Get a Grip
/ Get a Grip #21
That's a really nice set set up, Jinman,
All I can think of besides seeing <font color="green"> GREEN</font> is:
/ Get a Grip #22
Jinman,
You can't fool me, based on the first picture I think that's a reused porch swing. Looked quite comfortable too, until you bolted that extra stuff on it. Now it's ruined as a traveling commfy chair.
Cliff
Do I really need to use smilys? That does look like a very useful setup.
/ Get a Grip #23
Jim, Where did you get the quick attach brackets that are bolted to the rock bucket?
Terry,
TC40DA
/ Get a Grip
When are you posting some action shots of your grapple, PineRidge? Has the weather been uncooperative? It's been rainy here until yesterday when it turned off beautiful (81°). /forums/images/graemlins/cool.gif Today is another poster day for weather here, but then it turns back cold. Heck, they are saying it may get down to the upper 30's at night before the end of the week. Gotta love this Texas weather. /forums/images/graemlins/grin.gif
/ Get a Grip
</font><font color="blue" class="small">( 's a really nice set set up, Jinman, )</font>
Thanks, Bill. Having a rock bucket with this design was one part that made my project quick and easy. I had doubts about the 3/8" u-bolts, but yesterday I stalled the hydraulic cylinder several times and it didn't phase the u-bolts. I think they are strong enough for most anything I'll do.
<font color="blue"> TCOwner:</font> The quick-attach bracket that came with my rock bucket is big, strong, and fits New Hollands quick attach bracket perfectly, even better than New Hollands own implements. I think it is probably manufactured by the company that made the rock bucket. Here is a link to their website:
S-Houle Equipment
<font color="blue"> Cliff: </font> You spilled the beans on me. /forums/images/graemlins/shocked.gif That ol' rusty porch swing sure makes a good implement. /forums/images/graemlins/wink.gif
/ Get a Grip #26
Jim the past couple of days its been rain and then snow here. The grapple is finished and as soon as the weather moderates I'll get a few pictures taken.
/ Get a Grip #27
Jim,
<font color="blue"> Daedong: Let's see, the only boat I own is shown in the attachment. How long do you think it will take me to get to the Murray River? </font>
How many batteries do you have /forums/images/graemlins/grin.gif
/ Get a Grip #28
Jim you may want to head on over to your local TSC and pick up a part number Universal 1404-6-6 R.031 restrictor. It's 3/8" x 3/8" and will fit your grapple cylinder. It has a 1/32" orifice and will slow your grapple to a comfortable working speed.
Priced at just over four bucks. Cheers! /forums/images/graemlins/grin.gif
/ Get a Grip #29
Hi Jim,
I can tell you, you are going to enjoy that more than you can imagine.
I was down at the local saw shop, buying a pole saw, when the salesman said, the only bad thing about these is they create too much clean up work, too fast. I told him my clean up work would go fast & I would enjoy the cleanup more than the cutting.
My guess is, you won't be taking the grapple off very often.
/ Get a Grip
Thanks, PineRidge, but I beat you to this one already. That's good advice for anyone building a circuit to control a cylinder where controlled flow is a must. My New Holland dealer has lots of those and suggested them to me a long time ago. I use them on my TnT and the Grapple. I can just feather the remote valve handle and make the jaws slowly close or go full open and the jaws move from open to close in about 2 seconds. It's very controlled and easy to operate. I think my orifices are 0.030". /forums/images/graemlins/cool.gif
One thing Mark at CCM pointed out to me is to be sure you have a right angle adapter between the orifice and the hose because the jet flow of fluid will eventually bore a hole in the walls of hydraulic hoses. I think it would take awhile to do that, but I've found Mark doesn't say things unless he has a reason.
/ Get a Grip #31
<font color="blue"> One thing Mark at CCM pointed out to me is to be sure you have a right angle adapter between the orifice and the hose because the jet flow of fluid will eventually bore a hole in the walls of hydraulic hoses. I think it would take awhile to do that, but I've found Mark doesn't say things unless he has a reason.
</font>
Jim, I have heard that mentioned before also but decided to test the theory. My restrictor is installed straight in line with one of the grapple hoses. This particular hose has a bit of excess so I figured that if the hose ruptured as a result of the restrictor then I could easily cut off the damaged end and have a new connector crimped into place and then deal with the location of the restrictor itself. I'm betting a failure won't occur in my lifetime but I could be wrong here too.
/ Get a Grip #32
<font color="blue">I have heard that mentioned before also but decided to test the theory. </font>
Mike, I remember CCM's post on that and it was more than a theory. It was experience they had with something (forget what) where a number of the same items came back with hole/leaks in hydraulic hoses, and the cause was traced to the hose being cut internally by the fluid shooting out of the oriface hole, sort of like high pressure water can cut steel plate.
Anyway, it might have been due to a bend in the hose right after the oriface. If your setup is straight, and the high pressure stream does not directly hit the hose material, and the energy is dissipated within the fluid in the hose, you should have no problems I would bet.
/ Get a Grip #33
Boy JinMan, that bucket/grapple would have saved me weeks of sweaty, back-breaking work when I cleared my land. I nearly ruined my knees clearing 8 acres of briar thickets, brush, and arm to leg sized trees. Nice picture story too.
/ Get a Grip #34
</font><font color="blue" class="small">( You can't fool me, based on the first picture I think that's a reused porch swing. Looked quite comfortable too, until you bolted that extra stuff on it. Now it's ruined as a traveling commfy chair.)</font>
Cliff,
Still looks like a comfy chair to me! Heck, I just got back from riding the Hulk roller coaster down in Universal, Orlando. This looks similar. I look at it as Jim's bench/chair now has a sholder strap for safely riding out front.
Jim - What a great setup. Very well done. Put me in the "jealous" category with the rest of the posters.
Brian
/ Get a Grip
</font><font color="blue" class="small">( My guess is, you won't be taking the grapple off very often. )</font>
<font color="blue"> Neal: </font> I think you are right. The only reason I see for taking it off is if it's in the way when I'm actually using the rock bucket for rocks. I'll leave the grapple base and beam attached and just remove the cylinder and jaws. As a matter of fact, when I get ready to mount the grapple onto my loader bucket, I'll probably see if Andy will sell me just the base. That way I can leave a base permanently installed on two buckets and just move the jaws and cylinder as needed. That's an advantage of a small, lightweight grapple. /forums/images/graemlins/cool.gif
/forums/images/graemlins/smirk.gif
/ Get a Grip #36
Jinman, To say I'm jealous is an understatement. Nice work.
A bit off topic, but....have you posted any details of that toolbox and how you mounted it up above the fuel tank ??
I'm thinking that's something I can use and afford /forums/images/graemlins/crazy.gif.
/ Get a Grip #37
)</font>
Wonder if Jim would loan it to me for digging 'taters? Looks like it would be fast and gentle on the spuds. /forums/images/graemlins/smile.gif
/ Get a Grip #38
<font color="blue"> A bit off topic, but....have you posted any details of that toolbox and how you mounted it up above the fuel tank ??
</font>
Don't know how Jim mounted his tool box but this is how we solved the problem. toolbox
/ Get a Grip
</font><font color="blue" class="small">( A bit off topic, but....have you posted any details of that toolbox and how you mounted it up above the fuel tank ??
I'm thinking that's something I can use and afford .
)</font>
I didn't know if I was gonna slip that by without anyone noticing or not. I just got tired of not having a good toolbox and decided to give this simple solution a try. It's an Irwin brand toolbox I bought at Home Depot. The thing is 26" wide and is nearly a perfect fit between the ROPs uprights. I used some old rubber bedliner (1/4" thick) under the toolbox to kinda pad the top of the gas tank. There were brackets on the sides of the toolbox just right for me to use more U-bolts in addition to the ones on the grapple. I'll post a few pictures to show how I mounted the box. I really like this box because it sheds water and has no holes to leak water down into the box. Heck! If I was diggin' tators with Have_Blue, I'd be able to put about 25# in this box. /forums/images/graemlins/laugh.gif
/ Get a Grip
The only problem with the toolbox is it is so big some of my rear view is blocked. I keep my seat adjusted high when boxblading in reverse so I can see what I'm doing. It's not bad, but I don't have the clear view of everything as I had before.
1998 VOLVO AUTOCAR WATER WELL DRILL RIG (A65643)
1998 VOLVO AUTOCAR...
2008 Ledwell LW48HTHT2 48ft. 40 Ton Hydratail T/A Step Deck Trailer (A64194)
2008 Ledwell...
2013 Ford Explorer AWD SUV (A64557)
2013 Ford Explorer...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
Landhonor 24" Mini Excavator Bucket (A66285)
Landhonor 24" Mini...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
