Glow plug indictor
/ Glow plug indictor #1
lewispmills
McKee, Kentucky
Case IH 5130 and John Deere 550 Dozer and Yanmar VIO50 Excavator and Case 1845C skid steer and Kioti LK3054 & Case IH Farmall 80 4wd w/cab and fel
My glow plug indicator on my 2000 LK 3054 is blown, does anybody know where I can purchase one online? I don't have a dealer close.
Lou
/ Glow plug indictor #2
Mine just quit on my CK30 with only 118 hrs on it as well
/ Glow plug indictor #3
I lost mine at about 50hrs on my '05 3054. Replaced it and it lasted about 15 seconds. Called the dealer; they showed up and changed the three glow plugs and the 15 second old indicator;it's still working at 160hrs:confused: Although I've never used them,either Wallace or DePratt does online sales
/ Glow plug indictor #4
My dealer is 85 miles away. How hard is it to change he bulb? Pull Dash,cowling? Thanks in advance!
/ Glow plug indictor #5
I am a Kioti Dealer in Yorkville Illinois and would be glad to help anybody out with parts needs and questions.:) I have bulbs in my inventory now for a CK30 and LK3054. These bulbs are inexpensive. Actually they have the same part numbers. They are not difficult to change either. The upper cowling needs to be removed enough to gain access to the rear of the instrument cluster. The bulbs are located in the rear of the cluster. I can give more detailed directions if needed. For more info and if you would like me to send parts to you, contact my email, rayb322@yahoo.com. Thanks and we look foward to hearing from you.
Ray
/ Glow plug indictor #6
The indicator on the 3054 is an inductive wire "pig-tail" that glows when energized,not a bulb, but the instrument cluster does need to be removed to access the indicator
/ Glow plug indictor #7
The pig tail on my 3054 appeared to burn out but the next time I started it, it glowed. Last time it was dead again.
Now to my question - if it's not glowing, are the plugs still heating up? Anyone know the answer for sure?
/ Glow plug indictor #9
If the "pig-tail" is not glowing,neither are the plugs.The "indicator" is just that;an indication the glow plugs are being energized.It is between the power source(battery)and load[glow plugs].It is possible the ignition switch is defective in the glow plug position,but not likely.You can test this by removing the supply line at the plug closest the fire wall,and using a multi-meter or test light between the wire and [ground]while operating the switch to the pre-heat position.
/ Glow plug indictor #10
I confirmed with Rick Wallace's part guy (Mike) that the pig tail is just a resistor, so it does not mean the plugs aren't being energized. They are in fact, but without the indicator, it is easy to over heat them and maybe burn up the plugs. They didn't have my part in stock but they will order it Monday.
/ Glow plug indictor #11
Some would call the nichrome wire a "resistor" but in an application where it "glows" it very well COULD be inline between the power source and the glow plugs.
/ Glow plug indictor #12
Lou
Hi Lou - I'm not sure if anybody asked?? But will your engine still start if you turn the ignition on? For those of us that are just :confused: Thank you for posting.
The Kid
/ Glow plug indictor #13
The Kid
John here - not Lou, but I can answer the question - Yes, it starts even though the indicator is blown. I've started mine three times since the indicator wire burnt out.
/ Glow plug indictor #14
I can only attest to my own experience;when the indicator on my 3054 burned out there was NO power being supplied to the glow-plugs. That was the first thing I checked.I called the dealer and asked if I could bypass the resistor(indicator),as it was winter and my unit will not start if the temp is much below 40*.The mechanic told me I could make a "jumper" between a hot wire and the plugs,which is no great revelation, but works if you're careful not to energize them too long,as they are getting more amperage than they get with the resistor in place:cool:
Patches is exactly right. It still starts with enough cranking. I pulled the indicator (resistor) out and taped the leads together. I count 7 seconds and its starts right up. Obviously the glow plugs work this way, I'm just afraid of burning up my glow plugs.
I contacted a dealer thats 80 miles away and he's shipping me the part. Cheaper than the fuel ($3.39/gal) to go get it.
Thanks everybody,
Lou
That's great. My tractor will start without the glow plugs when its above 40 degrees, but if it's below that, I have to crank it alot, really to much, wears on the starter, if you know what I mean. Glow it for 5 seconds and it starts right up. I wonder what the difference is between your tractor and mine? Do you add something to the fuel or do you keep it in a heated garage?
Lou
That's great. My tractor will start without the glow plugs when its above 40 degrees, but if it's below that, I have to crank it alot, really to much, wears on the starter, if you know what I mean. Glow it for 5 seconds and it starts right up. I wonder what the difference is between your tractor and mine? Do you add something to the fuel or do you keep it in a heated garage or are some tractors just nor cold natured than others?
Lou
/ Glow plug indictor #19
You're fortunate a 3054 starts that well; I keep mine in an unheated garage but have a lower coolant hose heater, which i use, usually for at least an hour, use the glow plugs for (2) 10 second periods, then go to start. The tractor starts but runs roughly for 5-10 seconds after it fires, even though I immediately go back to the glow plugs. It was much worse, so the dealer shimmed the injector pump, which retards the injector timing
Well, I am fortunate. I usually use the glow plug the first time I start it but I don't have to if its not to cold. It does run rough for a few seconds though. Mines a 2000 model with about 800 hours.
Lou
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
SKIDDED PLAIN/WASTE WATER TANK (A60736)
SKIDDED...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
12FT X 20FT STEEL CARPORT (A58214)
12FT X 20FT STEEL...
New/Unused Grapple for CFG Mini Excavator (A61166)
New/Unused Grapple...
