesn't look like any issues access wise if you need to replace the bearing/UJ at any point in the future. You may even wish to keep the setscrew and locktite that in too, but a rollpin instead of that bolt would be my next step. You've certainly got to know your machine!!
Ps I'd have to agree with whoever suggested removing the chain and keeping it in oil over the off-season, sounds like a good idea to me.
2009 Jaguar XF Sedan (A61574)
2009 Jaguar XF...
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
14ft Flatbed Truck Body (A59228)
14ft Flatbed Truck...
John Deere Gator TX4x2 (A62177)
John Deere Gator...
karcher pressure washer (A61567)
karcher pressure...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
