Glow plug info for newbie
/ Glow plug info for newbie #1
Millwood
Millwood, Washington
Kubota B3300SU
This is my first tractor. It's brand new. It's a Kubota B3300SU. I've read the owner/operators manual 3 times, cover to cover. Then I went on a Kubota Tractor website and got completely different information from an experienced Kubota mechanic. Winter is coming and I anticipate moving lots of snow. So now I'm confused.
The operators manual says to engage the glow plug as follows: Over 32 degrees/2-3 seconds. 23-32 degrees/5 seconds. 5-32degrees/10 seconds.
Kubota Tractor mechanic says to engage glow plug a full 60 seconds when temps get around 32 degrees. WHAT??!!
I understand compression ignition engines. I want to pre-heat the initial fuel to the cylinders, but 60 seconds seems excessive, or is it? I don't want to fry the glow plug out! I have magnetic crankcase oil heaters/ battery tenders I use, and all equipment is stored inside an unheated barn.
So what does the experienced Kubota community think?
/ Glow plug info for newbie #2
You probably won't need any more than 10 seconds to get it started. But you posted your question in the wrong forum.
Would have been better served here: Kubota Owning/Operating
/ Glow plug info for newbie #5
You get a feel for it. Mine will start on 15-20 seconds until it gets down to 0. Parked inside vs outside also makes a difference.
/ Glow plug info for newbie #6
When it's real cold out (I store my tractor in an unheated, uninsulated shed), I may go close to 20 seconds, but typically until the fuel gauge makes its way all the way to the full mark (when the tank is full) is enough.
You'll get a feel for how long with some experience based on white smoke or not. If it's cranking and sputtering white smoke, it'll need more GP time to start easier.
The mechanic you heard from apparently has never started a small Kubota diesel engine in the cold, or most other diesel engines for that matter. Even my old 7.3L Powerstroke didn't need a full 60 seconds to get a clean start in very cold temps.
/ Glow plug info for newbie #7
The book has it pretty much correct 20 sec is max needed for my bx series Kubota
GEHL RT14 SKID STEER (A65053)
GEHL RT14 SKID...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
2023 CATERPILLAR 259D3 SKID STEER (A65053)
2023 CATERPILLAR...
1991 FRUEHAUF 45'X96" FLATBED TRAILER (A65643)
1991 FRUEHAUF...
2020 International LT625 Sleeper 48" (A62613)
2020 International...
2021 International HX620 Quint Dump (A62613)
2021 International...
