Getting ready for Winter?
/ Getting ready for Winter? #1
kevincook
Platinum Member
k
I never got around to posting this picture last winter. I found a used cab and a used front mount blower for my L3010 last December. I looked at the B3030 but it was just too small and I figured it made more economic sense to upgrade what I had instead of jumping into a L3430 Cab.
It works great. Throws snow fast and I stay warm and dry.
Kevin
I never hooked up the hydraulics for the chute rotation last winter since I only have a three position loader valve. The regen circuit on the dump prohibits the use of the 3 position valve for the chute rotation.
I have been trying to figure out the best way to solve this problem and I was ready to order the 4-position valve for $600 from the dealer. I figured that this would be the cleanest set-up. The other day it occurred to me that if I switched the hoses on the loader valve and used the lift circuit for the chute rotation and the dump circuit to raise and lower the blower then I could use the valve I already have.
I hooked it up today and everything works great.....just saved $600. Hmmmm. I wonder what I should spend that on now?
I just thought I would pass this along in case anyone else was up against the same problem.
Kevin
Yes. I put quick disconnnects on all the hoses.
Kevin
/ Getting ready for Winter? #5
I think I am ready for snow.
/ Getting ready for Winter? #6
Kevin,
Thats a nice photo of your rig. I bet that dude can handle some pretty serious snow! Nice shot of our flag with it.
BD
/ Getting ready for Winter? #7
kevincook said:
Yes. I put quick disconnects on all the hoses.
Kevin
Get some colored tape and color mark the hoses for reconnection next season. That will save you a lot of time trying to remember how you did it last season.... unless you are young and have a good memory.:D
Now all you need is a heater in the cab to keep you warmer... Snowblowers are great.. Snowblowers with cabs are best!!:p
/ Getting ready for Winter? #8
Hope you've got a heater in that cab - it makes all the difference. Being able to blow snow while in shirtsleeves and listening to some great music is cool. Put a spreader on your 3ph and you'll be all set.
/ Getting ready for Winter? #9
Kevin
Hey kevin,
What is the model number of your snowblower? I have a BS2750B that I run on my BX2230. I wish it had hydraulic chute rotation like yours has. I am thinking of adding that feature to mine and would like to get some ideas.
Thanks guys.
I have a heater in the cab but it isn't hooked up yet. I just got the adapter from Curtis Cab so hopefully next weekend I'll get the heat working.
ewoz, I'll have to double check the model number tomorrow. Do a search for chute rotation and look for some posts by Von. He used an electric motor for his.
Kevin
/ Getting ready for Winter? #11
ewoz said:
Hey kevin,
Power window motor works great, cheap too about $25. I added it last year, nice, also added a motor to the chute deflector, about $75.
Do a search you will find info on both of these projects.
And oh yea where is your cab? :D
/ Getting ready for Winter? #12
kevinj
I've been thinking of buying an 1850 for mowing and snowblowing. How far does the blower lift off the ground? I have a problem with my current mower/blower in that the blower doesn't lift far enough. I have to keep it in a shed and go up ramps, the blower is so low it would get stuck. Also, what model blower is that? It looks like a different # than what the dealer says he'll mount on the 1850.
/ Getting ready for Winter? #13
kevincook said:
Thanks guys.
Heat? Anybody can do it with heat in the cab. :D Me, I don't have any heat and I am tough :D
Bob
PS I also don't have any choice. I wish I had a heated cab.
/ Getting ready for Winter? #14
kevincook said:
Thanks guys.
Kevin
Are you going to tap off the bottom of the thermostat housing or taking it off the radiator hoses? Post some pictures when you can. I also have a heater that hasn't been hooked up yet. I dress warm, and try not to stay outside too long. I think that I am a snow bird that forgot to fly South.:D
Dusty
/ Getting ready for Winter? #15
Anyone thinking of adding heat to a BX?? If so, I have the 1"T fitting for the radiator hose. I got 2 thinking I could put it in the lower and top hose. It fits the top radiator hose but no place to put it on the bottom radiator hose.:mad:
I paid $9.50 for the part plus $8 to ship for a total of $17.50. You can have it for $10 plus what ever it costs to ship, PM me if interested.
/ Getting ready for Winter? #16
Looks like a great machine. I sure could use one like that. :D
With mine I have no trouble keeping warm. See attachment.:)
/ Getting ready for Winter? #17
Double 00 Soul said:
kevinj
I would have to measure it, but I would guess it raises about 8".
/ Getting ready for Winter? #18
ewoz said:
Hey kevin,
I assume you meant this to me?? It is a 2750 from my BX1500. The chute rotator is a Kubota unit I added when I got the BX1850.
/ Getting ready for Winter? #19
How are you going to be returning the coolant to the engine if the adapter won't fit the bottom radiator hose? On mine, I was thinking of returning to the block where the block heater goes and installing a heater in the lower hose. If the heater return won't fit the lower hose, then the block heater idea won't work either. How do they do it on the later model BX engine that doesn't have the tapped hole in the side of the block?
Dusty
/ Getting ready for Winter? #20
2003 HRTO 14ft. Enclosed S/A Trailer (A61574)
2003 HRTO 14ft...
REDBALL 4R HOODED SPRAYER (A64276)
REDBALL 4R HOODED...
2002 Pace American of Texas Trailer, VIN # 47ZA528212X020330 (A61572)
2002 Pace American...
2015 Chevrolet Traverse SUV (A61574)
2015 Chevrolet...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
Towable Pipe Road Crossing Trailer (A63689)
Towable Pipe Road...
