Geothermal Loops?
/ Geothermal Loops?
20 20 said:
It was built in 1860 with remodel in 1990's but they didn't use any insulation.
This is where I'd definately put some reassurance, insulation, IMO, can make or break a house for heating and/or cooling. A person can have the biggest badest setup there is but without good insulation it won't mount to a hill of beans
Yes I have added attic insulation and planning residing and insulating walls when in 2 years when we remove wood siding and add the laundry room. Its all a 6 year plan as we are paying as we go. Its came along ways in last year since we bought it.
/ Geothermal Loops? #23
You might want to put off the geothermal until the house is properly insulated. You are either buying a lot more 'tonnage' than you need or planning on supplemental heat until you insulate. Either would be a waste of money. Insulating is the most cost efficient way to reduce HVAC energy use.
It would be cheaper to have the wall cavities filled now and pay less to heat and cool for the next 2 years. They will plug the holes in the siding which you are planning to replace in 2 years anyway. Then have an energy audit done and get the proper size Geo system. Maybe even have an audit done first, there might be other things you need to do at the same time to tighten up the house though replacing windows would probably be better done when you replace the siding unless they are single pane with pocket weights :).
The cost to insulate in 2 years will probably go up (like everything) so the difference in cost (plugging the holes mostly) will be little to none, maybe even cheaper now so you would be well ahead money wise. The other option would be to wait the 2 years and take off the siding AND sheathing and fill with batts. That would be a LOT MORE work and expense (unless you do all the work yourself).
/ Geothermal Loops?
The right size with insulation and addition is six ton or a dual zone multi unit system. I agree that cost wise insulation would go along ways which is why we did the attic but the wall will have to wait.
Its just one of those 5 yrs from now it wont matter which came 1st the insulation or geo because both will be done and I hate doing things twice or having to not complete a project because of lack of funding.
Talked to a geo specialist and looked at a system with loops that were 44 inches and owner was very happy with how it was working.
/ Geothermal Loops? #25
Problem with geothermal is there are too many "qualified" professionals pretending to "engineer" these systems using generic rules of thumb. It seems every practitioner has an angle, mostly because it is the way they make the most $$.
A well driller will sell you on the open loops because they know how to make $$ drilling wells. Another practitioner will sell you on vertical closed loops with grout because they are likely the distributor for the grout. Others sell special pipe that has magical heat transfer rates.... Most are acting as design professionals without any endorsed Professional Engineering License, good luck if there are errors or omissions in their design.
Geothermal has been around for a long time, but is a very immature industry.
/ Geothermal Loops? #26
If I did it all over again...I would have the entire house insulated with closed cell foam prior to the geothermal heat. The part of my house that I did with the foam is unbelievably tight and retains heat for a long time.
/ Geothermal Loops? #27
You're right about that. We had some wildly different quotes for our system three years ago, anywhere from 3 to 5 ton systems, 3/4 to 1.5 inch pipe, and different field designs, a couple of which I'm pretty sure would not have worked well at all.
We finally went with the most experienced installer we could find, and it turned out they were among the best. Not to mention the cheapest! Even at that, there were a few piping errors inside the house, but they did get rectified before we were finished.
Incidentally, there IS software designed to calculate heat loss and geothermal requirements. The installer simply plugs in the variables the program calls for and it spits out what's needed. However, they do have to understand exactly what is being requested, and how to compensate for non-standard conditions.
Sean
/ Geothermal Loops? #28
Yep, geothermal is a big outlay up front, but with tax credits (state and federal) you'll get a huge chunk of that initial money back over a short period of
time.
We replaced a heat pump with geothermal and we figure at 4 years with the credits and reduced electric bill, it would have cost the same as a new heat pump. Now we have savings on our electric bill (we heat our water with it too) into the far future.
We did our homework and got a great contractor. The only downside it the cost of the filters, which are north of $100, but last us about 18 months.
/ Geothermal Loops?
I purchased the software to do the loop design my self from the company that I am buying the geo pump from. And it showed that at 48 inches I wouldn't need electric backup till it was 6 out and that would put my water at 30 degrees. So I changed some inputs in the program and at 5 foot I can get down to 0 and shouldn't need extra heat with 3000 foot of pipe.
I had put loops in for others but never like how they wanted it done. So this will be my 1st 100% all my design and I specified all the equipment with what I feel is good equipment. If I am wrong better to be wong at home than in someone elses yard. Should take about 10hrs to put the lines in.
/ Geothermal Loops? #30
When I did my house the EMC calculated 34,000 btu heating and 31,00 btu cooling with 22F outside, 70 inside and 92 outside, 75 inside for cooling using Right -J short form. The 3 ton Climatemaster with ground slinkys has worked fine at 74 all year round. At near 100 F outside it runs a lot, at 10F it runs a fair bit but no discomfort. Both of those temps are a bit out of normal seasonal weather.
They watered the dirt as they were backfilling the slinkys. I can't remember how much dirt before they watered but I know they did.
My mean earth temp is probably 14F warmer than where you live. We do just fine without booster heat but 14F earth is a lot warmer for heating.
My folks did foam in their 1900 house back in the early 1970's. They say it made a huge difference in comfort. The installers peeled off some of the redwood siding up towards the top of each floor, drilled some holes and foamed away. Years later we removed plaster and for the most part they had done a great job. A skilled insulation company should be able to foam your existing house which will make a huge difference right now but it looks like you are on your way to geothermal right now.
/ Geothermal Loops? #31
We have 4 ton Waterfurnace with 2500 ft of "fluffed" coils in our pond. We heat about 3800 sq ft and our highest heating bill was about $110 at 4.2cents/kWh but the rate just went up to 5.2 cents for this winter.
The guy who installed the system also has a horizontal drill and can install ground loops with minimal ground disturbance. The trajectory of the bore is calculated and set such a way that the drill bit will emerge from ground at desired location. The drill head is removed and two pipes connected at the end with a U are pulled under ground. The drilling polymer that was used to power the drilling head prevents the bore from collapsing, lubricates the bore and also provides thermal contact.
Friend of mine just installed new geo in existing house they just bought. The bid was about 20000 but after rebates and tax write off they paid only something over 12000. They think it will pay for itself an about 4 years.
/ Geothermal Loops? #32
I would LOVE to pay only 4.2cents/kwh
Ours currently is ~10cents or a little more. It all depends on how much you use. The more you use, the cheaper it is per KWH.
My last bill was for 1644Kwh. At your rates that would have been only $85
At MY rates, the bill was for $180:mad:
/ Geothermal Loops?
Well got the loops in and all went as planed took about 11 hrs to get all the pipe in the ground. We found a old heating old tank old septic tank and several tiles for the old lateral field as we have new aeration septic. Had wet clay from 34 inches down with as dry as its been that was a nice find and should help make it more efficient.
/ Geothermal Loops? #34
You guys are killing me here... our last bill was for 948 kwh, by the time all the fees and taxes are added in it was nearly $160... slightly over 12 cents per kwh.
Sean
/ Geothermal Loops? #35
We have two meters one for heating and the other for total consumption. The heating rate is 5.2 cent/kWh and used only in the heating season. The normal rate is 11 cents. Then there is tax and service surgarge added on the top of it.
/ Geothermal Loops? #36
I never heard of anything like that.
I wished we had that here. That would cut my heating bill in half. Since I heat with electric (heat pump) 90% of the time, and only use propane below 17 degrees. But If electric for heating were that cheap, that would make electric resistance heating for back up even cheaper than the propane.
/ Geothermal Loops? #37
That is exactly the case. I just bought Fujitsu HP (split unit) for my shop. It should work down low to 4F. Then resistive heat will be used. I also got a meter for the shop heating.
/ Geothermal Loops?
Ended up ordering a new 5 ton century 2 stage unit as local distributer real wanted our business and several others have asked me to install systems for them. Equipment should be in by end of the month.
/ Geothermal Loops? #39
I am heating my house with the Fujitsu's. Depending upon model, they will make rated output below zero. I just put in a Rinnai Ex22 propane wall furnace yesterday as well. I removed the 5 yrs old gas central furnace and air system that had been added to the house. Ductwork was very poorly done and leakage was enormous. Let's see, an 80% efficient furnace, with a 60% efficient duct system, hmmm let me check my math...48%. All of my equipment is net to the space now with no transmission losses.
My point is that regardless of equipment efficiencies, it is frequently the "transmission" system that is the weak link.
Have to acknowledge my bias, to be fair. Prior to selling my business last year I had represented Rinnai for 20 yrs and Fujitsu for 12. Just for drill go to www.miniheat.com That was my site. It is out of date model wise, as I'm no longer in the bus., but pay attention to the "total hrs/yr" column. That tells you how many hrs per year you will be at a particular temperature. It is a 25 yr compilation of dederal weather stats.
I'll be interested to hear how your install goes. What model did you put in?
/ Geothermal Loops?
Well finally had time to install over last weekend. Everything went real smooth and seemed to go together as planned. The hardest part for me was the duct work but got it done and up and running. I am amazed at how quite it is when running and that it is handling the house on the 1st stage without any problem but is 20 out so it will get colder soon. I'll try to get some photo's up this weekend.
1999 Peterbilt 330 Truck (A66736)
1999 Peterbilt 330...
PALLET WITH 3 ELECTRIC CHAIN HOISTS AND ONE MANUAL CHAIN FALL OUTBOARD MERCURY PARTS MOTOR (A66738)
PALLET WITH 3...
2020 GMC SIERRA 1500 (A67714)
2020 GMC SIERRA...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A66734)
2025 Kivel 42in...
2017 RANCO BELKY DUMP (A67714)
2017 RANCO BELKY...
2018 KENWORTH T370 LUBE TRUCK (A65057)
2018 KENWORTH T370...
