L4610HST Slowly bleeding to death.
   / L4610HST Slowly bleeding to death. #11
I understand, Patrick. Anytime someone else will do the work and it doesn't cost me anything, that's the way I go./w3tcompact/icons/laugh.gif And especially in this heat./w3tcompact/icons/frown.gif
Bird
Rich, I had in mind about what you suggested but was overcome by a brief random heavy duty gust of lazy and other extenuating corcumstances. (See post to Bird). I had the trippple valve kit with TnT installed when I bought this beast. One goes to extra aux outlets in back for hydraulic scarifiers, cement mixer, etc. The three valves are mounted as one and in a hard to get to position. One of the hoses to the rear aux quick connects had to be replaced with one bent more sharply for clearance as it hit the cab while trying to plug something in and it couldn't be used without partial dissasembly and a helper. Not convenient. I basically don't like to accept coincidence as the reason for much of anything. I figure the odds are in favor of that changed hose going to that valve as being the culprit as that is the only thing on that trippple valve assy that was changed at the 50 hr.
One day I am going to have to pour a set of ramps with safety curbs to drive the tractor onto for easy access to the underside. Anybody out there done this, seen this, know of any reason it souldn't be done? Speak now or forever hold your peace. I might come up with something that would work safely and conveniently for other vehicles as well. Don't want a "Grease pit", would likely fill with water, dirt, debris, distracted people, whatever.
Patrick
Del, Catch basins to recycle the fluids. I shouda thought of that. There was a guy in the dorm down the street from me in early college days who drove something really old (babbited bearings and like that). It was old worn and looked like something out of a black and white movie bootlegger chase scene. Anyway it started and ran reliably, smoked reliably A N D he carried a bucket under it (good road clearance in those vintages) to catch his leaking engine oil (motor oil if you prefer). Ever so often he would pour it back into the engine. I think the crankshaft rear main seal was a little less than perfect. Worked for him! I suppose he could have automated it with a pump and float switch.
Patrick
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A56436)
2023 Kubota Z412KW...
1985 Ford Ltl9000 Tender Truck (A56438)
1985 Ford Ltl9000...
Kubota M108S (A53317)
2008 KENWORTH T300 FLATBED FUEL TRANSPORT TRUCK (A58214)
2008 KENWORTH T300...
5ft Woods 60 Rotary Cutter (A57453)
5ft Woods 60...
Case BPM13 Mixing System (A57453)
Case BPM13 Mixing...
