geothermal questions and possible DIY
   / geothermal questions and possible DIY #141
I now wish I had investigated geo when I built our new home 4 yrs ago. We have a lp forced air system but when they dug the well 60 feet from the foundation, they said they hit an artery and the water was almost overflowing. I wonder what it'd take now and whether it'd be advantageous to spend the money for a new furnace.
   / geothermal questions and possible DIY #142
Geothermal is more plumbing than anything else if installed with gauges and valves... troubleshooting is pretty straight forward. Its pumps and valves, plumping. I would call a refrigeration guy for the geo units before I called any HVAC guy..... or make sure the HVAC guy does refrigeration, its not a furnace. They are actually pretty straight forward. If you are not in a colder climate you ROI is harder to get to compared to air source. Ours makes all our potable hot water(in winter) So roi is much faster.
_________
Using a standard gas furnace as our air hander allows us to switch to 4 tons of hot water to the potable hot water indirect water heater, if the 80 gals of 115 degree water doesn't last. It then switches back to the water to air coil furnace shuts off. The way we currently have it we can't keep up in the summer. There is a timer when the unit switches between hot and chilled water. That lag time is a killer. We use indirect in the summer, we have less hot water demand anyway as we are not washing cars and trucks as much.
_____________________________
its going on 28 years, however with some changes and improvements we can get it to make all our potable hot water and be even more efficient in the summer. I just can't figure out why I didn't think of it earlier.
   / geothermal questions and possible DIY #143
It's as simple as setting a furnace, tying in ductwork, supplying electric, and water supply and return.
You could use your existing furnace, remove the current evap coil and install cased water coil and all you need is a plumper and electrician. Doesn't get any easier than that. You would need a 40-50 gal electric water heater as a buffer after the cased coil. $10,00-$12,000 and you could problem get it installed for that. It been a while but cased water coil is $2,000 a climate master 2 stages is roughly $6,000 a pump water heater and piping I don't think I am that far off. These days getting the tin work done has been the hard part.
   / geothermal questions and possible DIY #144
You had a moron for a contractor...plain and simple.
So your contractor was an idiot.
Can't say I disagree with you. The sad part is, he is the best I have found within 50 miles of my house.
   / geothermal questions and possible DIY #145
Heatpumps in general should have much larger air ducting system due to large air volume needed in order to operate efficiently.
For optimum performance your current forced air duct-work may need some extensive redoing depending how it was sized?
We've had a closed loop Climate Master 2-stage geothermal unit for a long time now and the air coming out of the registers is in the low 90's F when operating at the max heating output.
Cheers
PS. I think they are offering variable speed single compressor models nowadays - anyone here who has experience with those?
   / geothermal questions and possible DIY #146
My only comment is, directional boring (which is a requirement of any loop system is always the major expense and not something you can do yourself. Takes specialized equipment to achieve.
   / geothermal questions and possible DIY #147
You can open dig them, it just may or may not be practical depending on how deep they need to be or things that are in the way.
   / geothermal questions and possible DIY #148
Here's what a 5' x 5' dig for a loop looks like - lucky no rocks!
Yea, they can be open dug.
So perhaps "excavation" is the major expense.
I did my own excavation. 4 ton required 4 loops, which is 4 trenches ~120' long, 6' deep, and 3' wide. Each trench ~20' apart. So a total area about 120' x60' is all that's needed.....plus a little room to maneuver a machine and backfill.
Those 4 trenches are connected to the house off a main trench about 80' long.
So in total I dug about 560' of trench. And at 3' wide and 6' deep, about 375 yards of material.
It can be done in an day with either a full-sized backhoe or a 5t mini with a 3' bucket.
You can rent said machine for $500. And I had less than $500 in material for the loops.
   / geothermal questions and possible DIY #150
Correct but here the PEX must be at least 54" deep to access the ground temp. I would not want to open dig any loop system when directional boring is much quicker and easier...and the HX unit will also be a major expense. My buddy has a Water Furnace (2nd one), first one was in his other house. I don't know the cost but it wasn't a cheap date by a long shot. His total utility bill runs around 75 bucks a month except when it's real cold. Then the resistance elements in the Water Furnace come on to hold the temp and his electricity bill goes north real quick.
He still has to have a backup genny just in case utility power fails and that requires a propane tank plus the genny.
I don't much care for the output either. The air always 'feels' cool to me.
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56436)
PENDING SELLER...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
200 Gallon Tank (A57148)
200 Gallon Tank...
