generator light always on
/ generator light always on #1
MillWeld
Durham NC
Ford 641
On my Ford 461 tractor (1958 model, 6 VDC starter) the red gen light is on bright when idling and rather dim when at operating rpm. How do I determine if it is the generator or voltage regulator?
/ generator light always on #2
Check the voltage out of the generator and out of the voltage regulator.
probably a dumb question but ... what voltages should i expect to isolate the source of the problem?
/ generator light always on #4
assume you mean a 641.
full field the unit and then check. IE.. jump bat to field. if lamp goes out at anything over idle, then you could replace the reg. if lamp don't go out, then slip belt off the gen and try a motor test. jump bat to arm and field. should spin real good like a motor.. if it is slow or stalls.. probably time for brushes.. etc.
can always check bat voltage at batter before start, at idle, then mid throttle, then high throttle.
6.2 - 6.3 is a well charged static 6v battery.
7.2 - 7.3 is good charge voltage. 6.3-6.6 should be a very low charge
not.. analog meters are good to use to check this as cheap consumer grade and auto rangers don't like brush noise due to timing windows / sampling rates..
soundguy
oops, yeah, it is a 641.
I took a short circuit to a repair. I figured the generator brushes probably wouldn't fail so quickly so I replaced the regulator with a used one known to be good and the problem was solved. :thumbsup: Thanks for the detailed analysis, Soundguy, I'll hold on to that one.
/ generator light always on #6
hope it helped some.
soundguy
JOHN DEERE 11 SHANK CHISEL PLOW (A63291)
JOHN DEERE 11...
John Deere 652R 52in Stand-On Commercial Mower (A56857)
John Deere 652R...
2015 John Deere X320 Lawn Mower (A63116)
2015 John Deere...
2015 HINO BOX TRUCK (A63569)
2015 HINO BOX...
2016 WILDWOOD TRAVEL TRAILER (A63569)
2016 WILDWOOD...
2015 Chevrolet Traverse SUV (A61574)
2015 Chevrolet...
