Glow plug indictor
   / Glow plug indictor #1
lewispmills
McKee, Kentucky
Case IH 5130 and John Deere 550 Dozer and Yanmar VIO50 Excavator and Case 1845C skid steer and Kioti LK3054 & Case IH Farmall 80 4wd w/cab and fel
My glow plug indicator on my 2000 LK 3054 is blown, does anybody know where I can purchase one online? I don't have a dealer close.
Lou
   / Glow plug indictor #2
Mine just quit on my CK30 with only 118 hrs on it as well
   / Glow plug indictor #3
I lost mine at about 50hrs on my '05 3054. Replaced it and it lasted about 15 seconds. Called the dealer; they showed up and changed the three glow plugs and the 15 second old indicator;it's still working at 160hrs:confused: Although I've never used them,either Wallace or DePratt does online sales
   / Glow plug indictor #4
My dealer is 85 miles away. How hard is it to change he bulb? Pull Dash,cowling? Thanks in advance!
   / Glow plug indictor #5
I am a Kioti Dealer in Yorkville Illinois and would be glad to help anybody out with parts needs and questions.:) I have bulbs in my inventory now for a CK30 and LK3054. These bulbs are inexpensive. Actually they have the same part numbers. They are not difficult to change either. The upper cowling needs to be removed enough to gain access to the rear of the instrument cluster. The bulbs are located in the rear of the cluster. I can give more detailed directions if needed. For more info and if you would like me to send parts to you, contact my email, rayb322@yahoo.com. Thanks and we look foward to hearing from you.
Ray
   / Glow plug indictor #6
The indicator on the 3054 is an inductive wire "pig-tail" that glows when energized,not a bulb, but the instrument cluster does need to be removed to access the indicator
   / Glow plug indictor #7
The pig tail on my 3054 appeared to burn out but the next time I started it, it glowed. Last time it was dead again.
Now to my question - if it's not glowing, are the plugs still heating up? Anyone know the answer for sure?
   / Glow plug indictor #9
If the "pig-tail" is not glowing,neither are the plugs.The "indicator" is just that;an indication the glow plugs are being energized.It is between the power source(battery)and load[glow plugs].It is possible the ignition switch is defective in the glow plug position,but not likely.You can test this by removing the supply line at the plug closest the fire wall,and using a multi-meter or test light between the wire and [ground]while operating the switch to the pre-heat position.
   / Glow plug indictor #10
I confirmed with Rick Wallace's part guy (Mike) that the pig tail is just a resistor, so it does not mean the plugs aren't being energized. They are in fact, but without the indicator, it is easy to over heat them and maybe burn up the plugs. They didn't have my part in stock but they will order it Monday.
Seppi Mini BMS 85 Mulcher excavator attachment (A52128)
Seppi Mini BMS 85...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2014 PETERBILT 388 AUTO TRANSPORTER (A51222)
2014 PETERBILT 388...
2008 CATERPILLAR 304C CR EXCAVATOR (A51242)
2008 CATERPILLAR...
