sd455dan
Super Member
- Joined
- Oct 23, 2012
- Messages
- 6,294
- Location
- North Idaho
- Tractor
- Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
like much of the above GM had reports the cranks bearing surfaces were not finished to a quality finish. A micro polished crank is almost as reflective as a mirror.My Toyota Land Cruiser calls for 0W-20. It's a 5.7 V8 engine. It's fine. The 5.7 is known for being bulletproof.
It's not the oil, it's the internals. The thicker oil is just a band-aid.
Again, this motor has been in GM cars and trucks for over 20 years. Roller lifter engines are not holding up to the old design of flat tappet engines. That is not the oils fault.
Roller cams should actually hold up better minus having such a high number of roller bearing pins that can actually fail. They pulled the ZDDP out of oils and that has damaged, shortened the life of or killed many flat tappet cams and lifters of older engines. Going to thin oil was not about wear protection, it was done to eek out another % or two of MPG for Corporate fuel mileage standards and not also slowly kill Catalytic converters. Of Course jmo.
Chrysler Stellantis specced that thin weight oil for many of their engines. my sisters V6 wrangler started using a quart in 500 miles with that 5W-20 oil @ all of 36000 total miles. About ten years ago we all decided to just switch it to 5W-40 T-6 and everything improved instantly. MPG, oil use dropped to under a quart, between oil changes, and the engine runs quieter as well. More than a decade of 5W40 use and it runs great.
The Ford F 150 i picked up recently started to rattle when fully warmed up on hot days at low idle in reverse. ( $1K -not complaining) Cam phaser rattle. We dumped the factory water viscosity oil out and put in just 10W-30. Noise gone and hasn't come back. I despise that thin oil. If it was minus 40* out everyday I would probably be singing it's praises.
